Page 28 of 90 FirstFirst ... 182425262728293031323878 ... LastLast
Results 1,351 to 1,400 of 4482
  1. #1351
    Reputation: GnarBrahWyo's Avatar
    Jun 2012
    Quote Originally Posted by Super Dee View Post
    For those of you with a triad II rear shock. How often do you need to get it serviced? I don't mean just by fox guidelines. Rather in reality.
    On my 2008 Stumpy (which had a triad), I had the shocks torn down every two seasons. Your LBS and Fox will claim to get it done much more frequently, but I was in college and on a tight budget. I average about 50 rides a season 1 to 5 hours per ride. Always seemed to run fine, but that's just me. This is what Fox says. Service Intervals
  2. #1352
    Nov 2012
    Thanks. That was the very sort of info I was after.
    My Camber is my first FS, although I have been mtbing since mid 80's and ridden a fair few. I was a bit shocked (did you see what I did there?! ) by the service intervals on some kit. I do still have my steel ht with coil fork for those grab and go rides, etc.
    I am impressed that the Camber is the most 'right at home' bike I have had since a Fisher I bought in 1990 so can't complain too much!
  3. #1353
    Jun 2012
    Anyone know if you can eventually upgrade the fork on a carbon model to get a tad more travel on it without voiding the warrantly?
  4. #1354
    Dec 2012
    Please help blown triad ii upgrade,
    I'm now going to be on my second Triad II...dealer replaced the first one...
    Specs are 7.875x1.9
    Can the FOX Float CTD 7.875 x 2.0 bolt up?
    I don't want to have to customize the shock and have it sent out.... I found a deal one one and want to know if I should grab it.
    Bike is a 2011 Camber Pro 29er, small frame.
  5. #1355
    Reputation: BCTJ's Avatar
    I just weighed an XL Camber 29er yesterday - 33 pounds!!! And I thought they said the newer models were going to be lighter!
  6. #1356
    Jun 2012
    Quote Originally Posted by BlackCanyonTrailJunkie View Post
    Which model Camber? The lower-end Cambers will weight a lot more than the carbon models which have a lighter frame and lighter components. The fact that it is an XL means it will be a bit heftier as well.
  7. #1357
    Reputation: MObiker's Avatar
    I have 29er expert carbon evo, 26 #'s tubeless. It should be less when I go 1 x 10.
    If the path ahead looks dangerous ------- it probably is!
  8. #1358
    [QUOTE=GnarBrahWyo;9928253]Which model Camber? The lower-end Cambers will weight a lot more than the carbon models which have a lighter frame and lighter components. The fact that it is an XL means it will be a bit heftier as well.[/QUOT
    It was the lowest end model....M5 aluminium or something like that.
  9. #1359
    Competent User
    Reputation: Mr.Quint's Avatar
    Mar 2012
    What year? The lowest model 2012 29er frame is actually the 2011 frame. I have one of those, and it was 31 lbs for a medium stock with pedals.
  10. #1360
    Nov 2012
    Just a bit of weight info. Maybe useful for people looking at last years model on clearout or second hand even.
    My lbs weighed a 26 Camber Comp in large for me when I was looking to go for either that or the Elite model. The Comp was 32lb without pedals and the Elite as near as possible to 2lb lighter.
    I ended up with a stonking deal on the Exert though. We didn't weight this one till it had pedals and a bottle cage on it but it came in at 28lb.
  11. #1361
    Oct 2012
    Evening all, just thought i'd share my (almost finished) 29er build.
    The concept started a few months back, looking for a bike with around £2500 budget for mostly trail with some XC and rougher rocky/rooty action.
    At 6'4'' I'm definitely in the XL size frame however was struggling to find bikes in my size with a 29er option.
    I looked initially at a Stumpy Comp EVO 29er but Specialized don't stock it in the UK and it was a little on the extreme side of my riding. I also looked at a Cannondale Scalpel 3 Alloy but couldn't get one in a XL size. I did however really like the Lefty concept so set out to build a mix and match of what i liked in the bikes i was looking at.
