    Oct 2007
    PF30 bearing set
    Specialized is out of the pf30 bearing sets at the present time. Does anyone know of an alternative source for bearings that will work in the new s-works 29er frames? I have a Specialized crank and xx spider to use but no bearing set. Specialized is looking into how long it will be to get some but I'm curious to alternative solutions. Plenty of snow on the ground with more to come so I'm not exactly in a hurry. Will the sram pf30 bearing set work with an sworks crank? I would still need to get the spacers and seals using a sram bearing.
    Reputation: chillie's Avatar
    You have a s-works 29er frame?ht or fs?How about some pics.What is the weight of the frame?
    Oct 2007
    Frames are trickling in...
    Where in the world is Floyellow S-Works?
    Large full suspension that shipped Friday. Not expecting it until later in the week after the big snow storm we are getting hit with in the midwest. Will post picts and weight.
    Reputation: goneskiian's Avatar
    Sep 2004
    I would expect any pf30 bearing to work.
