Page 108 of 167 FirstFirst ... 8 58 98 104 105 106 107 108 109 110 111 112 118 158 ... LastLast
Results 2,676 to 2,700 of 4151
  1. #2676
    Quote Originally Posted by Dangur View Post
    My camber has just started to creak intermittently.
    It creaks most when pedaling over uneven terrain (when the suspension is actually doing work) - it doesn't really happen when coasting on smooth sections or the road. It sounds like it is coming from the rear shock mounts - I think from the bolt up front, where it mounts to the frame.
    I've seen various sources online recommending taking out the bolts, cleaning them, greasing and/or loctite-ing them up, and putting them back in. However, I haven't been able to find any good step-by-step how-to's.
    Does anybody have a detailed description of this process for a newbie mechanic like myself?
    Also - is this a potentially dangerous problem?
    I second what NTHA stated. The seats have a known creaking problem. Spray some lube where the seat rails run into the front of the seat. If that's the problem call your bike shop. Specialized is apparently aware of the issue and is compensating the bike shops for replacements. My shop is letting me pay the $30 difference and get the model with titanium rails. Worth a shot.
  2. #2677
    Reputation: jhtopilko's Avatar
    Oct 2012
    I will swap my seat out tonight. My henge creaks bad, I have cleaned the rails twice.
    2014 Norco range 7.1. Avalanche F34 RP23 with push Factory tune by suspensionwerx.
  3. #2678
    Jaymanjibe
    Nov 2012
    Quote Originally Posted by jhtopilko View Post
    I figured the upgrade to kashima RP23 plus a tune was worth 300.00 cad to me. I am still contemplating having the triad rebuilt as a spare for trips.
    It is always nice to have a spare so next time your shock leaks you don't have any down time...Swap it out and RIDE! Of course that's also why many of us have more than one bike
  4. #2679
    Oct 2012
    After I receive my shock, waiting on FedEx today, I will likely send my shock to suspensionwerx in August.
  5. #2680
    Oct 2012
    RP23 in hand. Just installing reducers now
  6. #2681
    Oct 2012
    Re: Official Specialized Camber Thread
  7. #2682
    Oct 2012
    Had a short ride with the kids, the ride over roots uphill is much improved, way better traction. Over major split earth it is also better. I can't wait to do an adult ride to see how much better on descent and high speed through roots.
  8. #2683
    Mar 2014
    Have any of you ridden the camber evo on any downhill runs?? I'm thinking about trading out my camber comp for an evo in the fall and was wondering if I should just go for a stumpy or enduro instead.
  9. #2684
    Oct 2012
    No. A camber on a downhill run would be a slow run. Sounds like you would be best served with an enduro. Horses for courses.
  10. #2685
    Reputation: Dusty Trails's Avatar
    As much as I like my Camber for pure fasr down hill runs I'd want a Stumpy.
    Sent from my SCH-I605 using Tapatalk
  11. #2686
    Oct 2012
    I swapped to my fizik nisene, got rid of the creak in the henge.
  12. #2687
    Jun 2014
    I have a 2013 Camber Comp.
    There is some play between my Monarch shock shaft and the u-shaped bracket that mounts directly to it. Not a lot, but there is some relative movement between the two. Can anybody tell me if this is normal or not?
    I would think this connection should be perfectly tight.
  13. #2688
    Oct 2012
    See if the yoke has a method to tighten it. Compare against a new bike if you can.
  14. #2689
    Jun 2014
    Yeah that would be ideal... I was wondering if anyone here had a camber in working order whose yoke they could describe.
    I can't access the bolt to tighten the connection without taking apart the rear triangle. I don't trust myself with such major surgery.
  15. #2690
    Oct 2012
    Maybe if you just pulled out the front shock bolt you would have better access to the yoke.
  16. #2691
    No talent hack
    The bolt for the yoke is in the middle of the fork. Mine loosened up a bit about 3 months after I got the bike... I could feel the play coming from some where in my bike, but couldn't find it. It felt weird like a loose headset, but that was definitely not it. You can access the bolt well enough to tighten it by deflating your shock completely. The rear end will collapse and you will have enough space for a hex wrench. This is EXACTLY how mine was fixed at the shop... I felt rather silly for bringing it in for a simple fix, but I couldn't find the loose part.
    2013 Specialized Camber Comp
    2014 Trek Domane 4.0
    1999 Trek STP200 (the commuter)
  17. #2692
    Reputation: Trail_Blazer's Avatar
    May 2012
    Mine loosened once too taking the linkage bolts allows it to move into a position you can fix it.
  18. #2693
    What's up Dut?
    Look what I brought home today
    2014 Camber Carbon EVO baby! It is bad to the bone. Quickly got it home and took it out for a quick hit on the trail. It is night and day different over my 2012 Camber. I am super excited for it!
  19. #2694
    Quote Originally Posted by mdutcher View Post
    Yep, felt the same way. They made a lot of developmental progress between 2012 and 2013. I just went with the Comp Carbon model though, sometimes I wish I would have saved up for the Evo. Sweet bike.
  20. #2695
    Mar 2014
    OTE=mdutcher;11340476]2014 Camber Carbon EVO baby! It is bad to the bone.
  21. #2696
    Mar 2014
    Did you take the dropper post off?
  22. #2697
    Does NOT know it all!
    Reputation: matuchi's Avatar
    Quote Originally Posted by TomW in KC View Post
    I was wondering the same thing........
  23. #2698
    What's up Dut?
    Yes, I am not going to use it. So I had them remove it for now.
  24. #2699
    Reputation: sml-2727's Avatar
    Nov 2013
    Dibbs you want to sell it?
  25. #2700
    May 2012
    Quote Originally Posted by sml-2727 View Post
    I have one for sale.
