Page 53 of 93 FirstFirst ... 34349505152535455565763 ... LastLast
Results 2,601 to 2,650 of 4603
  1. #2601
    Reputation: jhtopilko's Avatar
    Oct 2012
    Re: Official Specialized Camber Thread
    Quote Originally Posted by lastplace29er View Post
    Help, I need brake advice. I popped my rear pads out to check them and by mistake hit the brake lever. I finally got the pads back in but the wheel will hardy spin.
    How do I get the caliper right again?
    Pull the wheel. Put a blade screwdriver between the pads and twist. The goal is to press the Pistons back into the caliper, which will give more room for the pads in the caliper.
    Sent from my SGH-I747M using Tapatalk
    2014 Norco range 7.1. Avalanche F34 RP23 with push Factory tune by suspensionwerx.
  2. #2602
    Reputation: jnicosia's Avatar
    Aug 2013
    Quote Originally Posted by matuchi View Post
    I'm leaning towards a Camber Comp Carbon and I read on here the Carbon sizing is different than the aluminum frame Camber Comp. Does anyone have a CCC that's 6'? What size did you get?
    I purchased a camber carbon expert EVO in medium . They had the large they as well. The medium fit like a glove and I am 5'10".
    I think you should lean toward the LG at 6'
    2014 YETI SB95C , KS LEV seat post,Nextie Carbon Wheelset/Hope Hubs/27lbs
    Framed Alaskan Carbon X1 /26lbs/Nextie Hoops.
  3. #2603
    Oct 2012
    I switched to a 70mm stem and want to try a 50mm
  4. #2604
    Aug 2013
    Quote Originally Posted by jhtopilko View Post
    I have a Crank Brothers 780MM wide carbon bars and 80mm stem to put on . The stock set up has been ok , stem is 90mm bar is 700mm wide.
    I am getting lower back pain after long rides say over 45 minutes .
  5. #2605
    Oct 2012
    Loosen the bolts holding the caliper so it can float a bit. Spin the wheel and then tighten them.
  6. #2606
    Does NOT know it all!
    Reputation: matuchi's Avatar
    Quote Originally Posted by jnicosia View Post
    I wish I had the budget for your bike, but I'm kind of pushing it for the Camber Comp Carbon - as I started my budget at around $2,500.
    My LBS is getting in a CCC in Large next week for me to demo - hopefully I will like it.
  7. #2607
    Aug 2013
    PM me if u want a deal on a 2013 specialized camber carbon EVO size LG at a super discount. My LBS has a left over , same one I bought in February. They have one more left!
  8. #2608
    Aug 2013
  9. #2609
    No talent hack
    2013 carbon Camber and 2014 carbon Camber are not the same bike at all. A killer deal might make it worth it, but the 2014's rear end makes for a better ride, IMHO. I rode both designs before buying my Camber.
    2013 Specialized Camber Comp
    2014 Trek Domane 4.0
    2015 Surly Karate Monkey Ops (the commuter)
  10. #2610
    Aug 2013
    Quote Originally Posted by Knight511 View Post
    Were talking about the Expert EVO model . There is one major difference between the 2013 & 2014 , the customized pike shock . But for $3000 difference it's not worth it .
  11. #2611
    Got the caliper lined up, brakes are dragging once applied. Looks like I need a brake bleed.,
    2012 Specialized Camber Comp 29er
    Trek 9800 OLCV, XT upgrade 26er
    KHS Fleetwood
    Schwinn 20" Fastback 5 speed stick shift
  12. #2612
    No talent hack
    The 2013 Camber Carbons still used the old style of rear swing arm that has the pivot located on the seat stay. The 2014 Camber Carbons have switched to the newer swing arm with the pivot being concentric with the shock mount.
    2013 Camber Carbon model:
    2014 Camber Carbon model:
    I rode both styles of rear swing arm and the newer one provided a plusher more predictable ride. There is a bigger difference than just the front fork on the bikes because they are different bikes entirely. You are right though.... maybe not a $3K difference... I would probably be on a 2012 carbon model instead of my 2013 aluminum (which has the new swing arm design) if I could have swung that kind of crazy deal.
  13. #2613
    Jun 2014
    Going back to that cable rub issue under the bottom bracket...
