Page 41 of 46 FirstFirst ... 31373839404142434445 ... LastLast
Results 2,001 to 2,050 of 2252
  1. #2001
    I'm with stupid
    Reputation: hitechredneck's Avatar
    I did.
  2. #2002
    Mar 2016
    Quote Originally Posted by hitechredneck View Post
    I did.
    Thanks, and do you feel better brake power?
    And what kind of clamp do you use for the GX1 shifter?
    I'm with stupid
    Quote Originally Posted by Endu1234 View Post
    I do like it much better. I went all to XT 11 speed at the same time as I did the new XT brakes. I am a shimano shifting and braking fan boy. I use the "pull shift" and the double shift down many times a ride and find I am missing it on sram shifters.
    Sent from my SAMSUNG-SGH-I537 using Tapatalk
  4. #2004
    Jan 2015
    Enduro appreciation
    Had a little bike appreciation ride today. Left my '15 S-Works Enduro 29er for an annual service and took out my old '10 Carbon Expert 26er for a ride. I rode up the cow trail in Laguna and down Peter Paul and Dirky and up Bomber road and down Waimea. Every aspect of the ride was harder from pedal strikes to steep up climbing to the technical decents. I ended up in the bushes after a bail out when I didn't make a rock I thought wouldn't be a problem. What a great testimony to the Enduro.
  5. #2005
    Reputation: Fillet-brazed's Avatar
    Anyone know the pivot bearing sizes for the 2014-15 Enduro?
  6. #2006
    Oct 2015
    Quote Originally Posted by Fillet-brazed View Post
    8st 6802-2rs (15*24*5)
    4st 6801-2rs (12*21*5)
  7. #2007
    Quote Originally Posted by Mikipedia_ View Post
    Awesome! Thanks Mikipedia, exactly what I needed. Pretty common sizes.
    One question, what does the "8st" and 4st" mean?
  8. #2008
    Oct 2015
    Its swedish for 8 pcs and 4 pcs. 😀
  9. #2009
    Reputation: BlueSpruce's Avatar
    Dec 2015
    Shock upgrade for new 2014 Enduro Comp 29er
    Hey guys! So I just picked up a brand new, off the bike shop floor, Enduro Comp 29er at below cost. Did some upgrades (dropper post, XT brakes, praxis one by). Bike makes me go faster and harder than I ever have!
    But I have one major issue still; no matter how much I adjust the rear shock (Fox float RP2) it feels really harsh on moderate sized drops and rock hits. Even when I don't totally bottom out, it feels like I am bottoming out. (Yes, I know this particular shock does not use the entire length of the stanchion, so with all the air out, I have put a piece of electrical tape around the last ~ 15mm or so to know where the true bottom is). I have thrown in various air volume spacers, adjusted rebound, and tried all variations of sag and psi. Without any spacers I was needing about 200psi to not bottom out (I weigh about 160#). I am now running 155psi with the second smallest spacer.
    So my question for you experienced Enduro owners/riders is: Has anyone experienced this and upgraded the shock to say the RockShox Monarch or the new Fox float X2 and experienced your harsh bottom feel change to a bottomless feel? (Sorry if this has been said before; did some searches to no avail.) Thanks for your help in advance!
  10. #2010
    I'm with stupid
    Best thing I ever did was get rid of my fox rear shock on my enduro, second best thing was to get rid of the inline that replaced the fox with the new ohlins air shock sxt22. Bottomless well supported feeling. Custom tuned for weight would be the only thing that would be better but this shock was custom made for this bike. So win win.
  11. #2011
    Aug 2014
    Quote Originally Posted by BlueSpruce View Post
    I'd suggest you try the Avalanche shock upgrade $229 on that Fox before replacing with something much more expensive.
  12. #2012
    Dec 2015
    Hey guys, thanks for the recommendations so far. I should add that I have the ability to get most big name parts at cost, hence the Fox and RockShox questions. But that Avalanche upgrade sounds really interesting, never heard of it before. The Ohlins looks amazing... I will need to see if I can pick that up at cost.
    There are tons of those inline shocks for sale on pinkbike, so I am guessing that they are not as reliable. Thanks so far... keep it coming! I really want this bike to work for me.
  13. #2013
    Knock on wood, I have actually had really good luck with my Inline and enjoy it very much. I have tried the Monarch Plus and Inline back to back and prefer the Inline, although the Monarch is much better than the stock Fox RP23. I wouldn't hesitate to buy an Inline that has had a recent rebuild from Cane Creek.
