Official Specialized Enduro Thread
681K views 2K replies 441 participants last post by  MTBiker2477
#1 ·
Hi, like the title says, please post your Enduro pictures and build specs! I know there's a 2010 Enduro thread but lets just include every model year in this...
I'll Start,
2011 Specialized Enduro Expert Frame - the only stock item on this bike. Built from the frame up with:
1. Rock Shox Lyrik 2 step 160mm travel with DH damper and Maxle.
2. Monarch Plus Rear Shock - PUSH'ed
3. Mavic 819's laced to King Hubs w/DT Swiss Comp double-butted spokes, alloy nipples. Rear hub w/Fun Bolts
4. XO Shifters and XO Rear Derailleur.
5. Race Face Atlas 175 Crankset with e13 chain guide, bash guard and RF Crank End Caps.
6. Chris King serviceable Bottom Bracket.
7. Cane Creek 110 headset.
8. Thompson Elite seatpost & Specialized Henge 143 saddle.
9. Maxxis Minion EXO 3C 2.5 DHF tires - tubeless.
10. Wipperman Connex chain and SRAM 990 11-34 cassette
11. Syncros Bar - 720mm width/1.5" rise and 60mm/8 degree rise stem.
12. Formula the One Brakeset, 180mm rotors, and Calipers w/Goodridge G* pads
13. Crank Brothers Candy 3 pedals.
32 pounds as shown.:cool:
#1,400 ·
I am almost 6ft (1.83) and I ride a large Enduro 29. In my previous bicycles I never used a seat post with an offset but I find it necessary with the E29. I suppose that it has to do with the seat angle in relation to the need of more clearance due to the big wheels and rear travel.
The problem is that this limits my choice of dropper posts since I need to get one with an offset so a Reverb or a KS Lev is out of the question. Is it just me or do others my size need an offset post as well?
#1,401 ·
Too much offset means your frame is too small, these days with 35mm stems available it's ok to go with that slightly larger frame, but offset still can "fix' a situation where something is too small, it's just not nearly as hard/bad to go to a larger frame size now. That said, the command post has offset. It's what I use.
#1,403 ·
I know this but if I went with the XL frame then the seat tube would have been too high to use any dropper at all. I think that the reason the offset is needed and comes with all stock Speci seat posts is the rather steep seat angle (75) vs other more slack ones. And I think that this happens because of the wagon wheels and the 155 travel that requires more clearance.
Anyway I think that I don't have many options available at this point. It has to be either a Command IR or a KS Dropzone or Eten.
#1,411 ·
Yes for sure. The seat tube is 47cm as in the official site and I have a 60 stem 780 bars combo but in order to get the knee over axle position I need to have my seat quite back.
I will try it again but I think that I can't get the proper riding position without the offset.
The thing is that if you measure the effective top tube without the offset then it is only 60 instead of the stated 61.7. So if you compare this with the 75 seat angle then I don't think that it is strange that I need the offset.
As of the XL I was thinking about it but with the 52 seat tube it would have been almost impossible to fit a dropper. Maybe just a 100mm but still it would exactly on the limit of the colar.
#1,412 ·
I ran a 50mm stem last year on my E29 and felt like a 40 would have been better.. However I'm running a 40 on my 650b this year and feel like I may need to swap it out for a 50.. heh
Been messing around with the bar height and so far nothing feels "normal",
I may have to just set it somewhere and try to get used to it.. I've got two spacers under the 40mm Syntace stem currently, thinking of either flipping the stem over or dropping down another spacer.. Feels like the front tire could be weighted a little more on some loose/sandy trails around here.. (Or do I just go to a 50mm?)
However I found that if the bars are too low, I don't feel nearly as comfortable jumping or descending steeper rock gardens, etc..
Enve DH bars FWIW.
How do you guys have your bar/stem setup?
#1,417 ·
#1,420 ·
Hi guys. I have ordered a Command post IR for my 2015 Specialized Enduro 29 Comp and I am wondering if I will need to change the stock "bat" in order to run the cable internally.
In a picture that I have found online it looks like there is a hole in the bat but I am not sure that my bat has a hole.
I could of course check it myself but I am traveling so I wont have access to my bike for the next 2 weeks so if you could check your bikes and tell me if it is OK or if I should order another bat I would really appreciate it.
Thank you in advance guys.
#1,426 ·
Hi guys. I'm new here and the sport and had a question about a 2007 or 2008 enduro elite I recently purchased. I love the bike and all I really do I trail ride since I'm stuck in fl but I don't really like the rear shock (dhx 4.0) and need some new tires. Do you guys have any upgrade suggestions?
#1,427 ·
Hey guys. I took the plunge and got a Specialized Enduro 29 after years of deciding. Well, I drove 3 and a half hours to get to a shop that had it and got it home only to realize it had a few problems that I didn't notice when I was there. One is the headset moves around no matter how I adjust my stem, spacers, and cap. Video:
The other thing is the rear suspension or shock feels gritty and makes a grinding sound for the sag portion of the travel. Video:
So I'm just wondering if anyone knows if there is a fix for these issues that I can do myself. I don't feel like making another 7 hour trip just to get a bike I haven't even ridden yet serviced...
#1,429 ·
Hey guys. I took the plunge and got a Specialized Enduro 29 after years of deciding. Well, I drove 3 and a half hours to get to a shop that had it and got it home only to realize it had a few problems that I didn't notice when I was there. One is the headset moves around no matter how I adjust my stem, spacers, and cap....
You are either missing the spacer shown in the photo (centre item), or it is not snug down into the top bearing, or is mounted upside-down. It should fit right down into the top bearing. Push it with your fingers even and you will see the steer tube tightens right up.
Circle
It could be that you need an extra spacer ring, but it looks like you have all 3 that comes stock.
Can't tell from video what the issue is with the shock.
For a shop to release the bike like that is SHAMEFUL.
I'd call Specialized and complain that one of their dealers SUCKS!
