    Reputation: FrankRizzo's Avatar
    Need 2002 Stumpjumper FSR replacement crankset advice
    Looking for advice about a suitable replacement crankset for a 2002 Stumpjumper FSR XC. The middle and large rings of the original Specialized Strongarm II crankset are worn after 12 years and the large ring has a tooth missing.
    I wondering if the Shimano XT M770 crankset will work on the bike. I have it on my 2008 Enduro and I'm happy with it. But the BB on the Stumpy is an Octalink cartridge BB where the bearings are inside the BB shell (i.e. the BB is not much wider than the shell in the frame - 68mm). The BB of the XT crankset is the external variety which adds about 6mm of width on each side of the bike. I think this will move the chainrings that much further from the frame than the old crankset. The front mech is the e-type and doesn't look like it can be moved further away from the frame and even if that were possible the BB bearing cup will still be between it and the small ring.
    Anyone have this crankset on their 2002 Stumpy? Or can someone recommend an alternative?
    On wuss patrol
    Reputation: Glide the Clyde's Avatar
    Do the chain rings un-bolt or are they riveted? If you can change just the rings, why not simply get new ones? Much cheaper than a new crankset or trying another that my give chain line problems.
    And while you're at it replace the Stumpy BB. 12 years is a long time.
    Sometimes, you need to go fast enough that the trail is a blur to find clarity. -- Wild Bill
    The rings un-bolt so I could swap them. Can anyone recommend some rings? The XT ones look a lot thicker than the old Spesh ones. The BB feels a bit gritty so I think I will replace it.
    Fitted the XT crankset. Works after a bit of limit screw adjustment.
  1. 2002 Stumpjumper M4 for $350?
    By lucky53s in forum Specialized
    Last Post: 08-18-2014, 12:42 PM
  2. Replies: 12
    Last Post: 08-11-2013, 08:37 PM
  3. 2002 Stumpjumper FSR XC
    By eastsands in forum Specialized
    Last Post: 07-09-2013, 07:35 PM
  4. CL ad for 2002 Stumpjumper FSR Xc
    By tyscobe in forum Beginner's Corner
    Last Post: 04-09-2011, 11:38 PM
  5. Crankset 2002 Specialized Hardrock
    By GeorgeS2051 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-22-2011, 08:57 PM