  14. #2014
    Aug 2014
    Quote Originally Posted by softbatch View Post
    Just noticed if your RP2 has a boostvalve then the upgrade is only $179
  15. #2015
    Mar 2014
    When are they coming out?
  16. #2016
    Dec 2015
    So far it looks like I have the ability to get either the Cane Creek in line or the Rock Shox monarch. Fanderson had some good insight on these two. Anyone else have an opinion on these two, or find one to perform better?
    The Ohlins shock and the Fox float X2 look pretty sweet, but pricey at full MSRP... but not ruling them out yet.
    Part of me worries that the suspension of the Enduro is so linear that it will always feel harsh, no matter how good the shock, so I am afraid to drop several hundred on a new shock. On the other hand, so many really love these bikes, (and they get rave reviews) so maybe it really is the Fox float RP2 making it feel so harsh.
  17. #2017
    Reputation: Mudguard's Avatar
    I guess it depends, I started with the CTD on my 14 E26, then went to a Monarch Plus and finally an Ohlins TTX (Coil). I felt the CTD had to be run too soft to get the small bump compliance I wanted, but then went through it's travel too quickly with no support in the middle. Upping the pressure made the small bump non existent.
    The Monarch Plus was much better, I did not have the model that has the removable can (so you can add volume reducers), but it was still a big improvement, I often left it in full descent mode and rode everywhere like that. I prefer an active shock with lots of sag and am happy to sacrifice pedaling efficiency.
    The Ohlins was another step up, the back of the bike is glued to the ground. But it is costly, so much so I probably have should bought the Evo frame. However I have not tried the air version.
    I would consider getting your original shock revalved for you weight and riding style first, or go straight to the Monarch and do the same thing.
    Maybe try ride another Enduro with the different shocks.
  18. #2018
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Custom tune is almost always better than any off-the-shelf suspension products. I would say "always", but I should leave some leeway there. Still, I'd take an older Avy or Avy tuned shock than any "latest and greatest", because most everything can not match what you get from these custom tuned shocks. You have to realize that they have to valve the OEM stuff so a 240lb rider won't blow it it apart and so it still uses travel for a 140lb rider. You simply can't tune across such a vast range effectively without modifying internals. For best performance, a custom tune is the way to go. Then the orifices are sized to the fluid flow required to you and the forces, the shims or valves are specifically tuned for your weight, and so on. For people that haven't experienced it, it's basically having your cake and eating it too, in terms of firm low-speed compression that doesn't dip dive and bob everywhere and high speed that will seemlessly and quickly blow off to absorb sharp impacts without spiking.
    It really pisses me off that the "descend" modes with pretty much all OEM shocks basically leave the low-speed compression wide open so you have no low-speed support, so your bike chassis dives all over the place with every bump, doesn't resist g-outs as well, and so on. They just don't get it for the most part and you always have to sacrifice this to get any decent high speed/sharp edged bump absorption, making the "trail" or "middle" compression setting annoying due to the harsh travel.
  19. #2019
    I may be dumb here, but I can't seem to find the page on the Spesh site that contained the manuals for the bikes? Looks like they've redesigned the site (and it's terrible)
    I'm trying to find the link to the exploded frame diagram for a 2016 650b Enduro Elite. Hub bearings are knackered and was hoping to find the IDs and order them first rather than having to take the bearings out to find the IDs
    Can anyone help?
  20. #2020
    Which hub? Front or rear? If it's the rear it's probably a DT Swiss 350 rear hub, in which case bearings should be easy to look up.
    Scratch that, that was the 2015 model. Looks like the 16's have a HiLo hub which is probably a Formula hub, in which case I've no idea. I've got one sitting at home, but am away from work so it will be faster for you to look up!
  21. #2021
    '16 Elite's have DT 360 internals in the rear hub.
  22. #2022
    Jan 2014
    I might be alone, but I run the stock Float CTD on my S-Works Enduro.
    The DB Air was obviously not reliable and left me walking a couple of times. Same with the DB Inline. The RS Debonair is all wrong for the Enduro. The X2 was not available yet, so I purchased a stock Float CTD from Spesh and had Push tune it.
    The Push tuned CTD has been by far the best shock, even better than the DB Air when it was working.
    I will also try the X2 if they make one for the Enduro with the dual position lever.
