I just have my first real ride on my 06 Stumpy FSR and love it!! The only thing I noticed is the amount of dirt and stuff that acumulate around the bottom bracket, front derealiur and rear shock area. I fund a mudflap at Specialized.com but it only protects the shock and I want to protect all the area I mentioned. Thas anyone has what I'm looking for? What do you use and if you can post any pictures is better.
Thanks again.
Are you looking for a mud flap that protects your shock? Similar to the image below, (courtesy of Archangel and lite-bikes.) It works really well at keeping the mud off the shock itself. As far as keepin' it off the pivot points / bearings and f- derailleur I've seen some pics somewhere on MTBR that show some ingenious ideas of some guys jerry-riggin some plastic from milk jugs or rubber cut to fit / lay over those areas and tied on with zip ties. Good luck and here's mud in yer' eye! Spine Shank
Constructed from 1.5mm neoprene rubber with velcro closures, its on an 05 Enduro, but I'm sure it could be adapted for a Stumpy.
I plan to extend it down the back of the black shock link to stop stuff splashing onto the underside of the shock and front derailleur.
Specialized does sell a flap for 04-05 disc brake equipped Stumpjumpers that does indeed fit the '06 Stumpys. I had one ordered from the Bicycle Sports Shop here in Austin for ~$15. It fits the frame precisely and is held on with three zip ties.
Hey guys thanks for the sugestions.
Hey Spill, I like the one you are using, we even have the same bike and color!! I only upgraded the brakes to Avid Juicy 7.
and a bit off topic, but I see spesh is back to the black shock link for 06...DAMN them! I just built up my 05 Sworks, and it has that 'getrofit' silver link...the one after the frame contact issue they simply ground down. Being that my bike is black, the new one would look nice.
You may find, as I did, that the skinny zip ties break. The slots in the mudflaps accomodate wider zip ties, which work better. I'm running the 2 mudflap set-up and it works pretty well.
I like the look of the mudflap but I was wondering if it would fit other bikes. I got a Hardrock comp I have been looking for a mudflap and I cant stand those big fat ones that attach to the seat post and I just dont like the look of them and I found this one and i like it and am hopeing that it might fit my bike. thanks for the help
My problem is the side ziptie holes ripped away after a couple months, its too close to the edge or needs to be reinforced. So the middle one is the only only holding the thing on right now. I guess I'll try drilling a new hole further away from the edge. If that doesn't work, I'll probably just make my own like others.
My problem is the side ziptie holes ripped away after a couple months, its too close to the edge or needs to be reinforced. So the middle one is the only only holding the thing on right now. I guess I'll try drilling a new hole further away from the edge. If that doesn't work, I'll probably just make my own like others.Dave
That happened to me too, but only on one of the slots.
I heated up the tip of a small screwdriver with a lighter and melted a new hole, farther from the edge as you are thinking. Hasn't ripped through so far.
Hey druid, does the double mud-flap work well in keeping dirt/mud away from the front derailleur ?
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
