Results 1 to 5 of 5
    Reputation: innovator8's Avatar
    Rear tire size 2011 Enduro
    Has anyone put a Maxxis highroller 2.5 on the back of their enduro?
    Im planning on a minion 2.5 in the front and the highroller 2 on the back.
    I'm pretty sure this will make for a great tire combo, I know that the maxxis tires run a bit narrow, for example, I have a minion 2.35 one of my bikes and it is narrower than the purgatory 2.2 that came on the bike.
    Im not sure if I am gonna rub or not.
    thanks,
    Jeff
    Mar 2011
    Plenty of room for 2.5 Maxxis tires. I ran that combo for a while on my 2010 enduro. Personally, I prefer the DHF on both the front and rear (I find the DHF grips a bit better on the climbs), but the Minion front high roller on the rear is a good combo.
    Re: Rear tire size 2011 Enduro
    Cool man, thanks, did you have high roller or the high roller two?
    Mar 2011
    It's the original High Roller.
    The highroller 2 uses the same casing as the old highroller so, they're the same volume. Maxxis is just being more accurate with the claimed sizes now.
    The high roller 2 side knobs are different however, so the tire is 1mm wider at the top of the side knobs, so it'll be fine on the enduro.
    I have a 2.2 Purgatory on one of my bikes and it's actually a bigger volume tire than 2.5/2.4 Maxxis tires, however, the Maxxis tires are slightly wider at the edge of the side knobs.
    Cool man, thanks
  1. Enduro rear tire recs (Specialized tire)?
    By jgusta in forum All Mountain
    Last Post: 07-10-2012, 03:10 PM
  2. Trail 29er 2011 max rear tire size?
    By fuenstock in forum Cannondale
    Last Post: 06-30-2012, 01:13 PM
  3. 2011 endro rear tire size ?
    By gsxr1000dave in forum Specialized
    Last Post: 03-17-2012, 04:11 PM
  4. Biggest rear tire size for a 2011 stumpjumper
    By k29er in forum Singlespeed
    Last Post: 02-25-2012, 08:38 PM
  5. 2010 enduro rear tire max size
    By thrasher_s in forum Specialized
    Last Post: 10-04-2011, 01:13 AM