    I don't know why so many people like the Debonair, the air volume is just too much for the Enduro's high leverage ratio. There is a reason RS puts all 9 reducers in it out of the box, and it is still to much volume. Look at the smaller can Spech specs on the monarch equipped bikes. There is also a reason Fox and Spech spec'd the smallest air can for the CTD. Additionally, look at Vorsprung, they had to make a special, smaller, Corset specifically for the Enduro.
    The fact is, the Enduro's leverage ratio works best with a small volume can. People are really jacking up their spring curve on the Enduro. Lighter riders may get away with it but would be better off getting revalved to improve damping, not jacking with the spring. Heavier riders will have real trouble with higher volume cans.
    But high volume cans are all the rage right now. They make every bike better, right?........Right?
  23. #2023
    I'm with stupid
    Look at the Ohlins STX22 it also has a small air can. I really dig that shock. Plus knowing it was made by a top tier suspension company for the enduro specifically tells me it is about as close as you can get to perfection. I am right in that 160-180lb window that suspension companies tune the one size fits all valving for. I have run a few PUSH rear shocks and the ohlins is interchangeable with them in the performance.
  24. #2024
    Reputation: titusquasi's Avatar
    Where can you buy the Ohlins shock and what is the price?
  25. #2025
    JCL
    JCL is offline
    Quote Originally Posted by projekZERO View Post
    This guys gets it.
    I run the Monarch Plus with the high volume can (not the Debonair) and I can just get away with it and I'm only 150lbs. How some heavier guys run the Debonair makes no sense to me. They must be running 250psi and 10% sag.
  26. #2026
    Dec 2015
    This is some really valuable insight! Maybe I will send my shock to Push, since it is here in CO and the shipping time will be quick (don't want to be without a shock and bike for too long).
    Looks like the Push tune will be about $220 and I could pick up a Monarch for around $300. Part of me want to "upgrade" to the Monarch, and then have the Fox float as a back up. Not sure I can get the X2 at cost, so that makes it pretty pricey for a gamble.
    Thanks everyone for the input so far, hope to have the shock sorted out in the next month. Any additional opinions are greatly appreciated!
  27. #2027
    Apr 2015
    I have played around a lot both with the Pike and the Monarch Plus Debonair and once set up properly they ride really well. More specifically about the Debonair if you run a little more sag (around 32-35%) and speed up the rebound it seems to perform so much better because the first part of the travel is really active and then the 9 bands provide could mid stroke support and ramp up towards the end of the travel.
    You can find more details here Enduro 29 suspension setup
  28. #2028
    Nov 2013
    I agree. Monarch plus debonair is far better than the stock Fox. You need to set it up properly. I think or in my case, I am 200 lb, need 7-8 tokens and 30% sag or a bit more. Then, works well.
    I can see here people not happy with CCDB CS, I thought it was the best option for Enduro 29. Well, now almost in my area along with Ohlins
    Inline definitely doesn't work with this frame. Almost all are broken and replaced for Monarch plus debonair. People aren't satisfied with Specialized because Inline costs more than Monarch plus and has more adjustments.
    For me Inline is a step forward.
  29. #2029
    Aug 2014
    My Avy tuned Monarch Debonair is the bees knees . Supple yet supportive. 30% sag in the attack position.
  30. #2030
    Jan 2014
    Quote Originally Posted by Tabby View Post
    I am really not trying to start a debate, so please just take this as my opinion.
    I also weigh 200 lbs and had a debonair. The shock certainly "feels" plush but the spring is all wrong.
    The fact that 3 posters in a row said they run their debonair at 30% + sag just proves (to me), that your shocks really are not setup correctly.
    The E29s leverage ration is REALLY high in its initial travel. By default the suspension wants to be supple in its initial travel because any input is increased greatly as it is transferred to the shock. The ratio flattens out in the mid stroke before it really falls away at the end of the stroke to provide a lot of bottom out resistance.
    So without the shock in mind you have a suspension that wants to be supple initially, firm up for mid stroke support, then really firm up at the end for bottom out prevention.
    So what you've done is put a large negative air spring which makes the shock VERY easy to initiate its initial travel. So now you have an suspension that has a high leverage ratio that will take a small input and amplify to the shock, and you made your shock not resist any initial travel.
    You've compounded what the suspension is trying to do and now you have nearly no support in the initial travel. Basically you have taken spring out of it to make it supple. That is not always ideal, and in this case, is certainly not ideal.
