Results 1 to 16 of 16
    More 2011 Epic 29er questions
    I'm getting close to pulling the trigger on a new 2011 Epic 29er (non S-works frame), but I need to understand a few things a little bit better. First: does this frame accept any bottom bracket, or do you have to use a truvativ pressfit 30/bb30? If I do use the bb30, can I use a Shimano crank, or at this point are you forced to use a Truvativ crank?
    Also, I just noticed last night that the frame uses a direct mount front derailleur. Since I'm planning on swapping the drivetrain over from one of my current bikes, I was planning on staying with my 9 speed setup. Can someone confirm that I can use a 9 speed Shimano front derailleur on this frame? From what I can tell, I'll need to buy the E type front derailleur and then remove the bracket from it.
    Between the 142+ hub/rear triangle, the direct mount front derailleur and (possibly) the semi-proprietary bottom bracket, there is enough odd/weird/non-standard stuff about this frame to make my head hurt....
    Thanks for any and all help!
    Reputation: zippy895's Avatar
    Sup
    Reputation: Burnt-Orange's Avatar
    Dec 2008
    it has the standard 73mm bottom bracket
    you need the E derailleur
    Should come with a rear hub so you can build up a wheel for the rear
    got the same frame on order
    cant wait for it to get here
    SJ
    I am slow therefore I am
    Very useful link - although it sure would be nice if they had actually listed the non carbon 2011 Epic...
    Quote Originally Posted by SlowerJoe
    SJ
    Can you post up when you have gotten the frame. It would to confirm that the frame comes with the hub. Any idea when it's supposed to be delivered?
    Oct 2010
    BB alloy frame specs.
    Zip do you happen to have a spec. sheet for their alloy frames?
    Sup
    Dec 2008
    I will post pics when I get my frame
    most likely, there will be a winter background in the pics
    that is only about two weeks away here in the land of cheese
    Reputation: goneskiian's Avatar
    Sep 2004
    Quote Originally Posted by saiellos1
    They don't have one for the alloy frames because the alloy frames use regular 73mm bottom brackets.
    Sup
    Dec 2008
    Looks like my bike will be here by turkey day "per dealer"
    I will post pics as soon as it is in
    SJ
    SJ
    When did you place your order? Sounds like I night want to order soon if I want it by Xmas.
    An additional question. Can I use a remote lockout for the Comp 29 Epic Reba fork? Or do I need to change some internal stuff first?
    Sep 2004
    Quote Originally Posted by janowitz
    That would be a yes...
    http://www.sram.com/rockshox/products/reba-rlt
    The fork is a Reba RLT and Rock Shox says its compatible with the following remotes: PushLoc, PopLoc Adjust and Poploc.
    Cheers!
    Sup
    Dec 2008
    ordered at local bike shop
    I placed my order in early august
    guess the have two ships on the way
    might even get my roval's on the same day
    Sup
    Dec 2008
    double post
    Quote Originally Posted by goneskiian
    Cheers!
    Perfect. I missed that on my Ellsworth. Thanks for the quick reply Goneskiian.
    Man I cant wait for that bike to arrive. 2 more weeks, and it should be in.
    Let's fly!
    Reputation: MultiRider's Avatar
    Dec 2005
    My LBS said any MegaExo BB would screw right into the Comp Carbon frame. They also said that Specialized sells a sleeve that goes in the PF30 in the Expert frame that is the same sleeve in the Comp Carbon so any MegaExo BB would work on the Expert frame once the sleeve is installed.
