Results 1 to 3 of 3
    Reputation: JosephAverage's Avatar
    PSI in the Rear DHXAir3.0
    I just got a 07' Enduro FSR and I love it. The only problem is the sag is a little to much. I weight about 200lbs and I have it pumped up to 205 PSI. I thought I read (in what little literature Fox has about the DHXAir3.0) that you should keep the PSI between 75 and 200? Is this true or can I pump it up a bit more to get the sag proper?
    Any help would be much appreciated.
    Reputation: 'size's Avatar
    fox actually says less than 300 psi on the dhx air models:
    Thanks man. I must have overlooked that. This will make me much more comfortable pumping the shock up to where it needs to be.