    That is why you get 30%+ unless you jack up the air pressure and make the rest of the stroke stupid harsh.
    So you end up with what you think is supple in the initial stroke but really is just way under sprung (not under damped). The shock cant even hold you up which is why you have high sag. The mid stroke will also feel like it blows through since you lowered the pressure. In order to combat this you speed up rebound (3rd poster). I know exactly what you guys are feeling and why you set up the debonair the way you did because I went through it all too. What you feel is supple is all wrong. Sure it smooths those rock gardens and braking bumps, but I promise you are loosing grip big time.
    My Push tuned shock runs about 23% sag and is just as supple in the initial stroke as the debonair ever was. That's because I'm not sagged all the way through its initial travel and I am allowing that initial leverage ratio do the work. Getting the shock damped right allows me to run the proper "spring" so I get the support I need from the shock. This is easy to do by setting up the shims right (such as staggering the shims to allow a little bleed on small bumps). The biggest difference I can tell you is my Push tuned fox has gobs more traction because my rear wheel is tracking much better, not just "floating" over everything and blowing through travel to easily.
    There is a fine line between harsh and under damped or under sprung. With the debonair I was easily under sprung and the wheel just floated.
    That's not the kind of "plush" I want.
    I know you guys would be amazed if you actually had a properly sprung and damped shock on those bikes.
  31. #2031
    Jan 2014
    I am very interested in the STX22. I can get a pretty decent discount on it, but I am hesitant to try it out. I've already spent way to much coin trying to get a shock I like on the E29. I finally found something I am happy with so we will see.
    The X2 has gotten very good feedback and with its similarity to the DB Air all it needs it small improvements and a lot better reliability. Plus I get Fox stuff stupid cheap through our club so the X2 is cheap for me. Like I mentioned before. I will buy it if they add the dual position switch to it.
    On the negative, I have ran into a couple riders who are not happy with their STX22 on their 16 Enduros. Also, my Spech dealer said they are not getting good feedback. I see of a lot of STX22s for sale on Pinkbike and I reached out to a couple of them and they weren't happy with them either and are running X2s.
    I would like to see more feedback on it and hopefully I will get a chance to try one first.
    On the flip side. I have heard really good things about the RXF fork from Ohlins, so it seems like that is definitely more of a hit than the STX22 so far.
  32. #2032
    Dec 2008
    Quote Originally Posted by coolatt View Post
    Can anyone with a 1x setup on their Enduro please tell me what brand and offset chainring you are running.
    The lbs sold me a RaceFace NW direct mount with what I believe is a 6mm offset to go on my Sram S2200 cranks. When mounted the teeth are about 1/2mm from contacting the chainstay and the chain rubs the chain guide even though the guide is flush against the frame.
    I think I need a zero offset chainring?
    On my brand new E29 Expert Carbon with the Sram crank is installed a 28t with 6mm offset
  33. #2033
    Apr 2015
    One again regarding both the Debonair and the Pike that I have in my Enduro I think that once they are setup properly they perform great. Having said that what is a proper setup of me may not be for you. For example many people also run 20% sag in their Pikes and I run 30%. Does this mean that the Pike isn't good? Same thing about the Debonair. Specialized suggests 30% and I run 32.5-35% sag but honestly I never runned less than that in any of my bikes or my shocks.
    Bottom line I don't understand why people get so crazy about the Enduro leverage rate because I don't think that is extreme at all especially for the 29. My Reign SX had a much more extreme leverage ratio than this and I didn't have any problems as well. And honestly since we have thoroughly analyzed this in the other thread I don't want to repeat myself.
    The beauty of the new gen shocks and forks is that you can adjust them by using rubber bands and tokens so they only thing that you need is time to experiment. Personally it took me more time to set up my Enduro properly but I think that it was time well spent.
    Are there any better shocks than the Debonair? Of course there are but is you spent time understanding how it works and adjust it to your riding style you will be pleasantly surprised.
  34. #2034
    I'm with stupid
    Really? The TTX is all over the place, there is exactly zero stx for sale right now on pink bike so its not like they are getting unloaded like the inlines. I would not run a X2 on my enduro without 2 things a smaller air chamber and a climb switch. The FSR are desperate need of both. Maybe the folks you talked with like a pillow bike (which the stx is not). What were their complaints? Were they rider opinions that you value and trust or just random folks? I have tried 4 shocks on my enduro and this is the only one that works closest to right for me. I have let others ride the bike and really like the rear shock as well. But please do not take my word or any of the others on pinkbike that try to sell one and ride one. Its a amazing shock if you ride agressively, if you just putz along and want a pillow shock then it might not be the one for you. But for me pillow shocks blow thru travel and bottom out fast or you use so many bands they become spikey. To each their own.
