    Reputation: Cevan's Avatar
    Maintenance question for FS bikes
    I have an '04 Epic S-Works. I'm in the process of cleaning the rear shock. I've taken the shork right off the bike and took the carbon fiber link off. Should I taken the outer bearing seals off and clean/re-grease the bearings? It feels like there could be some dirt in the large bearings. While I'm at it, should I remove the other two pieces of the rear suspension and do the same? This seems like a step to take prior to replacing the bearings.
    Reputation: Murchman's Avatar
    I pull the seals from time to time on mine and repack them. I have over 2000 miles now on my first set of bearings and they are still going strong.
    Gravity Rides Everything
    Reputation: endurowanker's Avatar
    if you got it apart you may as well.
    Reputation: wrenchmonkey's Avatar
    Clean the whole lot.
    If you've got it apart do all the bearings, especially the seat/chain stay ones and the BB one. You can pop the seales off and clean and relube, or actually push the bearings out and replace them. I find that the small ones at the seat/chain stay almost sieze up after a while on my epic, so check them.
