Page 54 of 90 FirstFirst ... 44450515253545556575864 ... LastLast
Results 2,651 to 2,700 of 4482
  1. #2651
    Reputation: sml-2727's Avatar
    Nov 2013
    A little help please
    Anyone who owns a 2013 camper comp and still has the stock alixir brakes, can you please take a picture of the rear caliber, I took mine off and im not sure if im puting the bolts in the right place.
    thanks
  2. #2652
    No talent hack
    Hope it helps.
    2013 Specialized Camber Comp
    2014 Trek Domane 4.0
    2015 Surly Karate Monkey Ops (the commuter)
  3. #2653
    Reputation: jhtopilko's Avatar
    Oct 2012
    I have a triad 2 that leaked out of the pro pedal lever hole. I feel that a rebuild is my best option. I don't know that a ctd with trail adjust will be worth the money.
    2014 Norco range 7.1. Avalanche F34 RP23 with push Factory tune by suspensionwerx.
  4. #2654
    Nov 2013
    Quote Originally Posted by Knight511 View Post
    Hope it helps.
    Hey thanks, with a little tinkering I figured it out, I had the two big black spaces in the wrong spot and was getting some major rubbing.
  5. #2655
    Reputation: Primalspy's Avatar
    Jul 2014
    Hello. Is that some type of cable guard I see on the front down-tube?
    I just ordered a 2014 Camber Comp. Should I be concerned the derailer cables are exposed? Paul
  6. #2656
    No talent hack
    You should be concerned if the cables/hoses are fit too tight to the frame. The cable/hose will rub through the aluminum if it is in contact with the frame. No worries and no problems with the properly installed cables/hoses.
  7. #2657
    Jul 2014
    Thank you Knight! I went for the Camber Comp because it was within my budget @ 1999.00. It was between that or the Trek Fuel 7 29er @ 2499.99. What I liked about the Trek is that it had internally routed cables & it did have Fox Evolution shocks. I hope that I made the right decision by going with the Camber Comp. In their beautiful red color.
  8. #2658
    Does NOT know it all!
    Reputation: matuchi's Avatar
    Quote Originally Posted by Primalspy View Post
    My buddy is looking at Cambers - where did you get a Comp for $1,999?
  9. #2659
    Jul 2014
    Quote Originally Posted by matuchi View Post
    Hi Matuchi! I ordered mine in person at bicyclesportshop.com in Austin, Tx. $1,999 + tax. I put it on lay-away. They require half down, in case you're interested. They also have the Camber Comp Evo on sale for $2899.00. They have them in stock.
  10. #2660
    Thanks for the heads-up! I'm in California so I won't be able to take advantage of their offer. I bought a 2014 Camber Comp Carbon last month and my ridding buddy has ridden it a few times and is now looking at getting a Camber too. I'm trying to talk him into skipping the entry level Camber and go for the Comp. I hope you enjoy your new bike - I sure love mine!
  11. #2661
    Jul 2014
    Good job!
    Cool! I am just getting back into it after 10 years & I'm coming from an old entry level Kona hard tail so the Camber Comp is like WAY more bike than what I'm used to. I think I'll be good for a while. Local retailers aren't selling the Comp as low as 1999? I know it retails for 2600 & that's why I went for it. Enjoy your ride!
  12. #2662
    Oct 2012
    Tuned kashima RP23 on the way, can't wait to get it on. I'm looking for quite a change vs. My triad
  13. #2663
    Cool! I am just getting back into it after 10 years & I'm coming from an old entry level Kona hard tail so the Camber Camp is like WAY more bike than what I'm used to. I think I'll be good for a while. Local retailers aren't selling the Comp as low as 1999? I know it retails for 2600 & that's why I went for it. Enjoy your ride!
    The local shop that carries Specialized has the Comp for $2,399 and the Camber for $1,699 and my buddy likes the $700 cheaper one at the moment. I haven't ridden for a long time and gave my 1996 StumperJumper M2 FS Comp to my son and picked up my new bike. Enjoy your ride!