  35. #2035
    Dec 2015
    Just want to commend everyone so far on there great feedback regarding rear shock options. I know I pretty much set us up for a debate by asking: what is the best shock option for the Enduro? This is all going to be opinion that is directed by riding style and terrain, which is hard to duplicate.
    Ahhh, still haven't made up my mind, but you guys are really helping me narrow things down! And at the very least, one thing seems to be decided; I now know my ride can be vastly improved by a custom tune of my current shock if I don't go for a new "upgrade."
  36. #2036
    Mar 2014
    I'm hoping the enduro makes an appearance in Ireland!
  37. #2037
    Dec 2015
    Just went to the Push website to try and order a tune and looks like they don't work on Evolution series or non boost valve shocks. So I am out of luck.
    What year was your fox float CTD that you where able to get it push tuned?
  38. #2038
    Jun 2013
    Quote Originally Posted by Vermonter802 View Post
    I heard rumors too, but Jared Graves said it's not happening.
    2014 Trek Remedy 8 29er
    2003 Gary Fisher X-Caliber
  39. #2039
    Aug 2014
    Avalanche is the only guys I know of that are doing the Evo shocks.
  40. #2040
    Nov 2013
    Official Specialized Enduro Thread
    Last year in Ireland, Specialized riders were running the Stumpy. Stuff there,isn't too demanding and most riders are using trail-All mountain class bikes. So, I don't think we can see new enduro,or who knows
  41. #2041
    I have been going through a few forums here and especially noted what gpgalanis, hitechredneck, projekZERO, JCL are saying
    Here is my experience so far
    2016 650b Enduro
    Rider weight 180lb
    Rode the STXAir for about 5-6 rides. I was running 5 clicks of low speed, the second setting of high speed comp, 3 clicks of rebound. I started out with 33% sag measured while seated, about 170psi on my pump. I found the shock had great damping initially, really good grip and controlled, specifically for technical climbing. It felt like it was riding high in the travel as I did not experience any pedal strikes that I previously encountered but I did notice that I used almost all the travel on the climbs. I did not fins responding well on the downhill. I adjusted the rebound faster and slower, backed off the low speed and high speed comp but it just seemed harsh on repetitive bumps and did not feel like it absorbed big hits at all. The bike felt like a 150mm travel frame.
    I then bumped up the pressure to 180psi, about 30% sag seated. The climbing was about the same. I still seemed to be using a lot of travel on techy climbs. It did feel better (but not great) going down, specially when I backed off the low speed comp. Still, it does not feel like a long travel frame. The shock used about the same amount of travel as the lower pressure.
    Lastly I threw on a Monarch Plus Debonair. This shock came off my previous 2014 26" Enduro. I had to have the travel reduced from 63mm to 57mm. I was told that the adjustment included an internal spacer that reduced the air volume a bit, but I haven't opened it up to confirm. Just for the hell of it, and because of these posts I wanted to reduce the air volume as much as possible. I put 8 bands in the positive side. I needed 230psi for 30% sag. Again, for the hell of it I put in an additional 4 bands in the negative side, airing it up I was able to drop down the pressure to 210psi for 30% sag. I then went for a ride.
    Just like when this shock was at full volume on the 26" Enduro , the climbing was just ok, not great. I find the Monarch a bit to out of control on techy climbing. It seems to be not very supple.. or maybe spiky is the word. It also feels like it is sagging more overall compared the STX as I experience a couple pedal strikes, but used less travel overall. On the way down though it felt great. There was really good absorbtion on all sizes of bumps and it felt very supportive. I never came close to using all the travel, I bet there was 15mm of stroke left. It seemed to work in the middle of it's travel most of the time.The unused travel doesn't bother me if the used travel is supporting me well.
    Next I am going to remove a few bands on the positive side and see how it feels.
    I'd like to know how you guys with the STX Air have it set up. I would really like the STX to perform on the downhill the way the Monarch did the other day. I'm wondering if I should increase the pressure on the STX even more or look for a volume reducer to ramp it up midstroke and endstroke.
