Results 1 to 5 of 5
    Aug 2013
    QR release on epic comp carbon 2014 - will this DT Swiss RWS fit?
    Hi,
    looking for a QR skewer to enable easier exchange of the wheelsets on my new epic comp carbon 2014.
    Will this version of RWS from DT swiss fit the epic comp carbon 2014 frame?
    DT Swiss RWS X-12 Alloy | Chain Reaction Cycles
    kind regards
    Christian
    Reputation: jnicosia's Avatar
    Aug 2013
    Looks like you already have a 142+ 12mm thru axle , is it not the DT swiss one ? Thats the one that came on my Specialized Camber carbon EVO expert
    REAR HUBSpecialized Hi Lo disc, 4x-sealed cartridge bearings, 12mm thru-axle, 142+ spacing, 32h
    Aug 2013
    no, my epic comb carbon came with a 12mm axle which needs a 6mm hex key to turn.
    But if your camber carbon evo (that are spec'ed with the same rear axle dimensions) came with a DT swiss RWS X-12, I guess it should work on my epic as well.
    I will give et at try
    thank you for your reply.
    Christian
    Aug 2013
    I don't know Bud, I just looked at my rear drop out and its threaded to except the thru axle without the nut on the end.
    Aug 2013
    Sorry, Misread your post, Yes that DT swiss RWS should work
  1. Replies: 56
    Last Post: 06-27-2014, 10:16 PM
  2. Replies: 4
    Last Post: 03-08-2014, 03:31 PM
  3. 2014 Epic Comp Carbon Front Derailleur Issues
    By Rocketman88 in forum Specialized
    Last Post: 01-03-2014, 07:58 AM
  4. Going tubeless 2014 specialized epic comp
    By Boothy82 in forum Wheels and Tires
    Last Post: 11-28-2013, 04:15 AM
  5. Replies: 5
    Last Post: 02-25-2012, 02:49 AM