    I (noobishly) took the slack out of my cables under the bottom bracket, because I was afraid of them getting caught on rocks, sticks, etc, and ended up with a gouge comparable to the one on mkasner's bike.
    http://fcdn.mtbr.com/attachments/spe...read-photo.jpg
    I put the 40mm of slack back in the cable as per GR1822's post. But, with the current extent of damage, is this going to ruin my bike? Is it safe to ride?
  14. #2614
    Oct 2012
    My guess is a bottom bracket shell is tough and this shouldn't be an issue for the majority of riding situations.
  15. #2615
    Picked up my 2014 Camber Comp Carbon today. The LBS was willing to make the wheels tubeless free of charge, so I took them up on it. I had a short ride after I got it home to set the tubeless wheels, but tomorrow's ride up Mt Tamalpais will give me a better idea of how well it rides. Below is a photo after I got it home.
  16. #2616
    Aug 2013
    Quote Originally Posted by sml-2727 View Post
    I just did this on my camber comp, it was so simple and way worth it, all you need to do is buy the WT sprocket I went with 32t and install it onto your crank, take off front derailleur,cable,levers. also make sure you adjust the chain to the right length. Also make sure your rear derailleur is a type 2 the one that comes on a 2013 camber comp is.
    The WF front chainring is a direct replacement ? 104mmBD. Also did you have to replace the chain ring bolts ? Any adjustments needed to the drive line ?
    Your OEM chain , was 116 links ? how many links did you end up removing ?
  17. #2617
    Reputation: Dusty Trails's Avatar
    Nice. So what size did you get.
    Sent from my SCH-I605 using Tapatalk
  18. #2618
    Reputation: sml-2727's Avatar
    Nov 2013
    Yes I did need chain ring bolts, I dont recall how many links I ended up removing, when I did all of this I bought a new chain so it was a bunch. This is what I read to help me out, Converting 2x10 to 1x10 - Mountain Bike FAQ
  19. #2619
    Quote Originally Posted by Dusty Trails View Post
    I got a Large and it feels real nice!
    I rode it up Mt Tamalpais this morning.
  20. #2620
    Aug 2013
    Converted my 2x10 to 1x10 tonight .
    Picked up a raceface red 32T chainring from my LBS , removed 2 links from my KMC X10sl chain, removed front derailer , front trigger shifter and cable, 38T chainring and the granny chainring . Only issue I had was that I could not get the sram s2200 crank bolt off to get the crank arm off for removal of the granny chainring . I ended up cutting off the granny chainring with a dremel tool knowing I'll probably never use it again . The 38T chain ring just slid off the crank arm as well as the new raceface 32T slid back on with ease . Utilized the same crank bolts . The chain line integrity was fine as I tested shifting with ease .
    Attached Thumbnails Attached Thumbnails Official Specialized Camber Thread-image.jpg
  21. #2621
    No talent hack
    Looks nice!
    If I ever get my wife a road bike so we can stop riding our of road bikes on the road together, I will take mine down to 1x10. A 30 or 32 would suit my needs rather well.
  22. #2622
    The Boat or The Bike?
    Reputation: Bike&Fish's Avatar
    Oct 2013
    Nice looking bikes guys!
    I've got a '13 Camber Comp. Recently got hooked up with a 120 Pike & got it put on last week! In all, I've got the Pike, a short 35mm Straight Line stem, 780mm bars & SLX brakes. Also an e*thirteen wheelset. And a Reverb dropper post. That Pike is SO smooth it's crazy. It's a whole new bike.
    Sent from my Droid Maxx using Tapatalk
    Live to Fish, now Love to Ride
  23. #2623
    Nice!
    Now go out and enjoy the ride!
  24. #2624
    I removed 4 links
    KHS Fleetwood
  25. #2625
    Aug 2013
    I removed 4 links
    I ended up removing 2 links, looks like you can only remove in 2's . I could remove another 2 . Was your front chain ring a 32 or 30T and did u have a type 2 derailer ?
  26. #2626
    Aug 2013
    I removed 4 links
    Ah re read your post , you had a 30T FS so 4 links , I put on a 32T FS so 2 links should be fine. I am testing this drivetrain out tomorrow . I wish there was a way to remove 3 links but its paired in 2's one narroe and one wide .
