Page 14 of 46 FirstFirst ... 410111213141516171824 ... LastLast
Results 651 to 700 of 2274
  1. #651
    Reputation: jimw's Avatar
    Quote Originally Posted by retrofred View Post
    Oh and in regards to putting a Ti spring on an Enduro, it would contact the frame amd rub due to clearance between the shock and the frame.
    Yep, that's exactly what happened to me. I have a 2012 Enduro Expert Evo. I picked up a Nukeproof Ti spring from Chain Reaction. Installed it and it seemed to fit, when unloaded. Riding around the street and doing some bunny hops it seemed fine too. But on the trail, towards the end of the ride I started hearing some horrendous creaking *sometimes*. It was the coil scraping the frame. Scratched off the paint a bit but otherwise no big deal, but of course I immediately swapped the coil back out. The Ti spring was a bit larger diameter, which like I said *should* clear the frame normally, but the clearance was so tight that when the coil shifted (there's a slight bit of play in the ID so that you can grab the coil and push/pull it a bit perpendicular to the long axis of the shock), it would rub the frame. Just like the Vector coil did on the regular Enduro frames, causing the warranty issue mentioned previously.
    So, no Ti for me unless someone comes out with one that has ID/OD that exactly matches the Fox one. Plus, for a spring that short it turned out that the weight difference was hardly worth it. On my old Demo 9, the Ti spring saved 1/2 pound, but on this bike it was less than 1/4 lb I think.
    On an unrelated note... is anyone else having issues with the headset on these frames developing a horrendous creak? I took mine apart after a few rides and found galling on the "slip fit adapter" that goes into the lower part of the head tube, above the lower bearing, and on the inside of the lower head tube itself. Basically exactly what was reported in this other thread. I've taken it apart a few times now, cleaned it up with steel wool, and a few rides later it's just as bad again. Some people seem to have had success with loctite-ing that adapter in there, and possibly the bearing too, but that seems like a band-aid on a bad design. I mean, I got this bike because it's supposed to be able to be ridden hard. Maybe I'll post up some pics when I get a chance, but was wondering if anyone else has run into this.
    Related to that, I've also had the crown on the Fox Van develop creaking now within a matter of a couple weeks in 2 cases now (already sent in for warranty twice). Is it me or is that just the price of having a single crown fork on a bike supposedly designed for light duty DH?
    I love this bike otherwise, it's just that random creaks drive me nuts.
  2. #652
    Quote Originally Posted by jimw View Post
    I've noticed a creaking sound a couple of months ago and traced to the headset. I've then disassembled the headset and putted a cooper based antiseize compound between the frame and the cups and the creak stoped. I recall I've found it odd that the tolerances seemed to be a litlle on the loose side of tight, but didn't pay much atention.
    The funny thing is today, in my saturday ride, I've noticed the creaking has come back...
    Cheers
  3. #653
    Remember to put grease, oil or loctite depending on the bolts before you screw them in. Because the parts are alloy or aluminum and are not the same grade metal as the bolts. When you apply pressure it creates heat and the two metals react differently at different temperatures giving you that creaking noise. The oil or grease helps a lot and depending on the bolt's location even loctite.
    08 Enduro: '12 Van RC2, Push DHX 5 coil, Flow EX, Hope m4, 750mm bar, Blacklite Post.
    Website
    http://all-mtn.com/
  4. #654
    Dec 2011
    Im 178cm tall without shoes,32 inseam. What size frame should i be looking at L or M - Will be a do all bike with long XC days and a bit of DH / AM riding .
    Quote Originally Posted by SMILER View Post
    I'm 180 and the 2010 L frame suits me perfectly. I use a supershort 50mm stem and still have a comfortable cockpit.
    Cheers
  6. #656
    It seems like their sizes got a lot larger a few years back. I'm almost exactly your size (just over 180, same inseam). I rode a L 2004 Enduro with a 50mm stem that fit perfectly. Tried out 2011/2012 Enduros, and L was waaaay bigger, even swapping out for a 50mm stem. I ended up with a 2012 Enduro Evo Expert w/50mm stem and it feels perfect.
  7. #657
    Dec 2011
    You on a medium now then jim?
    Im looking at a 2011 / 2012 frame myself.
