Results 1 to 10 of 10
    Reputation: Devastazione's Avatar
    Dec 2009
    Plz help me find the right adapters ( Shimano XTRs)
    Bike : Stumpjumper FSR Elite 29 2013
    I'm about to buy some mighty XTR Trails brakes and i need the whole package : rotors and adapters.
    I can keep looking at the XTR equipped Sworks Stumpy FSR for hours but I still can't figure out wich Shimano adapters I need to buy. Let me go ahead and try :
    front : IS 200 ?
    rear : PM/PM 180 ?
    I've got the money burning in my pocket,I can't belive there's just two stupid piece of metals holding me up.
    What could go wrong ...
    Reputation: Zoke2's Avatar
    Nov 2007
    look at #3 and #4 ... should be what you need
    Universal Cycles -- Shimano Disc Brake Adapters
    I used to ride to Win ... Now I ride to Grin
    While my guitar gently weeps, my bike sits there mocking me
    Just did the same thing this weekend, except with XT on my Expert 29'r. PM 74mm to PM 74mm front and back, sized to your rotors. What is your front fork? If it's a Fox, its 74mm Post Mount and not 51mm IS.
    Dec 2009
    Quote Originally Posted by Zoke2 View Post
    Those seems to be all IS,it looks like the fork still has a PM mount. Damn..
    Dec 2009
    Quote Originally Posted by bicyclebillpdx View Post
    Yes it is a OEM Talas Fox. So what you're saying is I can look for the same adapters for rear and front both PMs ? Front rotor is 200mm rear one is 180mm.
    Yep, PM74/PM74 203mm front and PM74/PM74 180mm rear.
    Dec 2009
    Great !! Thanks,rep given. So I would assume the rotor's size is printed on the adapter like Avid does,is that correct ?
    Nov 2007
    Quote Originally Posted by Devastazione View Post
    #3 looks to be 74 PM
    180mm / 51mm / Front / 74mm Post / SM-MA-F180S/P
    Yes, the size is on the adapter, as part of the bigger funny looking part number
    180mm / 74mm / Front / 74mm Post / ISMMAF180PPA
    203mm / 74mm / Front / 74mm Post / ISMMAF203PPA
    Reputation: WR304's Avatar
    That took a long time to finally get round to fitting Shimano brakes.
    March 2012
    Need help in swapping from Formula R1X to Avid x0(Epic 2012)Rep given.
    You'll need post mount adapters front and rear, along with Shimano RT-86 Ice Tech rotors if you're using six bolt disc brake hubs.
    The Shimano brakes have quite a distinctive feel so it's worth practicing gently bringing in the brakes to find the bite point when you first get them. Going down a road descent where you can feel out the brakes response as you apply them on and off initially is a good start.
    Putting some light oil on the servowave cam inside the brake lever makes the lever action a lot smoother also.
    Once you're used to them complaints about lack of modulation and grabbiness shouldn't be an issue. There is a learning curve though.
  1. Where to find Mavic Crossmax XL 20mm adapters
    By GTscoob in forum Wheels and Tires
    Last Post: 12-27-2016, 03:32 PM
  2. Magura and Shimano adapters for Shimano calipers
    By crazylax42 in forum Brake Time
    Last Post: 05-10-2012, 08:48 PM
  3. New XT calipers, non-Shimano adapters?
    By fat_weasel in forum Brake Time
    Last Post: 11-14-2011, 01:14 PM
  4. Replies: 6
    Last Post: 04-06-2011, 12:23 PM
  5. Hope/ shimano adapters
    By simen in forum Brake Time
    Last Post: 01-19-2011, 11:35 AM
