Results 1 to 3 of 3
    May 2010
    Rear D Shifting on Own
    I'm having an issue with my Rear D on my Spec Enduro 2010. Stock x7 shifters and x9 rear derail. New PG990 cassette.
    Normal riding, the rear shifts fine. Rock gardens its ok too. When I go off a jump or drop, or even sometimes bunny hop over stuff, the rear shifts by itself. The drops are around 2ft. It mostly drops to a lower gear (smaller cog). Anyone know how I can resolve this or what the issue may be.
    No loose cogs, chain wear has been checked. No problems shifting normally. Thanks!
    Reputation: kingbozo's Avatar
    You may not have enough cable length to the rear D. There should be"loose" cable underneath the bottom bracket.
    May 2010
    Quote Originally Posted by kingbozo
    Thanks for the reply. I checked my cable and it does seem tight, especially for the rear d cable. I'll give it some slack and hope fully it will help. thanks
