    Reputation: kmoses's Avatar
    Apr 2005
    Oil leaking from brain shock
    I screwed my pump onto the shock of my epic and a bunch of oil spewed out. Is this normal?
    You are not a beautiful and unique snowflake
    XC Rider
    Reputation: dozerdog's Avatar
    My brain does the same thing, I was told by the guys on this board that this is somewhat normal with Fox.
    same thing happened to me, but it only lasted for one day. Wouldn't hold air. Finally concluded that the tiny stem in the middle of the schrader valve somehow got stuck in an 'open' position, thus allowing oil out and would not hold the air in. At least that what it seemed to me.
    Apr 2005
    Thanks for the responses. It holds air fine. It's just when I hooked my pump up to it the first time. Less came out the second time I hooked the pump up.