  14. #2664
    Nov 2013
    There is a dealer near me (Pittsburgh) that still has 2013 camber comps in stock and are selling them for 2,000 bike shop is called dirty harry's Dirty Harry's Verona Pa, Trek, Specialized, Santa Cruz, Niner, Pittsburgh , there actually spec'd better than the 14's and now with the 15's coming out they might lower them a little more.
  15. #2665
    Jun 2014
    Creaky Camber
    My camber has just started to creak intermittently.
    It creaks most when pedaling over uneven terrain (when the suspension is actually doing work) - it doesn't really happen when coasting on smooth sections or the road. It sounds like it is coming from the rear shock mounts - I think from the bolt up front, where it mounts to the frame.
    I've seen various sources online recommending taking out the bolts, cleaning them, greasing and/or loctite-ing them up, and putting them back in. However, I haven't been able to find any good step-by-step how-to's.
    Does anybody have a detailed description of this process for a newbie mechanic like myself?
    Also - is this a potentially dangerous problem?
  16. #2666
    No talent hack
    If you can locate a 2013 Camber Comp, it is just about equal to the level of the 2014 Camber Evo. Finding one of those for $2K would be THE BIKE to buy if looking at Cambers. They will be scarce, but it is worth searching a bit for. I am totally unbiased, but I LOVE my 2013 Comp. LoL
  17. #2667
    Oct 2012
    Minus 10 mm travel?
  18. #2668
    Quote Originally Posted by Dangur View Post
    Does it creak when you stand on the pedals? My seat (henge comp) creaks. You may check that.
  19. #2669
    No talent hack
    Quote Originally Posted by jhtopilko View Post
    Minus 10 mm travel?
    Yeaaah.... except you won't notice it and you can't get the same spec without the Evo level now. The 2014 Comp is a bit of a let down after the 2013.
  20. #2670
    Jaymanjibe
    Nov 2012
    My Triad 2 did the same last year where oil was leaking from the pro pedal lever. I had PUSH Industries rebuild it for ~$180.00. Quick turn around (about 1 week). Shock has been fine every since. It was cheaper than a getting a new CTD shock.
  21. #2671
    Oct 2012
    I figured the upgrade to kashima RP23 plus a tune was worth 300.00 cad to me. I am still contemplating having the triad rebuilt as a spare for trips.
  22. #2672
    I second what NTHA stated. The seats have a known creaking problem. Spray some lube where the seat rails run into the front of the seat. If that's the problem call your bike shop. Specialized is apparently aware of the issue and is compensating the bike shops for replacements. My shop is letting me pay the $30 difference and get the model with titanium rails. Worth a shot.
  23. #2673
    Oct 2012
    I will swap my seat out tonight. My henge creaks bad, I have cleaned the rails twice.
  24. #2674
    Jaymanjibe
    Nov 2012
    It is always nice to have a spare so next time your shock leaks you don't have any down time...Swap it out and RIDE! Of course that's also why many of us have more than one bike
  25. #2675
    Oct 2012
    After I receive my shock, waiting on FedEx today, I will likely send my shock to suspensionwerx in August.
  26. #2676
    Oct 2012
    RP23 in hand. Just installing reducers now
  27. #2677
    Oct 2012
    Re: Official Specialized Camber Thread
  28. #2678
    Oct 2012
    Had a short ride with the kids, the ride over roots uphill is much improved, way better traction. Over major split earth it is also better. I can't wait to do an adult ride to see how much better on descent and high speed through roots.
  29. #2679
    Mar 2014
    Have any of you ridden the camber evo on any downhill runs?? I'm thinking about trading out my camber comp for an evo in the fall and was wondering if I should just go for a stumpy or enduro instead.
  30. #2680
    Oct 2012
    No. A camber on a downhill run would be a slow run. Sounds like you would be best served with an enduro. Horses for courses.
  31. #2681
    Reputation: Dusty Trails's Avatar
    As much as I like my Camber for pure fasr down hill runs I'd want a Stumpy.
    Sent from my SCH-I605 using Tapatalk
  32. #2682
    Oct 2012
    I swapped to my fizik nisene, got rid of the creak in the henge.
  33. #2683
    Jun 2014
    I have a 2013 Camber Comp.
    There is some play between my Monarch shock shaft and the u-shaped bracket that mounts directly to it. Not a lot, but there is some relative movement between the two. Can anybody tell me if this is normal or not?
