Results 1 to 7 of 7
    Quick handlebar question
    I have an 07 rockhopper comp. Specialized says my handlebars are XC rise. What does that equate to in an aftermarket bar like the Easton monkey lite. I need help! Thanks for the help
    Reputation: EDDIE JONES's Avatar
    Mar 2005
    Quote Originally Posted by Kevin22
    Easton Low rise I think
    Specialized Rida
    Reputation: skate's Avatar
    All that means that it's low rise and lightwieght enough for XC. I'm sure they are close to eastons spec wise, but chances are that eastons may be lighter (depending on which one you buy). Plus easton is in the business of bike components vs. specialized is in the business of bikes and purchase part from companies like easton.
    But what rise is the Specialized xc rise equal to from Easton?
    Specialized Rida
    As mentioned Easton has different specs per handlebar, but chances are that it is about a 1.5 inch rise. Easton has the same specs depending on which bar you choose. thier are to many specs choices with easton that you can't compare the two unless your very specific on which easton your talking about.
    Reputation: Lumbee1's Avatar
    Dec 2004
    Kevin, did you actually look at the Specialized website before asking?
    Specialized alloy butted 31.8mm XC rise w/ graphic, 640mm wide, 8 degree back, 8 degree up sweep
    Reputation: Student Driver's Avatar
    Quote Originally Posted by Lumbee1
    Unfortunately that quote doesn't actually read how much rise it has either. According to the site, it reads "XC oriented mid rise (1.0*)" which I bet should read 1.0" as the mid rise bar is listed as 1.5".
    1997 Specialized Stumpy Pro
    1998 Specialized Allez Epic
    2007 Specialized Stumpy FSR Elite
    2010 Specialized Roubaix Expert
