Page 47 of 86 FirstFirst ... 37 43 44 45 46 47 48 49 50 51 57 ... LastLast
Results 1,151 to 1,175 of 2130
  1. #1151
    Jun 2013
    Quote Originally Posted by jimw View Post
    The DB coil is a great shock and worthy upgrade.... you'd have to go through a Specialized dealer (the DB has a custom mount for the shock yoke
    That's not my understanding. Cane Creek told me to order part number BAD0612, and that it fits 2013+ Enduros.
    2014 Trek Remedy 8 29er
    2003 Gary Fisher X-Caliber
  2. #1152
    Jun 2012
    Thanks!.....It eliminates the spider and separate chain ring and is just one piece now. Cut out specifically to fit the s-works spider crank arm design. Cuts down the weight.....a little, but looks much cleaner in my opinion and because it is all one piece now it's a little less flexy at the ring.
  3. #1153
    Jun 2012
    Quote Originally Posted by smilinsteve View Post
    Cool bike man.
    What makes the chain ring S-Works specific?
  4. #1154
    Jun 2012
  5. #1155
    Reputation: gosser66's Avatar
    Oct 2010
    @kbjohnson7,
    Weight of bike?
  6. #1156
    Jun 2012
    The way it sits now is 30lbs. With my Nevegals on it, it weighs 27.5 so I'm hoping with some carbon wheels to takes it down around 25ish or less. I'm also looking into doing a 650B conversion to it as well. still really up in the air on that one though.
  7. #1157
    kwa
    kwa is offline
    Jul 2014
    Quote Originally Posted by Billy Mumphry View Post
    If you use the fit finder on the cane creek site the 2013 and 2014 end up showing a different part number.
    I just noticed since I'm trying to sell a brand new #BAD0612 and did some research for a buyer and myself. Small difference but I'm sure it might be enough to cause issues.
  8. #1158
    Commit or eat sh!t
    Reputation: Cable0guy's Avatar
    Quote Originally Posted by kwa View Post
    I am pretty sure BAD0611 is for 2013 and BAD0612 is for 2014 (for 26" bikes). The stroke of the shock is different, so you will either not get full travel or bottom out if you use the wrong shock.
  9. #1159
    Nov 2013
    Hi gang long time lurker first time poster.
    Just thought id throw my experience up on the Cane Creek topic.
    For my 2014 Enduro Evo (fox van r is stock) Cane Creek say the DBCoil to buy was BAD0299.
    Wish i knew that before i brought a s-work version, it fits and works but it isn't right. Its 10mm shorter in length and has 10-15mm less travel.
    Silly me doing zero research
    Changed the head angle and lowered the bb, i guess a 160mm Pike might of balanced the head angle back out but im not sure so back to stock for me.
  10. #1160
    Jun 2013
    Quote Originally Posted by Cable0guy View Post
    I'll double check with cane creek then; this is what they told me when I asked about a 2014 Enduro 29er.
  11. #1161
    Nov 2013
    Gang has anyone tried to make or force your Enduro Evo to climb better.
    Its a large and 26".
    I know lowering weight for me (250lbs) and bike will help but what else, if there are any ideas id dearly like to know.
    Perhaps i have the wrong model for my intentions.
    I will be looking at the 2015 29er SJ's and Enduros thou.
    My Stump Jumper Comp 29er 2013 i should of kept i feel
  12. #1162
    Can the SX Enduro EXo accept a Triple crown fork?
  13. #1163
    Mar 2012
    Official Specialized Enduro Thread
    Quote Originally Posted by Mr Gravity View Post
    I changed out the spongy x-fusion coil fork on mine for a fox talas air. I feel it climbs a lot better and is much more agile in the corners, without any noticeable effects on its dh performance
    Faster rolling tyres will help too
  14. #1164
    I ditched the fox van r coil I was running for a Suntour Durolux RC2 and couldn't be happier. I think the days of coil sprung forks are coming to an end.
    Sent from my SM-G900T using Tapatalk
  15. #1165
    Nov 2013
    I wonder how a Pike 160mm fork would effect the bike.
    I guess it depends in the standing free height.
  16. #1166
    Mar 2012
    My x-fusion was 170mm, I changed to the 160-140mm talas. Did some geometry measuring before and after swapping the fork. The differences were tiny. But the bike is much better to ride
  17. #1167
    Nov 2013
    Quote Originally Posted by Treble View Post
    Thanks for that.
    So it didnt alter the handle bar height to much. I can assume that would make you need to learn more forward.
    I guess its the bottom of grown to axle measurement that matters the most more so then fork travel.
  18. #1168
    Jan 2014
    Hey all!
    I'm looking for a replacement frame for my Specialized S-works Enduro SL 2008, size medium, carbon fiber or aluminum. I would prefer a frame from the same year so I can reuse the other parts. Is there anyone who can give me a tip on an available frame at a good price? Shipping address is Sweden.
    I've been looking at Pinkbike but havn´t found the right frame so far...
  19. #1169
    Dirt Junkie
    Reputation: Rock's Avatar
    Quote Originally Posted by jejzee View Post
    Hey all!
    Ebay?
    How can anyone who's been riding as long as I have, be so slow???
  20. #1170
    Reputation: Napi's Avatar
    Jun 2014
    One short question on the endure COMP...
    The decals, are they covered with the clear coat, or are they "removable"?
  21. #1171
    Jun 2014
    That looks awesome Rock.
    Problem is, I am considering buying a `15 elite 29. And till now, only the black with blue stripes and white letters version "leaked".
    So I wonder if I could remove these decals or would have to order a different version or bike.
    Last edited by Napi; 07-11-2014 at 04:22 AM. Reason: Why is my post above Rock`s post?! Oo
  22. #1172
    Dirt Junkie
    Quote Originally Posted by Napi View Post
    I have a '13 black comp. I have no clear coat on mine. The decals are barely visible, the bike is "murdered out" The decals appear to be on top of the paint, almost like silkscreened on. Since my bike is flat black, I'm not sure how you could remove them except with some sort of solvent. Sounds Risky.
    Attached Thumbnails Attached Thumbnails Official Specialized Enduro Thread-img_0615-1024x765-.jpg
  23. #1173
    Jun 2013
    I could have sworn I saw that both alloy versions are coming in two colors. Hopefully the Elite comes in flat black like the bike above - that looks sick. You could always go with that white Expert Carbon too; what's another thousand bucks, right?
  24. #1174
    Jun 2014
    I don`t really like the white carbon one either.
    When it comes to colors I am a simple man.
    One Color. No contrasts.
    I`d love to buy flat black, flat white or even an entirely green bike, but I really hate these stripes on bikes.
    Carbon is still an option, but I had to rise my "limit" from 3k to 4k already (in Euro), Carbon is just too much. My wife is going to kill me anyways, but If I buy the carbon bike, she`ll torture me first.
  25. #1175
    Jul 2014
    Hi guys, I have a 2012 enduro Evo and have the shock rub issue of the X-Fusion shock. The bike is in great condition for its age and use. Does anyone know if Spesh is still ready to take care of the issue? Also, if anyone with the same issue has pictures of the rub area that would be greatly appreciated to help get my LBS behind me and convince Spesh of the issue
