Lost front wheel's QR nut from Stumpy Comp FSR 26" '12
The LBS which sold me the bike say they don't have a replacement, and I don't want to buy a new QR just for the missing nut.
I want to try to search for the part online, what exactly do I need to look for (dimensions etc.)?
Is there any short-term solution i can use until the part arrives?
Lost front wheel's QR nut from Stumpy Comp '12
Which 2012 Stumpjumper Comp is it? There are several different versions FSR, 29er hardtail etc which don't all come with the same fork.
It sounds like it's probably a DT RWS 9mm thru bolt:
http://www.dtswiss.com/Components/RWS/RWS-Thru-bolt-en
Superstar £7.99GBP for a 9mm front skewer
http://superstar.tibolts.co.uk/produ...roducts_id=286
Or maybe a 5mm quick release, although they're very common so a bike shop should have a spare nut lying around.
Halo Hex Key 5mm skewers £8.09GBP pair
http://www.wiggle.co.uk/halo-hex-key-skewers-pair/
My bad. It's a FSR 26". Updated title
The stock front skewer on that bike is a DT RWS 9mm thru bolt.
http://www.specialized.com/us/en/bik...rfsrcomp#specs
Thanks! So can I try to mix-and-match any other nut that fits a 9mm axle with mine as a replacement?
Sounds like it should work.
By illgobigger in forum General Discussion
Last Post: 04-20-2013, 02:14 PM
By smac45 in forum Colorado - Front Range
Last Post: 03-29-2012, 11:53 AM
By snowdrifter in forum Vermont, New Hampshire, Maine
Last Post: 08-27-2011, 11:05 AM
By kyle10bike in forum Colorado - Front Range
Last Post: 05-18-2011, 05:47 PM
By buxfan75 in forum Colorado - Front Range
Last Post: 04-05-2011, 07:46 AM
- You may not post replies
- You may not edit your posts
Forum Rules
