Page 106 of 169 FirstFirst ... 6 56 96 102 103 104 105 106 107 108 109 110 116 156 ... LastLast
Results 2,626 to 2,650 of 4219
  1. #2626
    The Boat or The Bike?
    Reputation: Bike&Fish's Avatar
    Oct 2013
    Re: Official Specialized Camber Thread
    Nice looking bikes guys!
    I've got a '13 Camber Comp. Recently got hooked up with a 120 Pike & got it put on last week! In all, I've got the Pike, a short 35mm Straight Line stem, 780mm bars & SLX brakes. Also an e*thirteen wheelset. And a Reverb dropper post. That Pike is SO smooth it's crazy. It's a whole new bike.
    Sent from my Droid Maxx using Tapatalk
    Live to Fish, now Love to Ride
  2. #2627
    Does NOT know it all!
    Reputation: matuchi's Avatar
    Nice!
    Now go out and enjoy the ride!
  3. #2628
    Quote Originally Posted by jnicosia View Post
    The WF front chainring is a direct replacement ? 104mmBD. Also did you have to replace the chain ring bolts ? Any adjustments needed to the drive line ?
    Your OEM chain , was 116 links ? how many links did you end up removing ?
    I removed 4 links
    2012 Specialized Camber Comp 29er
    Trek 9800 OLCV, XT upgrade 26er
    KHS Fleetwood
    Schwinn 20" Fastback 5 speed stick shift
  4. #2629
    Reputation: jnicosia's Avatar
    Aug 2013
    Quote Originally Posted by lastplace29er View Post
    I removed 4 links
    I ended up removing 2 links, looks like you can only remove in 2's . I could remove another 2 . Was your front chain ring a 32 or 30T and did u have a type 2 derailer ?
    2014 YETI SB95C , KS LEV seat post,Nextie Carbon Wheelset/Hope Hubs/27lbs
    Framed Alaskan Carbon X1 /26lbs/Nextie Hoops.
  5. #2630
    Aug 2013
    I removed 4 links
    Ah re read your post , you had a 30T FS so 4 links , I put on a 32T FS so 2 links should be fine. I am testing this drivetrain out tomorrow . I wish there was a way to remove 3 links but its paired in 2's one narroe and one wide .
  6. #2631
    Reputation: sml-2727's Avatar
    Nov 2013
    Quote Originally Posted by Bike&Fish View Post
    It looks really nice but, for what you spent adding on you could of just bought a camber comp carbon and had money to spare.
  7. #2632
    Nov 2013
    Quote Originally Posted by jhtopilko View Post
    I switched to a 70mm stem and want to try a 50mm
    Sent from my SGH-I747M using Tapatalk
    Yeah dont do this, I just bought some new renthal carbon light bars at 740mm wide in a 10mm rise and also bought the duo stem that is 50mm, its was great going down hil but climbing was not so great, I returned the stem and now have Truvativ AKA All Mountain 80 5-Degree and its much better. BTW im 6'1" on a large frame.
  8. #2633
    Oct 2013
    Quote Originally Posted by sml-2727 View Post
    I actually didn't spend that much. But retail on the changed parts, yes, it's a lot. He he...
  9. #2634
    Jun 2013
    I have have it cut to 700mm
    Quote Originally Posted by Dusty Trails View Post
    How wide is your bar?
    Sent from my SCH-I605 using Tapatalk
  10. #2635
    Reputation: ShamusWave's Avatar
    Not mine... just found a pic...
    Official Specialized Camber Thread-10246056_422923311184661_1907483967_n.jpg
  11. #2636
    No Clue Crew
    Apr 2005
    Just picked up a '14 Evo Comp at the LBS. Got it built out to my initial liking and out on a shakedown. Posted thoughts over in the 29er forum. It's a companion to my E29 S-Works.
