Results 1 to 26 of 26
    Reputation: phlegm's Avatar
    Push/Push vs Push/Pull
    Ok, let's reopen the debate.
    I'm a Shimano guy and used to push/pull shifting. Just bought an Epic with the Sram push/push and trying to weigh the benefits.
    Feels weird to me now, but push/push technically leaves more fingers on the bar. That said, Shimano's push/pull allows you to keep the thumb and index in place for shifting.
    What's your take on this?
    Hands down SRAM all day long. I have used both and am so pro-SRAM that I may buy my next bike based on if it has SRAM or not. Strictly talking just the shifting method I prefer the SRAM push/push because I can still use the shifters while my fingers are on the brakes.
    old and slow
    Reputation: BluesDawg's Avatar
    I'm fine with either type. It may take me a minute or two to readjust when moving from one to the other, but they both work well.
    There's only two things in life (but I forget what they are). - John Hiatt
    I find it easier to change up, whilst standing up, with Shimano. Have to reach under the bar with SRAM, which I don't find easy when leaning over the bars.
    Reputation: ebeer's Avatar
    Prior to my '12 SJ Evo I'd never ridden SRAM....was a die hard "pull" shifter. Took me about three rides to completely break the habit. Now when I ride a Shimano kit I only push.
    Sep 2012
    Personally--I like the shimano system way better.. I had a set of xo shifters and just never liked the push/push... Now i have a set of xt shifters and like that i can either push/push or push/pull -- and i like the option to double downshift for faster dumping of gears..
    Reputation: wetpaint's Avatar
    I don't mind my Sram shifters, however, I love the new XTR stuff, being able to shift with my thumb and pointer finger is awesome
    Sep 2012
    SRAM for sure fire me. Guess it's a matter of taste.
    Sent from my Galaxy S3
    Jamis Dakar XC Comp
    Jamis Quest
    Selle Italia Ldy Gel saddles
    Shimano here. Always preferred Shimano. Plus you can push/push with Shimano if you so choose. I did initially (before Shimano did 2-way release) appreciate the push/push of SRAM for wrenching as it was easier to reach the release when stretching yourself to the arse end of the bike.
    Dec 2012
    can someone explain the difference please
    Quote Originally Posted by sinfony78 View Post
    Sorry, I'll backtrack a bit.
    I'm used to the standard Shimano shifting setup where you use your thumb and or index finger to shift. The thumb is a push by default, where the finger is effectively a "pull".
    I just moved to a SRAM-based bike, where you push both buttons with your thumb.
    Reputation: Saul Lumikko's Avatar
    Oct 2012
    Quote Originally Posted by blinder View Post
    If you still have some SRAM shifters on a bike of yours, try rotating the shifter forward for easier access to the lever and trigger.
    I can and do pull with SRAM shifters when I think it will be easier than pushing like when standing. I tend to go back and forth based on where my fingers are at any given time.
    Reputation: Bicyclelist's Avatar
    SRAM for me. I one finger brake and always keep my finger on the brake so thumb push/push is natural. Even with my XX1 I can go from the hardest gear to the easiest in 2 pushes. I also like the crisp, precise feel of a SRAM shift compared to the quiet and smooth Shimano shift. Definitely just a personal preference.
    Sep 2012
    Quote Originally Posted by jhat View Post
    Can you explain how you're doing this?
    I prefer the Shimano push/push as you can upshift 2 gears on the XT/XTR shifters.
    Quote Originally Posted by the-one1 View Post
    I prefer the 'twist/twist' of SRAM over the 'push/push/pull' of anything else.
    MCH Co-Captain
    old fart
    The clincher for me with SRAM was that I learned to 1-finger brake (using my index finger). Besides being a much better way to ride XC, this means that a "pull" type shift doesn't work well. So Push-type shifters are essential.
    I like turtles
    Reputation: TiGeo's Avatar
    I spent 10 years on push/pull and in the last year got my first taste of SRAM shifting...ain't goin' back.
    Geologist by trade...bicycle mechanic (former) by the grace of God!
    2018 Niner RKT 9 RDO - enduro are #@$%
    Oct 2012
    Quote Originally Posted by Tech420 View Post
    I agree
    DFMBA.org
    Reputation: MTBeing's Avatar
    I will be transitioning from all Shimano to all Sram very soon (new ride). The Shimano push/pull feels the most natural if that's even a proper deacriptive here. I do like that I can double-shift quickly on the pull action. It will be interesting to feel the difference, but Im embarrassed to admit that I'll miss the indicator windows. I do look at them.
    Sent from my mountain bike while crashing
    Please donate to IMBA or your local IMBA chapter. It's trail karma.
    I'm gonna build up a 26er with a Sram X7 right trigger,a Shimano XT left shifter, and a Rock Shox DNA motion control powered by a friction shifter on a alt handlebar.
    ...It's space travel time.
    roccowt.
    rocnbikemeld
    maybe my shifters are different but the shimano slx ones i have on my giant and the ones that are on my new 10 spd epic are the big shifter is push only and the smaller thumb on can be used in both directions. for me they both shift when i need them to so i don't see as much difference besides the sram stuff not being able to be pulled when needed. for the record i only push all the time and have never even thought to use the pull method.
    Dec 2011
    I ditched it all and went with the new SRAM gripshift. Will never go back.
    old fart
    You can on SRAM as well...
