    Reputation: Rockrover's Avatar
    New Enduro Comp SE 29 and XX1 Conversion
    Hey guy's. Well I finally did it and ordered an XL Enduro SE 29r.
    I've been eyeballing the XX1 group for a while now, and am thinking I would like the simplicity and weight reduction of the XX1.
    Question: What do I need to know about the Enduro's PF30 BB and Q factor limitations before I plunk down the cash on the groupset? Is it a straight remove and replace as long as the QF will clear the stays? I guess I just need to know what should I order?
    I'm also debating on 170mm crankset vs. the 175mm. I ride in chunky environments 9 out of 10 rides and find I'm striking on my XL 2011 Epic with 175mm cranks. It will only be exacerbated with the Enduro. Thoughts?
    Thanks guys!
    -Doug
    95% sure you will need the wide q factor cranks, you also know that you can't get an xx1 freehub for the stock wheels on the Enduro Comp?
    Aug 2010
    I ride an Enduro with the XX1 group. Get the 168, BB30 edition crank and you are good to go. If you don't like the SRAM chain rings, I use a North shore billet 1x10 spider and a wolftooth components chain ring, or a spiderless wolftooth components ring works great as well.
    Thanks guy's! #Floor Tom: Yea I know the free hub needs to be changed out too. I'm going to swap my existing I9/Flows to the Enduro. Hey, what's another hundred clams when I'm $1k deep?
  1. Enduro Evo VS Enduro Comp VS Stumpjumper FSR Comp
    By Klurejr in forum Specialized
    Last Post: 01-21-2014, 09:33 AM
  2. Remedy 29 or Enduro 29 Comp for AM/Enduro use
    By p2rider426 in forum All Mountain
    Last Post: 05-23-2013, 08:36 PM
  3. Replies: 3
    Last Post: 04-06-2013, 07:28 AM
  4. Replies: 25
    Last Post: 12-07-2012, 10:51 AM
  5. Replies: 18
    Last Post: 02-02-2011, 03:32 PM