    My basic requirements were FS Alloy MTB with 29'' wheels, around 110mm travel with a Lefty set up if possible and decent brakes to slow my not inconsiderable bulk down. Oh yeah, my £2500 budget also stood.
    Looking around, the 2012 Specialized Camber Comp 29er really started to stand out. Heavily discounted from £2400 to £1700 it had most of what i wanted except forks and brakes. Purchased online, i immediately sold the fox forks (£375), Avid Exilir 7 Brakes (£100) and the standard SLX shifters (£50) bringing my outlay down to £1175.
    A brand new XLR140 Carbon from Qwerty cycles (top customer service!) was ordered coming in at £820 delivered! teamed to a tapered Project321 Stem (circa £100). I had my LBS re-lace the still new Specialized wheel to a standard Cannondale lefty Hub and chucked some brand new XT shifters on since they were a good price (£10 more than i got for my brand new SLX items).
    Perusing Chain-Reactions clearance pages, i spotted some Formula the ONE10 Ltd edition brakes reduced to £320 for both front and rear delivered so they were swiftly ordered!
    Chucking the lot together over the last few weeks as the parts have turned up, they is how its looking:
    Total price is a touch over my budget but i'm happy with the spec i've ended up with.
    I just need to re-shim the fork to 29er spec and am awaiting delivery of a remotely adjustable seat-post to finish the build off. The brakes are spaced correctly with stainless washers at the moment but will be replaced with turned aluminum spacers.
    Now, a good day out to set it up properly and start having some fun on it!
    Pete
  12. #1362
    Dec 2010
    hmm..a Specialized with a Lefty, equipped with a mix of Sram, Shimano and Formula components...interesting
  13. #1363
    Oct 2012
    Killer bike, thats sweeter than a S-WORKS! Hows that lefty ride? Are those formulas squeal free, unlike the Avids?
  14. #1364
    Oct 2012
    I haven't had the chance to try it yet, Just waiting on the dropper post and some time off work to get out on it. I'm not 100% sure they wont squeal as the avid disks are still on there but if it does squeal i'll upgrade them to something more suited to the caliper.
  15. #1365
    Nov 2012
    Looks great. Nice to see another UK owner.
    What dropper post are you going for?
    Also, not sure if the 29ers suffer the same but I can't see why they wouldn't, which is rear brake cable rub on the inside of the chainstay. You can read on the previous page or so about what I did as prevention.
    Enjoy the new bike.
  16. #1366
    I Ride Bikes
    Reputation: Mazukea's Avatar
    My 2012 Specialized Camber
    This is a pic from my latest conquer this past weekend. Me and my buddies were the first ever to conquer this mountain on bikes. Under that metal sign is the surveying pin. Pretty awesome feeling when we reached the summit.
    I like to hug trees at FULL SPEED!
    INSTAGRAM -> hawaii808MTB
    FACEBOOK -> Big Island Mountain Biking
  17. #1367
    Jun 2012
    Quote Originally Posted by Mazukea View Post
    Was that single track going up? How do you like your Camber for AM riding, compard to a Stumpy?
  18. #1368
    Quote Originally Posted by Mr.Quint View Post
    This was the new 2013 model....it was an XL but still 33 pounds seems like alot.
  19. #1369
    Oct 2012
    Enjoy the new bike.
    I wasn't aware of the chain stay rubbing issues but i did have concerns about the control cables rubbing around the headstock of the bike. My plan is to apply a layer of blade tape in this area (and on the chain stay now you've given me the heads up). A clear abrasive resistant strip i use it in work to protect the leading edge of helicopter rotor blades from erosion so this should do the job perfectly and is periodically replaceable.
