• 09-16-2012
    GreenLightGo
    OSBB / Truvativ crank question
    Bike in question: 2010 Stumpjumper Expert Carbon (HT, 29er).
    Been doing some reading and understand the OSBB and press-fit cups that came OEM work with the Shimano spindle size.
    I have a virtually brand new Truvativ Stylo 1:1 and love the Rotor SS q-ring. Theoretically, if I wanted to put this crank into play and "EVO" the Stumpy, is this the bottom bracket part I would need?
    BikePedia, Bottom bracket adapter, TruVativ 00.6415.033.040 "GXP Adapter Cups" - Full Item Description
    For fitting SRAM and Truvativ GXP cranksets to frames with either Specialized-OS, BB86-Road, or BB92-MTB press-fit, non-threaded bottom bracket shells (not for BB90/95 Trek Madone/Fuel, or BB30 systems) - Includes 37x24x8mm bearing set with wave washer and bearing shields for use on Giga X Pipe cranks with integrated 24mm GXP spindle (Road: 47.5mm chainline, MTB: 51mm chainline) - BlackBox (hybrid-ceramic bearing) or Team (steel, sealed bearing) in press-fit, internally sealed composite cups - Use of a shop-quality headset press recommended for installation
  • 09-16-2012
    skiwi
    what crank are you currently running?
  • 09-17-2012
    GreenLightGo
    The bike has the original XT crank - 175mm arms though.
  • 09-17-2012
    skiwi
    In that case, you will already have the correct OSBB cups fitted.
  • 09-17-2012
    GreenLightGo
    No, Shimano spindles are not the same size as Truvativ spindles, hence the requirement for new bearings.
    Bike has XT cranks and I plan to swap in Stylo 1:1s.
  • 09-17-2012
    skiwi
    You're confusing me. They should both have 24mm spindles, unless I'm mistaken about the Stylo 1:1. Are you saying that the Stylo is a 30mm spindle?
  • 09-17-2012
    GreenLightGo
    No, I think the Shimano spindle is bigger.
    http://service.specialized.com/colla...om-Bracket.pdf
    According to the comparability chart, need different BB for SRAM cranks. The 2010 Stumpy expert carbon has an alloy OSBB shell according to the sheet.
    I am 95 percent certain the part I listed is correct, based on the part number match, just looking for the final 5 percent.
  • 09-17-2012
    skiwi
    Sorry - I was confused; I thought that you were talking about an alloy stumpy. The part that you need is this one.
    BTW, the spindle diameter is the same with GXP & Shimano. 24mm.
  • 09-18-2012
    GreenLightGo
    Muchas gracias! Appreciate the help :thumbsup:
    I may be a bit confused on the spindle size as well, always thought the bearing surface on the the Shimano was a different size than the Truvativ which is why they run different BBs, let alone the bearing pre-load process.....
