Results 1 to 7 of 7
    The Dude Abides
    Reputation: theeric's Avatar
    Mar 2006
    pedal bob on 07 FSRxc Comp
    I'm worried about my wife's bike.
    She has an '07 FSRxc Comp. She's about 5-11 and her bike is a large. The shock is the stock X-fusion O2 rc and it is set at about 25% sag. There is compression damper that can go from fully open to locked out, but it's set in the middle.
    While on a slow fire road climb last weekend I noticed A LOT of bob as I was riding next to her. She was seated and was in the middle chain ring and had a smooth pedal motion. With 25% sag and a middle of the road compression damper I don't think there should be any bob (maybe a little), but she seemed to be really bouncing. The trail was pretty smooth so that shouldn't have had an effect. I got an 05 Enduro and I couldn't feel/see any bob in my bike as I rode next to her.
    Do anyone else have and FSRxc? And if you do, how is your pedal bob?
    Thanks,
    Eric
    This aggression will not stand, man.
    thecentralscrutinizer
    Reputation: mopartodd's Avatar
    theeric.
    SHe should set it to the lockout position when riding fire roads. This will provide the most efficiency.
    2015 Kona JTS
    2014 Scott Scale 710
    2014 Giant Anthem 27.5
    2013 DeVinci Leo SL
    Reputation: onegymrat's Avatar
    I have an '05 and the pedal bob is just terrible. My shock is a Fox Float R and the sag is about 25% as well. I'm a relatively new rider and would like to hear about this as well.
    I CAN ALWAYS GO BIGGER
    Reputation: RYAN E's Avatar
    She should try about 18-20% sag.
    I have no pedal bob at all..only when i stand up on the pedals tot accelerate.
    Go to your local bike shop and set the pressure/weight right..
    there might be needed some more air pressure in it.
    The Dude Abides
    Mar 2006
    thanks for the info. I guess the 25% sag is a little too much for the O2 rc. I'll put some more air in to reduce the sag.
    Thanks again,
    Eric
    bi-winning
    Reputation: rkj__'s Avatar
    Quote Originally Posted by theeric
    Thanks again,
    Eric
    i think that is a good idea.
