Results 1 to 5 of 5
    Reputation: Tarekith's Avatar
    Mar 2005
    Need Spec Tire recommendations
    Hey guys, my Stumpy came with Fast Trak tires and they're getting to the point of needing to be replaced. While I like them for the low rolling resistance, I would like just a BIT more traction in the looser conditions.
    Can anyone recomend a Spec tire that is close to the rolling resistance of the Fast Trak, but with just a bit more grip? These will be used for everything from loose singletrack to urban riding.
    Tarekith.com
    '17 Specialized Enduro Elite 29
    mechmann_mtb
    Guest
    not specialized but...
    i asked the owner of my LBS (a great mechanic btw) which tires i should go to considering weight, speed, and so cal terrain and he suggested the Kenda Cortez.
    http://www.kendausa.com/bicycle/JohnTomac.html
    i will soon be riding on the 2.2" version of these tires!
    Soft AND Tender
    Jun 2005
    Depends on where you ride...
    Tarekith - If a Spec tire is what you want I would recommend the Adrenaline Pro. Low rolling resistance and pretty darn sticky. I have these tires on my 05 Stumpy Pro and ride the rocky, rooty singletrack in Pennsylvania.
    If you are willing to go beyond Spec, I would recommend the Kenda Nevegal. 95% of the crew I ride with uses this tire and swears by them.
    Mar 2005
    Thanks guys, not entirely set on Spec, so I'll check out the the other recommendations as well!
    Tarekith.com
    I've found the fast trak is a great cornering tire (as well as RR) but for the rear the Roll-X from specialized works better
  1. UST rims
    By Zig in forum Wheels and Tires
    Last Post: 12-23-2004, 03:19 AM
  2. Tires at MEC
    By turbo ultrasport in forum Eastern Canada
    Last Post: 12-04-2004, 04:00 PM
  3. Blur rear tire choice thread from old boards
    By CraigH in forum Santa Cruz
    Last Post: 03-03-2004, 05:16 PM
  4. Advice with Stan no tubes sealent ?
    By Johny Rotten in forum Singlespeed
    Last Post: 02-13-2004, 03:39 PM
  5. Suggestions for WW FAQ section
    By Trevor! in forum Weight Weenies
    Last Post: 01-19-2004, 01:22 PM