    I've ordered a chinese copy of the ICE Lift V8. MBR magazine gave it a 9/10 review score. The chinese copy appears identical in every way (indeed its probably made on the same production line). I'll swap out any fasteners for Ti/ Stainless as my experience of chinese products (mainly motorcycle parts) is of decent manufacture marred by poor fasteners.
    This design also features some features i prefer over more expensive models. The traveling surfaces are protected by a rubber boot similar to that found on the lefty which should help protect the moving surfaces and prevent seizing due to dirt ingress. Similarly the cable entry/activation mechanism is all internal and not exposed like many designs again increasing reliability, indeed the entry point looks like it cab be positioned fore of the seat-stay so reduce the level of dirt thrown onto the entrance from the rear wheel. The entry point for the control cable is also at the bottom of the post which will allow for a more permanent cable routing with no cable movement when the seat is raised and lowered. This should prevent frame finish wear caused by a movement. Oh yeh, its also £65 not £300, worth a try i think!
    Fresh Produce: ICE Lift V8 Seatpost
    2013 TMARS Remote Adjustable Seat Post 31.6X425mm / 27.2X425mm | eBay
    Pete
  20. #1370
    Competent User
    Mar 2012
    New Brakes on Camber
    Question for those of you ditched your Avid brakes (yes, I've tried everything. Seriously). I'm going to put some SLX or XT brakes on the bike, depending on specials and sales in the coming months, and I wanted to know what else I need besides the brakes in terms of mounting up the Shimanos. For example, do I need a new adapter for the 180mm front brake, or can I use the one that's on it? What about the 160 rear? Do I need the IS mount for Shimano, or will the current hardware do the job?
    I know I can get the Ice Tech rotors, and probably will, and that I don't want centerlock.
    Nov 2012
    Thanks for the reply Yamirider.
    Let me know how you get on with the dropper post - I recall seeing the ICE one in MBR as I have bought the last couple of issues as they had my Camber Expert in them. In my previous posts on this thread you might have seen Danny's Camber from MBR too.
    I got the info on the brake rub from a couple of UK based forums and thought prevention is better than cure.
    Let us know how you get on with the dropper. It is something I want to add. I am pretty sold on the Spesh Command version but its good to compare / keep the options open.
  22. #1372
    Nov 2012
    @ Mazukea - great pics - my son will love them btw as he is Hawaii crazy atm. (big Hawaii five-0 fan)
    What pedals do you have?
  23. #1373
    I Ride Bikes
    I currently have the Spike Spank pedals. I really wish I had clipless pedals for this ride cause some of the climbing was intense. Not very technical, but steep. I just can't decide which pedals to get.
    Here's another pic of that ride. In the background is Hualalai. That haze is the picture is vog. It was pretty bad on Sunday cause the south winds were kicking it straight up the coastline
  24. #1374
    I Ride Bikes
    Quote Originally Posted by GnarBrahWyo View Post
    It was double track going up. It changed from broken asphalt, to rocks, to dirt, to grass, then powdery dirt, to loose rocks, then it got really steep. I was in granny gear wishing that I had a couple of more granny gears. lol. The last mile up was killer.
    I never had a Stumpy, this is actually my first bike. The Camber is doing great for the riding that I do. I noticed that on the downhills my 29er is fast compared to my friends 26ers. I really don't have to pedal to catch up to them. In fact, I usually have to apply my brakes if I'm behind them or else I will be right on top of them. I don't know if that is just a 29er thing though.
  25. #1375
    Nov 2012
    Great pic and thanks for the info on the pedals.
    What were your riding buddies riding?
  26. #1376
    Reputation: Ksousa81's Avatar
    Rock Shox Monarch RL w/ autosag comes on the comp 29 model. Ive been jumping around on here trying to find some reviews. What do people think and say about it?
    My Plan was to grab a 2013 camber comp 29 and a set of mavic crossmax 29 ST
    price tag is going to be about $3150.00
    Still cheaper than the Comp Carbon that my LBS is selling for $3500
    but the carbon has the FOX Float CTD Evolution. Im new to the full suspenion game and want to make sure that the rock shox monarch RL has what it takes to keep me riding .