    I used to ride a medium 2008 enduro which i sold and bought a large but it was massive.
    Medium was pretty much spot on, but the 2008 was more of a long travel XC bike rather than an AM bike.
  8. #658
    Exactly. Sorry I didn't clarify that, I bought the size M 2012 Enduro Evo. It came with a 60mm stem, which was fine, but feels even better with 50mm to me. I agree, size L to me feels way stretched out and more XC. I'm more AM/DH oriented, but do my share of climbing too, and this size feels perfect to me.
  9. #659
    Reputation: Enduro4710's Avatar
    Just Wanted to pust up my new baby in here... took her out for a couple of rides yesterday and she is sooooooo damn plush!!
    Attached Thumbnails Attached Thumbnails Official Specialized Enduro Thread-imag0295.jpg
    2013 Specialized Endruo Expert Carbon
  10. #660
    Me too. Feel that my 2011 medium enduro is larger and required me to stretch more.
    I trimmed my handlebar to 700mm to fit in better as I don't want to spend additional money
  11. #661
    Quote Originally Posted by Enduro4710 View Post
    l love the color of that Enduro
    Sent from my SGH-T889 using Tapatalk 2
  12. #662
    Is time for a new yr resolution for ur biking style
    These are mine :P
    1. Change to single chainring like 32-34
    2. Hopefully some companies like CCDB give us more options on the shock
    3. RIDE MORE !!
  13. #663
    aka...appBLING72
    Reputation: aappling72's Avatar
    Love that look. I have the sworks frame only in red/black coming. Was hoping to see it by now. Should be here by the end of the year. When did your arrive and where are you located?
    How does the new kinematics feel on pedaling and still maintain that great spechy plushness?
  14. #664
    THAT guy
    Reputation: TRY2KPUP's Avatar
    Aug 2010
    I used to have this problem when mine was new. Every time it was from my stem/star nut being loose.My theory is that the carbon fiber spacers "compress", thus cuasing everything to losen up. But after abouth the 4th time of retightening everything, it hasn't been an issue since. Just make sure that star nut is nice and tight before tightening the stem bolts.
    My headset did the same thing as yours and others in the thread you posted. But it hasn't gotten any worse in the last 2 years of heavy abuse. I do however use plenty of greas between everything when I rebuild it about every 5-6 months.
    Bikes:
    2010 Spec Enduro comp.
    2013 Specialized Demo 8 (build)
  15. #665
    Very nice ride!...
    Is that the stock Fox 34? Did you like it?
  16. #666
    Reputation: tsefreeflow's Avatar
    Very nice, still waiting on mine to come in. Cannot wait
    Tie two birds together and though they have four wings, they cannot fly!
  17. #667
    Nov 2012
    awesome! my 2013 sworks should be ready tomorrow - cant wait!
  18. #668
    Quote Originally Posted by NevB View Post
    Where are you from & what color did you order? The last I was told was end of dec. for the red & end of jan. for the blue.
  19. #669
    Anyone notice that the Enduro Evo is back on the US site?
    Specialized Bicycle Components
  20. #670
    Stinking double post
  21. #671
    Jun 2010
    I noticed, and I also noticed that they have the price of them now along with both color options. Before they were only showing the Matte black. Can't wait to see one in person. Been going back and forth on the Evo and the Comp. Comp looks nice in person so we will have see????
  22. #672
    I think I'll be leaning towards the comp. I was looking at the Stump Evo but the Enduro Comp has a bit more travel and a little bit bigger fork. I think the Enduro Evo is a little too slack for a Do Everything bike.
  23. #673
    2013 Comps do look nice.
    Funny thing, in the US site the Comps are red or black (very nice!) and in the portuguese site the only colour for the Comp is white. Much prefer the stealth black colour...
  24. #674
    Executive User - UK
    Nov 2008
    Those new Enduro's look awesome. Keep the pics coming.....
  25. #675
    Executive User - UK
    Nov 2008
    New Enduros look awesome - keep the pics coming guys!
  26. #676
    I'd love to see a white one in the US personally.
  27. #677
  28. #678
    May 2012
    2010 Specialized Enduro Freeride
    This is my 2010 XL Specialized Enduro Expert. The front fork is a Rockshox Totem 180mm travel Solo air with the DH damper. It also has red Azonic Outlaws. The bike also has a xfusion vector R shock with custom frabricated clavices to stiffen the rear end. Sram XO drivtrain and Avid elixir cr brakes. Specialized command post as well.