    I would think this connection should be perfectly tight.
  34. #2684
    Oct 2012
    See if the yoke has a method to tighten it. Compare against a new bike if you can.
  35. #2685
    Jun 2014
    Yeah that would be ideal... I was wondering if anyone here had a camber in working order whose yoke they could describe.
    I can't access the bolt to tighten the connection without taking apart the rear triangle. I don't trust myself with such major surgery.
  36. #2686
    Oct 2012
    Maybe if you just pulled out the front shock bolt you would have better access to the yoke.
  37. #2687
    No talent hack
    The bolt for the yoke is in the middle of the fork. Mine loosened up a bit about 3 months after I got the bike... I could feel the play coming from some where in my bike, but couldn't find it. It felt weird like a loose headset, but that was definitely not it. You can access the bolt well enough to tighten it by deflating your shock completely. The rear end will collapse and you will have enough space for a hex wrench. This is EXACTLY how mine was fixed at the shop... I felt rather silly for bringing it in for a simple fix, but I couldn't find the loose part.
  38. #2688
    Reputation: Trail_Blazer's Avatar
    May 2012
    Mine loosened once too taking the linkage bolts allows it to move into a position you can fix it.
  39. #2689
    What's up Dut?
    Look what I brought home today
    2014 Camber Carbon EVO baby! It is bad to the bone. Quickly got it home and took it out for a quick hit on the trail. It is night and day different over my 2012 Camber. I am super excited for it!
  40. #2690
    Quote Originally Posted by mdutcher View Post
    Yep, felt the same way. They made a lot of developmental progress between 2012 and 2013. I just went with the Comp Carbon model though, sometimes I wish I would have saved up for the Evo. Sweet bike.
  41. #2691
    Mar 2014
    OTE=mdutcher;11340476]2014 Camber Carbon EVO baby! It is bad to the bone.
  42. #2692
    Mar 2014
    Did you take the dropper post off?
  43. #2693
    Quote Originally Posted by TomW in KC View Post
    I was wondering the same thing........
  44. #2694
    What's up Dut?
    Yes, I am not going to use it. So I had them remove it for now.
  45. #2695
    Nov 2013
    Dibbs you want to sell it?
  46. #2696
    May 2012
    Quote Originally Posted by sml-2727 View Post
    I have one for sale.
  47. #2697
    Reputation: fefillo's Avatar
    Jul 2014
    Bonking ... not feelin' well Mystery washers after taking apart suspension.
    I just took apart the required suspension linkages to service the shock on my 2013 Camber Comp (Monarch RL). I only removed 3 suspension pivot screws: 1x top shock pivot screw, and 2x yoke pivot screws.
    My question... I have 2x black washers that are slightly bigger, and 2x silver washers that are a bit smaller and thinner than the black ones. Where do these 4 washers go?
    I've got all published Specialized manuals for this model/year bike, but there are no exploded schematics or assembly guides.
    Thanks in advance,
    Fefillo
  48. #2698
    I really wish you hadn't said that.
    2012 Specialized Camber Comp 29er
    Trek 9800 OLCV, XT upgrade 26er
    KHS Fleetwood
    Schwinn 20" Fastback 5 speed stick shift
  49. #2699
    No talent hack
    Quote Originally Posted by lastplace29er View Post
    I remember telling people the same thing when I bought my Camber (not Evo). I actually test rode a 2012 Camber on the trails and liked it a lot... when the time came to actually put the money on the table, I found out the 2013 model was available, so I went with the 2013 Camber to get the new rear end. It was a night and day difference. The 2012 has a "stiffer" or "firmer" feeling rear end. The 2013 redesign feels more active, or I think some say more plush. It is NOT pogo-like in the way the the big brother Stumpjumper FSR can be (especially for a bigger rider like me), it just feels more well planted.
    Is it worth ditching the old design and dropping more money? I don't think so. I think money would be better spent on an upgraded rear shock (like a Monarch RT3 or Fox Kashima) and a Pike up front... but that is just me.
  50. #2700
    Oct 2012
    I now want to test a camber with the yoke now just to feel the difference for myself. Just Swapping an RP23 in place of my triad was a noticeable difference.