    5'10" 240lbs
    I ride XC and real Techy XC nothing more than 2 foot drop( and not every often either)
  27. #1377
    Reputation: jhtopilko's Avatar
    Oct 2012
    I considered that option, but preferred the frame feel of the carbon.
  28. #1378
    Nov 2012
    I was going to add a picture I found on my phone of my Camber but it didn't look good when I viewed on the laptop compared to my phone!
    Tried to delete the post but couldn't. Sorry.
    But rather than waste a post - just thought - what made you choose the Camber?
    For me, I knew I wouldn't need more than 120mm, I liked the styling and knew Spesh have a great rep and build good bikes. The real clincher though was the fact that it felt 'right' as soon as I rode it.
  29. #1379
    Oct 2012
    like you the camber felt right right away.
    So I tested a Tallboy LT AL ,and a Specialized EPIC comp, and then a Stumpjumper.
    None felt as good as the Camber carbon, all the other bikes I tested were AL.
  30. #1380
    Nov 2012
    So I could post a pic of my Camber my son sent me this one. It's his '12 Hardrock Disc in the background.
  31. #1381
    Sep 2012
    Well... I bought a '12 specialized stumpjumper comp fsr 26.
    About the Camber Comp I didn't care for the rear ARIO shock that blew out so easily, the cheap front hub and cheap crankset & BB. I understand they are/were going after a price point and its a lot of bike for the money. Also had I known that all the bike manufacturers were going to stop producing 120-130mm suspension forks eliminating the possibility for future upgrades I wouldn't have bought the Camber in the first place. Keep in mind I'm not griping. I ride very aggressively and outgrew the capabilities of the Camber much faster than I expected. It got me back into mountain biking at a pretty low price. I love Specialized bikes and the SJ FSR is my 4th specialized. My 3rd Specialized full suspension bikes.
  32. #1382
    I Ride Bikes
    Helped my buddy do some trail maintenance yesterday. Then we ripped through that trail like we were on fire! lol.
  33. #1383
    Dec 2009
    Monarch rl on comp 2013 can be upgraded to rt3?
    Send from Tapatalk via GalaxyTab
  34. #1384
    Merendon Junkie
    Reputation: abelfonseca's Avatar
    Dec 2011
    Riding my Camber through some sweepers
    Here is a video I made of the way back from a long climb we did last Saturday with our group. Its a twisty downhill through what you guys would call fire roads. Its nothing technical nor am I going way fast but it was somewhat muddy and slippery and very fun. I almost lost it at 3:48, yay!.
    Cheers
    Disclaimer: No fowl was harmed during the filming of this video.
  35. #1385
    Nov 2012
    Cool vid.
    Hammer that Camber!
  36. #1386
    I got my rear shock back from Fox last night, they did a rebuild, no charge.
    While my Camber was out of commission we went back to our 26ers....never again!
    Trek 9800 OLCV, XT upgrade 26er
    KHS Fleetwood
    Schwinn 20" Fastback 5 speed stick shift
  37. #1387
    Tweaks done to my Camber so far
    -Converted to tubeless
    -Trimmed bars 2.5"
    -Added GP2 grips
    -Hope to upgrade wheels at some point.
    KHS Fleetwood
  38. #1388
    Dec 2011
    My 2011 Camber comp 26" size small with a few changes.
    Answer pro-taper carbon 720mm 1/2" rise Handlebars (stock 680mm)
    Shimano SLX cranks and BB 175MM from 170mm
    Shimano M-520 pedals
    Tubeless Conv.
