Results 1 to 5 of 5
    Central High 269!!!
    Reputation: extremeb's Avatar
    Mar 2006
    quick rockhopper question
    I recently purchased a 06' Rockhopper Comp Disc with the Rockshox Tora 318 fork. I haven't taken it out of the shop yet (not until summer), but does anyone know if this fork on this specific bike comes in COIL or AIR.
    I already know this fork comes in coil and air form but I want to know which version Specialized chose to put on every of their 06' Rockhopper Comp Disc models.
    Thanks in advance!
    Yo, I have an account on Squidoo...Check Me Out!
    ...the wave won't brek
    Reputation: anthrax's Avatar
    From the Specialized web page on the '06 Rockhopper Comp Disc:
    FORK: RockShox Tora 318 SL, coil spring,100mm, 32mm Cr-Mo stanchions, alloy steerer,
    motion control damping, preloadand rebound adjustment w/ Lock Out
    2008 Santa Cruz Superlight SPX-XC Kit
    2003 Specialized Rockhopper FSR-XC Comp
    2006 Specialized Allez Sport Double
    Central High 269!!!
    Mar 2006
    Thanks for the help! I was a little curious of what I was buying!
    I'm not sure if the Specialized web site is correct regarding the Tora. I purchased the comp disk in October and the Tora that came on the bike is adjusted by air pressure, and when it has no air in the fork it sure doesn't feel like their is a coil in the leg. I have not opened it up yet, but I'm pretty sure its the solo air spring.
    On another note, I think you will be very happy with the performance of the fork. Most other forks that come on bikes in this price range don't come close to matching the performance of this fork. Compression and rebound adjustments are easy and quick and work well. Give it a little time to break in and ride it hard.
    Central High 269!!!
    Mar 2006
    I thought so! Do you think that they all come in Air form on this bike?