  27. #2627
    Nov 2013
    Quote Originally Posted by Bike&Fish View Post
    It looks really nice but, for what you spent adding on you could of just bought a camber comp carbon and had money to spare.
  28. #2628
    Nov 2013
    Yeah dont do this, I just bought some new renthal carbon light bars at 740mm wide in a 10mm rise and also bought the duo stem that is 50mm, its was great going down hil but climbing was not so great, I returned the stem and now have Truvativ AKA All Mountain 80 5-Degree and its much better. BTW im 6'1" on a large frame.
  29. #2629
    Oct 2013
    I actually didn't spend that much. But retail on the changed parts, yes, it's a lot. He he...
  30. #2630
    Jun 2013
    I have have it cut to 700mm
    How wide is your bar?
  31. #2631
    Reputation: ShamusWave's Avatar
    Not mine... just found a pic...
    Official Specialized Camber Thread-10246056_422923311184661_1907483967_n.jpg
  32. #2632
    No Clue Crew
    Apr 2005
    Just picked up a '14 Evo Comp at the LBS. Got it built out to my initial liking and out on a shakedown. Posted thoughts over in the 29er forum. It's a companion to my E29 S-Works.
    <a href="https://www.flickr.com/photos/69288292@N03/14303509059" title="IMG_0528 by dbozman1173, on Flickr"><img src="https://farm6.staticflickr.com/5542/14303509059_05eee29e5d_z.jpg" width="640" height="478" alt="IMG_0528"></a>
  33. #2633
    Jun 2013
    I've want to convert to a 10 x 1 set up, Wolfs Tooth 30T ring. I have bottom bracket cable rub and want the front cable off. Wolfs Tooth's black M8 x 0.75 x 10 mm bolts have been out of stock for weeks. Anybody else know of a US source?
    I would not recommend to buy these aluminium bolts to anyone. It's way too much expensive toy, and made of very-very soft material (the bolt-head gets broken easily, creating you a trouble to get the bolt out of the crank)... You can rather save 95% cash, and buy classic steel bolts.
  34. #2634
    Ben-Jammin
    Reputation: CasteelG's Avatar
    Upgraded my drivetrain to 1x10. Raceface N/W 30T ring, XT cassette with One-Up 42t+16t sprockets added, and an SLX chain.
    It's been great so far. I did have to snag a longer b-tension screw though.
    I also upgraded to a Butcher 2.3 up front. It's been fantastic so far!
    Now I just need to wait for my buddy to re-lace my rear Roval Control Carbon wheel and I'll be done...
  35. #2635
    Aug 2013
    Quote Originally Posted by CasteelG View Post
    Did you have to shorten your chain ?
  36. #2636
    Ben-Jammin
    Indeed I did.
  37. #2637
    I went from 36T to 30T upfront and removed 4 links. Running 11-34t cassette, considering the move to 40T
    KHS Fleetwood
  38. #2638
    Aug 2013
    I want to do the same thing , I want the one up componets 40T and it comes with the 16T replacement cog . This should provide a smooth shift transition .
    My Front original was a 38T and went with a 32T , removed 2 links from the chain and my cassette is 11-36 . I am hoping the chain should still be long enough if I mount that 40T cog out back .
  39. #2639
    Broke the KMC chain couple days before the 4th. Must have been all that cross chaining before going 1x10. Went with an XT replacement, only thing the LBS had in stock. The knuckle head put it on backwards. Good thing they gave me an extra pin.
    I was incorrect in my earlier post, the Camber came with a 11-36t cassette, not 34.
    KHS Fleetwood
  40. #2640
    I broke my KMC chain at about 250 miles. Ended up replacing it with a Shimano XT chain. The LBS said he didn't know why bike manufacturers didn't put the XT chains on original aside from saving a dollar per bike. He did make sure I knew that they could be put on backwards.
  41. #2641
    No Clue Crew
    Apr 2005
    2014 Camber Evo, size L, available if you're in the market.
    Ad here
  42. #2642
    No talent hack
    Stretched my chain to replacement values in about 1000 miles. Replaced it with another KMC as I was happy with the performance. Breaking chains prematurely can also be a sign of bad form.... spint he pedals at a higher RPM( 75-90) instead of mashing them....