    JCL Where did you pick up the smaller monarch air can?
  42. #2042
    JCL
    JCL is offline
    From my local shop.
    Monarch Plus HV 216mm x 57mm Aircan. It comes without a decal BTW.
  43. #2043
    Jan 2014
    Not true at all.
    Push does do evolution series shocks and forks, they just haven't updated the website. It involves replacing the internals out completely so you are left with essentially a factory series damper.
    So far, I am the only person who has had the stock evolution series shock "Pushed" for the E29. This is according to Matt, who did my tune. I am having a FOX 36 fork tuned now so I asked Matt again.
    I also have a kashima shock body on mine. Many people don't know this, but fox made a limited number of kashima shock bodies for the enduro strut mount. Fox never made an entire shock except the X2. You can buy a Float X or regular Float and then buy the kashima shock body and build your own shock. The shock body retails for $50. They only have 6 or 7 left when I bought mine and they said they will not be making any more of them. This is how you see a few Float X's on E29s
    FYI, the stock evo shock is a custom air sleeve. Fox doesn't normally make a standard sleeve (SV) in the 8.5X2.50 length. You will have to buy either a XV or XL sleeve (XL sleeve only for Float X) if you don't buy the stock shock from Specialized. If you buy the XL sleeve you will need to notch the larger eyelet as it may interfere with the enduro's frame. This is the reason Fox never made a float series shock for our bike. You can build a regular float with a XV sleeve and Regular eyelet without clearance issues.
    I can't remember the full part number for the shock body, but call Fox and they will get it for you. It is 207-10-XXX (can't remember the last 3 digits).
  44. #2044
    Jan 2014
    It's just their opinion to me at this point. I have no opinion myself. I didn't know these riders or their skill level in evaluating a shock. I found 4 sold on Pinkbike and contacted all of them -Two responded.
    I am still very interested in trying the STX22, I just want to try it first before I commit. I also want to try the X2.
    Now that I am happy with my Push tuned Float. I want to ride these shocks before I commit.
  45. #2045
    Jan 2014
    They do work on the evolution shocks, they just haven't updated the website. You will have to contact them via phone or email. They always answer the phone.
    Please see my more detailed post above.
  46. #2046
    Someone had talked about pressfit BB's dying and how the Enduro is a bit of a water trap , so I pulled my chain off and noticed that my cranks were very fast to stop spinning. Popped them off and sure enough, I had some pooh brown looking bearings. Stuffed a little fresh grease in there and reassembled, then ordered a new bottom bracket from Shockcraft.co.nz
    I ordered the stainless ball bearing option, with the storm drains. On my 2014 E26, there is nowhere for the water to go. There's no drain hole in my BB shell, and there's plenty of places for it to get in, headset, seat tube and even the top tube as it's got a large hole for a stealth post I guess (though mine runs in front of the BB).
    I'll pull the old bearings apart shortly for a mosey, but holy hell, the cranks spin fast now. Makes me wonder what the ceramic version would be like.
    New BB Shockcraft by Chazz Michael Michaels, on Flickr
  47. #2047
    Jun 2012
    New question here. 27.5+ tires on E29 thoughts?
    This guy seems to love 27.5+ on an E29, more on that here. These guys too.
    The first guy says 3" won't fit but a 2.8" WTB Trailblazer fits fine. I'm curious which plus tires people have tried on the E29, what rim widths, and overall pros/cons about this setup. Thanks!
  48. #2048
    Interesting comments on the shock options and experiences. I have a 2011 Sworks with the stock RP23. Can't say that I can fault it - I use all the travel quite regularly but only one harsh bottom out so far. Added a little more air ( about 170psi) and it rides a tad higher and feels better pedaling uphill. I use the pedal position for climbing and the open setting with 2 on compression damping.
    My main gripe with the bike is the tapping noise I get when pedaling. I have checked headset, BB, pedals, crank, chainring bolts and suspension pivot tightness. All check out fine. Frame is old stock bought new less than a year ago. Pivots are quiet when the suspension is cycled with the shock unbolted. Noise only happens when pedaling as opposed to standing descents or just bouncing on the suspension. The noise starts out softly but gets worse as the ride progresses.
    Any ideas?
  49. #2049
    Saddle?
  50. #2050
    Jul 2015
    Nobby Nic 2.8 fits no problem. You can fit 3.0 if you get creative or spend $$$$