    Attached Thumbnails Attached Thumbnails Official Specialized Enduro Thread-2012-12-15-13.28.52.jpg
    Official Specialized Enduro Thread-664707_4542755660264_1699049216_o%5B1%5D.jpg
  29. #679
    ^ Nice. You should look into wider bars next.
    Website
    http://all-mtn.com/
  30. #680
    May 2012
    Quote Originally Posted by camarosam View Post
    Thats exactly what im looking at. Im looking at red deity dirty30 bars. Going from the stock 680mm to the 760mm of the deitys will be nice!
  31. #681
    Feb 2006
    Pics look like you have this bearing problem...
  32. #682
    May 2012
    Quote Originally Posted by mantra View Post
    Well, I DID, until i fabbed those clavices. Those braced clavices make it super solid!
  33. #683
    Quote Originally Posted by aappling72 View Post
    dude! you won't be dissappointed mine arrived on monday but was expected to be here on 30th of dec, but hey it was an awesome surprise it coming early! i'm located in sydney so pretty much the rest of aus should be getting theirs now too. new kinematics are great tho man, better than the older enduro's (i had last years comp) but it still feels like a super plush mini dh bike going down!! haha
  34. #684
    Quote Originally Posted by tugamik View Post
    Very nice ride!...
    cheers dude! it is the 34 though, and it feels great!! it is definately not a let down having the thinner stanchions on there
  35. #685
    Quote Originally Posted by tsefreeflow View Post
    wicked dude! it's such a sweet ride
  36. #686
    I have yet to be disappointed with my Enduro
    Sent from my GT-N7105 using Tapatalk 2
  37. #687
    ... and if we just ...
    +1
    Always return with a smile from every ride
  38. #688
    May 2012
    I feel ya! My azonic outlaws failed before my bike did!
  39. #689
    Quote Originally Posted by Gawdodirt View Post
    Nice fix!!! Is that 3/16" plate? Will have to keep that in mind if mine starts to do that! Got the same link and shock but haven't ridden them yet. Keep us posted on how it works out!
  40. #690
    May 2012
    Quote Originally Posted by Bajatoy View Post
    It works phenominally! The bike feels tons stiffer! I landed and busted a rear spoke on my azonic outlaws. Absolutely no flex from the rear and im 6'4" 220lbs without gear!
  41. #691
    Sweet! I'm about the same size, lol 6'3" 230! I will have to see how the stock link holds up! Lol
  42. #692
    May 2012
    Let me know how it works out. It only happened to me on drops. If you need the modification done just let me know!
  43. #693
    And now for something completely different.. Do you guys know the chain growth on the 2012 Enduros? I am thinking of getting (actually, I bought it already) an X-9 Type 2 short cage derailleur for my 1x10 setup (32 front, 11-36 back) and I'm wondering if everything will be ok on the trail... I heard that chain growth is something I should consider, and it's the greatest around the proper sag position (25-30% of travel) rather than when in full travel. Can anyone confirm/elaborate on this?
  44. #694
    No problem with your configuration !
  45. #695
    Thanks, and do you know how many links should I add when I switch to 34 tooth front? Will one full link do?
  46. #696
    Just release the air from your shock and check the chain when the suspension ist fully compressed.
  47. #697
    Dec 2012
    Quote Originally Posted by gnriden View Post
    I see you have bought yourself a 2013 enduro comp. How well does it climb and handle tight switchbacks on single track?
    Coming from a 13kg (28lbs) xc bike and would like to know if it can handle xc besides the all mountain purpose.
  48. #698
    Reputation: rufflesurf's Avatar
    my 2011 enduro evo
    Attached Thumbnails Attached Thumbnails Official Specialized Enduro Thread-imgp0094.jpg
  49. #699
    my 2011 enduro evo on a local welsh trail
    Attached Thumbnails Attached Thumbnails Official Specialized Enduro Thread-imgp0087.jpg
  50. #700
    evo in switzerland
    Attached Thumbnails Attached Thumbnails Official Specialized Enduro Thread-imgp1202.jpg
