    Oct 2011
    Please help me to decide between a 2012 Trek Cobia and 2012 Spcialized Carve Comp
    Hi guys I was hoping someone could help me to make a decision between these two bikes. I have been deliberating for some time over these two setups and still am not anywhere close to a decision. I love the color of the Trek Cobia ( red and white) but feel the frame is inferior to the specialized. I think the Specialized has a better frameset but inferior drivetrain ( SRAM v Alivio).
    I wonder if I should buy the specialized for $200 more and upgrade the drivetrain at a later date. Or should I save the $200 and upgrade something else on the Cobia?
    Trek Cobia Setup
    Colours
    Chi Red
    Frameset
    Frame
    Alpha Gold Aluminum, butted & hydroformed tubing, cold-forged dropouts & bottom bracket, G2 Geometry
    Front suspension
    RockShox Recon Silver TK 29 w/Solo Air spring, TurnKey lockout, rebound, custom G2 Geometry, 51mm offset crown, 100mm travel
    Sizes
    15.5, 17.5, 19, 21"
    Wheels
    Wheels
    Shimano M475 alloy hubs; Bontrager AT-850 disc 29 32-hole rims
    Tyres
    Bontrager XR3, 29x2.1"
    Drivetrain
    Shifters
    SRAM X5, 10 speed
    Front derailleur
    SRAM X5
    Rear derailleur
    SRAM X5
    Crank
    SRAM S800, 44/33/22
    Cassette
    SRAM PG-1030 11-36, 10 speed
    Pedals
    Wellgo alloy
    Components
    Saddle
    Bontrager Evoke 1
    Seatpost
    Bontrager SSR, 27.2mm, 20mm offset
    Handlebar
    Bontrager Low Riser, 31.8mm, 5mm rise, 9 degree sweep
    Stem
    Bontrager Race Lite, 31.8mm
    Headset
    1-1/8" threadless, semi-integrated, semi-cartridge bearings
    Brakeset
    Hayes Dyno Comp hydraulic disc brakes
    Accessories
    Grips
    Bontrager Race Lite
    Specialized Setup
    FRAME Specialized M4SL fully manipulated alloy frame, 29" XC geometry, fully butted w/ smooth welding, tapered head/seat tube, forged post mount 160mm dropouts w/ replaceable derailleur hanger, disc only
    FORK RockShox XC32 TK SA 29 SL, magnesium lower, 32mm Cr-Mo stanchions, 1-1/8" to 1.5" tapered alloy steerer, coil spring, TurnKey damping w/ LO & external reb. adj., 80mm travel
    HEADSET Integrated 1-1/8" upper and 1-1/2" lower threadless, Campy-style, full cartridge bearings
    STEM Specialized 3D forged 6061 alloy, 4 bolt clamp, 7 rise, 31.8mm
    HANDLEBARS XC flat bar, double butted alloy, 10 backsweep, 4 upsweep, 31.8mm
    GRIPS Specialized Body Geometry XCT Men's, dual compound, Kraton rubber, closed end, 130mm
    FRONT BRAKE Shimano BR-M446 hydraulic disc brake, post mount, 180mm 6-bolt rotor
    REAR BRAKE Shimano BR-M446 hydraulic disc brake, post mount, 160mm 6-bolt rotor
    BRAKE LEVERS Shimano BR-M446, hydraulic lever
    FRONT DERAILLEUR Shimano Alivo, 9-speed, 34.9mm clamp, bottom-swing, dual-pull
    REAR DERAILLEUR Shimano SLX Shadow, 9-speed, SGS cage
    SHIFT LEVERS Shimano Alivio, 9-speed Rapidfire plus, SL type w/ optical display
    CASSETTE Shimano 9-speed, 11-34t
    CHAIN KMC X-9, 9-speed, reusable Missing Link
    CRANKSET Shimano Alivio, 3pc, 9-speed, Octalink spline
    CHAINRINGS 44/32/22, replaceable
    BOTTOM BRACKET Shimano, Octalink spline, cartridge bearing, 73mm
    PEDALS Alloy 1pc. body and cage, reflector kit, 9/16"
    RIMS Carve Disc 29", alloy double-wall, sleeve joint, 32h
    FRONT HUB Formula disc hub, alloy 7075 axle, high-low flange, double-sealed cartridge bearings, machined disc mount and flange, QR, 32h
    REAR HUB Formula rear disc hub, cassette, double-sealed loose ball, polished races, machined disc mount and flanges, 19mm contact, QR, 32h
    SPOKES Stainless, 2.0mm (14g)
    FRONT TYRE Specialized The Captain Control, 60 TPI, 2Bliss Ready, aramid bead, dual compound, 29x2.0"
    REAR TYRE Specialized The Captain Control, 60 TPI, 2Bliss Ready, aramid bead, dual compound, 29x2.0"
    INNER TUBES Presta valve
    SADDLE Specialized Body Geometry Carve, steel rails, 143mm width
    SEATPOST Forged 6061 alloy, 2 bolt head, 27.2mm, 12.5mm offset, micro adjust
    SEAT BINDER 31.8mm, forged alloy, extruded QR leve
    Rockhopper Expert
    I have tried both at my LBS the Specialized lighter and had a better frame, the Cobia felt better to ride and had a better fork, but was heavy 30lbs. Cobia was cheaper too.
    My quest continues as I have not decided yet.
    Oct 2011
    I'd go with the one with the better ride.
    Feb 2012
    Those are tough choices for sure. I love the frame on the Specialized but give the Cobia a VERY slight edge on components.
    It has the better fork but everything else seems pretty much equal IMO.
  1. Replies: 61
    Last Post: 10-11-2012, 10:46 PM
  2. 2012 Trek Rig, Cobia, Mamba
    By imprezawd in forum 29er Bikes
    Last Post: 05-12-2012, 01:49 PM
  3. 2012 Trek Wahoo VS. 2012 Specialized Hardrock
    By smoothie7 in forum Beginner's Corner
    Last Post: 03-18-2012, 10:31 AM
  4. 2012 trek slash 9 vs 2012 remedy 9.8 or 9
    By Demorider in forum Trek
    Last Post: 01-20-2012, 12:51 AM
  5. Just got a New 2012 CARVE
    By jparisi48 in forum Specialized
    Last Post: 12-25-2011, 11:26 AM