    <a href="https://www.flickr.com/photos/69288292@N03/14303509059" title="IMG_0528 by dbozman1173, on Flickr"><img src="https://farm6.staticflickr.com/5542/14303509059_05eee29e5d_z.jpg" width="640" height="478" alt="IMG_0528"></a>
  12. #2637
    Jun 2013
    I've want to convert to a 10 x 1 set up, Wolfs Tooth 30T ring. I have bottom bracket cable rub and want the front cable off. Wolfs Tooth's black M8 x 0.75 x 10 mm bolts have been out of stock for weeks. Anybody else know of a US source?
    I would not recommend to buy these aluminium bolts to anyone. It's way too much expensive toy, and made of very-very soft material (the bolt-head gets broken easily, creating you a trouble to get the bolt out of the crank)... You can rather save 95% cash, and buy classic steel bolts.
  13. #2638
    Ben-Jammin
    Reputation: CasteelG's Avatar
    Upgraded my drivetrain to 1x10. Raceface N/W 30T ring, XT cassette with One-Up 42t+16t sprockets added, and an SLX chain.
    It's been great so far. I did have to snag a longer b-tension screw though.
    I also upgraded to a Butcher 2.3 up front. It's been fantastic so far!
    Now I just need to wait for my buddy to re-lace my rear Roval Control Carbon wheel and I'll be done...
  14. #2639
    Aug 2013
    Quote Originally Posted by CasteelG View Post
    Did you have to shorten your chain ?
  15. #2640
    Ben-Jammin
    Indeed I did.
  16. #2641
    I went from 36T to 30T upfront and removed 4 links. Running 11-34t cassette, considering the move to 40T
    KHS Fleetwood
  17. #2642
    Aug 2013
    I want to do the same thing , I want the one up componets 40T and it comes with the 16T replacement cog . This should provide a smooth shift transition .
    My Front original was a 38T and went with a 32T , removed 2 links from the chain and my cassette is 11-36 . I am hoping the chain should still be long enough if I mount that 40T cog out back .
  18. #2643
    Broke the KMC chain couple days before the 4th. Must have been all that cross chaining before going 1x10. Went with an XT replacement, only thing the LBS had in stock. The knuckle head put it on backwards. Good thing they gave me an extra pin.
    I was incorrect in my earlier post, the Camber came with a 11-36t cassette, not 34.
    KHS Fleetwood
  19. #2644
    Reputation: Dusty Trails's Avatar
    I broke my KMC chain at about 250 miles. Ended up replacing it with a Shimano XT chain. The LBS said he didn't know why bike manufacturers didn't put the XT chains on original aside from saving a dollar per bike. He did make sure I knew that they could be put on backwards.
  20. #2645
    No Clue Crew
    Apr 2005
    2014 Camber Evo, size L, available if you're in the market.
    Ad here
  21. #2646
    No talent hack
    Stretched my chain to replacement values in about 1000 miles. Replaced it with another KMC as I was happy with the performance. Breaking chains prematurely can also be a sign of bad form.... spint he pedals at a higher RPM( 75-90) instead of mashing them....
    2013 Specialized Camber Comp
    2014 Trek Domane 4.0
    1999 Trek STP200 (the commuter)
  22. #2647
    Quote Originally Posted by Knight511 View Post
    Believe me when I say I don't mash pedals, that crap wears you out. Though to be fair The KMC chianti on my 20212 held up until it stretching called for a replacement. I think what my LBS was saying is that there is a higher probability of a chain break with KMC chain vs Shimano.
  23. #2648
    Merendon Junkie
    Reputation: abelfonseca's Avatar
    Dec 2011
    ... I think what my LBS was saying is that there is a higher probability of a chain break with KMC chain vs Shimano.
    I read somewhere that KMC manufactures all of the Shimano chains except for the XTR and Dura Ace chains. I use kmc and have never broken one. I think they are as good as it gets when is comes to chains.
  24. #2649
    Guilty as charged, hammering uphill while down shifting.
    KHS Fleetwood
  25. #2650
    No talent hack
    The only chain I have broken was done by shifting as I dropped off a curb and stood on the pedal (on my old bike)... not saying they can't break under "normal" use, but it is a lot less likely.
