Results 1 to 13 of 13
    MTB B'dos
    Reputation: LyNx's Avatar
    Purgatory cut, thoughts?
    SO I've run and tested Maxxis tyres now for over 2 years and never had a sidewall cut/sliced, not a Specialized fan, but thought I'd give the new Purgatory in Control casing a shot - expensive shot Do they have a replacement program for such incidents? Couldn't believe that it sliced the casing like it did, but going all the way up through the tread was the real surprise. Luckily I had a quite big plastic tyre boot and finished the ride, thinking if no option for discounted replacement etc I'll just patch and stitch it and use it as a rear only.
    On wuss patrol
    Reputation: Glide the Clyde's Avatar
    For me, while I like the traction and performance of Specialized tires, I find the sidewalls to be quite thin and they do not hold up well, especially the S-Works and Controls. I recently tossed an S-Works Ground Control I had on the rear with only a year of riding and lots of tread left because the sidewall threads were showing and it had begun to separate with the tube bulging through in a couple places. Meanwhile, I run Nevs on the fronts of a couple bikes and they are 3 years old without a problem other than the tread is starting to look a little tired. They are pigs, though. I ride each bike with the Specialized/Nev combo several hundred miles a year. Probably going to switch brands for rear tires, unless I want something lighter for racing.
    Check with Specialized direct or with an LBS. They may offer some replacement help.
    Sometimes, you need to go fast enough that the trail is a blur to find clarity. -- Wild Bill
    Reputation: Devastazione's Avatar
    Dec 2009
    Love all Specialized tires but i do agree on their very thin sidewalls even at Control level. That's why I keep them at a very high pressure.
    Bad cut,where were you ? Floating on spiked rocks at a low pressure ?
    MTB B'dos
    Yes, out on the sea cliffs which are coralstone, was running about 27PSI as a rear on a Flow rim tubeless, weigh about 180-185lbs geared to ride. Have ridden out here numerous times before on Maxxis TLR/EXO rubber with no issues.
    Quote Originally Posted by Devastazione View Post
    Class Clown
    Reputation: dundundata's Avatar
    that's disappointing, i've run the sport versions I'm guessing they are tougher stuff
    Go by your LBS and have them give Specialized a shout. The tire looks pretty new, so they might be willing to warranty it. Worth a try.
    MTB B'dos
    Unfortunately that would be Miami and I live down in the Caribbe4an, but still going to e-mail/ring a shop I deal with and see what they say. Yes, brand new, only the 3rd ride on it, less than 30 miles.
    Quote Originally Posted by owensjs View Post
    Specialized has a satisfaction guarantee on their tires for 90 days. You can exchange them for another tire (or maybe a credit) for any reason you want.
    You need to buy them from a dealer and have the receipt. Some dealers will swap them for you no questions asked and others may hassle you first, but they should eventually help you out. If they don't you should be able to contact Specialized customer support.
    If you decide to give the Specialized tires another shot I'd go for a grid casing. I ride them all the time and haven't had any trouble with them.
    Spec Tech FAQ: Specialized Bicycle Components
    Search: :"Is there a satisfaction guarantee on Specialized tires?"
    I dig trails!
    Reputation: Mr.P's Avatar
    Feb 2005
    You answered your own question.
    Sidewall protection... ALWAYS!
    They make a sidewall protection version if you like the rest of the tire.
    P
    MTB B'dos
    Yeah, only problem is that it's sposed to weight 1,000g for the 29er version and for what the tyre is I just can't accept that, all my Maxxis tyres of similar application design are well under 900g, closer to 800g with the EXO casing. If that is my only option for some help/replacement, then I'll go that route, but this'll be my first and last Special tyre.
    I dig trails!
    Feb 2005
    Here is the one I am referring to "Armadillo Elite" they are light, but it looks like they don't have them in 29 :/
    The Armadillo casing is like EXO, is light and tough - but is a bit stiff.
    P
    MTB B'dos
    Yeah, I know about the Armadillo casing, would have got it if they offered it in 29er version Not quite sure why they don't since they're pushing 29ers so hard
    Quote Originally Posted by Mr.P View Post
    P
    I dig trails!
    Feb 2005
    And the Enduro will need that casing too!
    P
  1. Purgatory 2.3 or 2.4
    By HrznRider in forum Wheels and Tires
    Last Post: 12-26-2012, 06:54 AM
  2. Purgatory 2.3?
    By dgw2jr in forum Wheels and Tires
    Last Post: 09-26-2012, 08:27 AM
  3. Replies: 2
    Last Post: 05-08-2012, 02:43 AM
  4. Replies: 4
    Last Post: 12-19-2011, 12:51 PM
  5. In what way is the Captain better than the Purgatory?
    By beanbag in forum Wheels and Tires
    Last Post: 06-22-2011, 12:24 PM