    Ground Control 2.1 rear 2.3 front ( Had Captain 2.2's)
    Specialized stem non adjustable 75mm (saved 24.6 grams over adjustable angle)
    Lizard Skins Peaty Lock on cheers grips
    Blackurn Dirt merchant front fender ( No straps! )
  39. #1389
    Reputation: sgtjim57's Avatar
    Replaced rear derailleur today. Really do not know what happened, never dropped the bike, hit anything, or any of the normal reasons a rear derailleur would get damaged, bent cage. Purchased the exact same model however it was not available in black so I got the crome. Looks good, shifts good, due to rain no ride yet so we shall see.
    2016 Cannondale Scalpel Si Carbon 3 (27.5)
    2013 Specialized Camber Carbon
    2011 Specialized Stumpjumper Comp
  40. #1390
    Nov 2012
    @ Whiskytango Rider - that pic / your username brought back memories of the old Whiskytown racer!
    BTW, were the 680mm bars stock on all US Cambers? I only seem to have seen 720mm on UK Cambers.
  41. #1391
    Dec 2011
    My bike came with 680mm.
    Not sure about other bikes. 2011 Camber models in US had 680mm handlebars according to website. and 2012 as well .
    Whiskeytown Rocks! Oh and 720mm was best swap yet.
  42. #1392
    Nov 2012
    Thanks! I guess it depends on the Country then for the overall spec.
  43. #1393
    Dec 2011
    Yes, Country does matter. Also sometimes Specialized will make small changes and do not edit website specs. For instance my bike came with Captain 2.2 tires front &back ,but website says Captain .2.0's front &back?
  44. #1394
    @whiskeytango_Rider, nice bike,nice place to ride. I love that country up there.Next time I get back to Redding, I'm going to ride Whiskeytown. Rode FB trail when I was there in Sept.
  45. #1395
    Dec 2011
    Thanks! If you come to Redding and have no one to ride with PM me. FB trail is a great trail, Whiskeytown is alot more difficult to navigate and ride,But well worth it!
  46. #1396
    Hi
    I'm considering a camber that can be a XC race machine during the summer and more of a trail oriented bike during the off season between sept - may.
    My budget is around the comp carbon model so I would like to buy the camber and switch parts (seatpost, steam, handlebar, tyres, tubeless?, add barends) so Its more race oriented “out of the box”.
    Is that a good idea? What should i do for get the camber to be more of a race bike? Im not looking for upgrades price-wise, more geometry-wise and maby weight-wise if I change the tyres.
    Thank you
  47. #1397
    No talent hack
    I would definitely try both the Carbon and the Aluminum models. The aluminum weighs a tiny bit more now that they switched to the M5 aluminum and a new swing arm. According to Bike Rumor, the difference is 7 ounces. 2013 Specialized Mountain Bikes – Complete Overview & Actual Weights - Bike Rumor
    The price difference is $1000 between the two. While you may be "stuck" with the Monarch on the aluminum rear end, you can spend the $$$ to upgrade the bike as you see fit. I replaced the shifters with XO GripShift and would still have enough money left to replace the front fork with a Fox before touching the price of a carbon Camber.
    Just my $0.02... and I am going crazy waiting for the bike to get to my LBS from the Specialized warehouse.....
    2013 Specialized Camber Comp
    2014 Trek Domane 4.0
    2015 Surly Karate Monkey Ops (the commuter)
  48. #1398
    Nov 2012
    Anyone use a reverb on their Camber?
    Torn between that and my original first choice of the Command post.
  49. #1399
    Reputation: GR1822's Avatar
    I have a KS Dropzone with remote on mine and LOVE IT!!! I've had a KS i950r (same post only no setback) on my Giant Reign for a few years and its been trouble free. Kindshock is the best on the market IMO. If you don't need/want the setback post the supernatural has 6" of travel vs the dropzone's 5".
    The cheapest I found them was through cycle club sports out of Texas for those of you in the US. Either way a dropper post is the best upgrade to a bike
  50. #1400
    No talent hack
    FWIW, I picked my new Camber Comp up yesterday.... sadly, I won't get to ride it for a few days...
    Just got to ride it around my street, yard and a field for a bit..... I am going to be a very happy biker.