  43. #2643
    Believe me when I say I don't mash pedals, that crap wears you out. Though to be fair The KMC chianti on my 20212 held up until it stretching called for a replacement. I think what my LBS was saying is that there is a higher probability of a chain break with KMC chain vs Shimano.
  44. #2644
    Merendon Junkie
    Reputation: abelfonseca's Avatar
    Dec 2011
    ... I think what my LBS was saying is that there is a higher probability of a chain break with KMC chain vs Shimano.
    I read somewhere that KMC manufactures all of the Shimano chains except for the XTR and Dura Ace chains. I use kmc and have never broken one. I think they are as good as it gets when is comes to chains.
  45. #2645
    Guilty as charged, hammering uphill while down shifting.
    KHS Fleetwood
  46. #2646
    No talent hack
    The only chain I have broken was done by shifting as I dropped off a curb and stood on the pedal (on my old bike)... not saying they can't break under "normal" use, but it is a lot less likely.
  47. #2647
    Aug 2013
    OneUp Componets 40T & 16T on Camber carbon EVO
    Well I finally did the 40T conversion. I didn't want the 42T at this time but may do that after I test a few tough climbing courses on the 40T.
    I Also used the 16T OneUp replacement cog for the 15T and the 17T , have to say its not as smooth as a shift as I thought it was going to be. The 40T shifts perfectly as well as all the other cogs on cassette except the 16T replacement . I will pull it back off to recheck the position since OneUp uses one cog for both SRAM and shimano. Other than that it was a very easy install. Chain lenth was fine as I deflated my rear shock and tested the chain tension.
    Official Specialized Camber Thread-photo1.jpgOfficial Specialized Camber Thread-photo2.jpgOfficial Specialized Camber Thread-photo3.jpgOfficial Specialized Camber Thread-photo4.jpgOfficial Specialized Camber Thread-photo5.jpgOfficial Specialized Camber Thread-photo6.jpgOfficial Specialized Camber Thread-photo7.jpg
  48. #2648
    No talent hack
    I am sure this is not news, but it does make me happy to hear. Rock Shox is now offering a Monarch RT3 that is actually made to fit the newer style of Camber rear end. Considering I like my OEM Monarch , I like the idea of the upgrade to be able to have a pedal platform setting as I have no plans on putting any Fox product on the bike.
    RockShox Monarch and Monarch Plus Evolve to Include Mounts for Trek and Specialized
  49. #2649
    I picked up my 2014 camber comp carbon back in November 2013 and I think I have it all tweaked out the way I want it aside a brake upgrade when these stock ones wear out.
    Started out stock weight 28.8lbs
    Added:
    -XT clipless pedals
    -SWAT Top Cap Chain Tool
    -Z cage with SWAT multi-tool
    -Race Face carbon fiber set post
    -Topeak quick release saddle Lg saddle bag complete with alien head light because why not
    -Topeak mini air pump
    -Chinese 700mm carbon fiber handle bar (that I like a lot more then I thought I would)
    -Oury grips
    -Specialized bike computer
    -Marsh Guard
    -Last but not least Mavic Crossmax SLR 29 rims with S-works Ground Controle tires and XT cassette
    Before I put the wheel set on the bike was at 29.9 pounds but the new wheel set has brought the weight back down to it's out-of-the-box weight of 28.8lbs
  50. #2650
    2014 Camber Carbon Comp
    Official Specialized Camber Thread-photo-3.jpgOfficial Specialized Camber Thread-photo-1.jpg
    New trail bike. Upgraded crankset with FSA SL-K crank and finishing kit. I decided on a 1 x 10. Using Wolf Tooth 40T giant cog and 30T Wolf Tooth front chainring. Went with Stan's Crest and S Works Captain Tires. Replaced the rear cassette with an XT. Less than 26lbs. Rides like a champ and looks the business.
    Keeping stock Shimano XT clutch rear derailleur, but did opt for the longer B-tension bolt. First ride impressions are pretty sweet. Looking to swap out the 15 rear cog for a 16T to lessen the transition from the 19T.
    Attached Thumbnails Attached Thumbnails Official Specialized Camber Thread-photo-4.jpg
