Results 1 to 5 of 5
    Jan 2011
    Just Purchased a Used 2010 FSR XC Comp
    It seems to be a bit heavy and without putting to much money into it... Do you guys/gals have any suggestions on what I could do to lighten it?
    I am a bit of a newb.
    Your input is much appreciated.
    Bike Addiction
    Reputation: 00sable's Avatar
    Check your tires. Mine came with Captains wire bead. I believe you can get lighter ones. I put Kenda Neves 2.1 and they are slow rolling but lighter. I also bought a used air fork that is about a pound and half lighter than the Tora 302 SL Coil. Mine weighed 32 lbs before and is around 29ish now. Wheel upgrade if you have the money. I'm still looking and saving for those. Crank and cassette are a little heavy too. Its almost endless. Good bike though.
    Disclaimer: Always get a second opinion cause I'm just guessing
    Quote Originally Posted by 00sable
    Pretty much spot on I reckon. The rims aren't the strongest too.
    Tyres and inner tubes might be a good bet. Kevlar folding tyres is what you want to save the weight or even go tubless.
    Good bike though. I've enjoyed mine since I got it.
    Bike Addiction
    Most of the Stumpjumper parts are interchangeable. I've been buying used SJ parts from some of the guys I ride with as they upgrade.
    Jan 2011
    My wife is actually going to be riding this bike, she is probably 105 pounds soaking wet. So I really am not to worried about the rims.
    Mainly , I am just trying to reduce the wait, because it will help her get up those tough hills .
    It does sound like the forks and the tires is the way to start.
    I am currently riding
    2002 Jekyll 3000
    Front Shock - Headshok Ultra SL 80mm travel
    Rear Shock - Fox Float RL W/lockout
    Rims - Mavic Crossmax UST Tubeless
    Hubs - Mavic Crossmax
    Tires - Michelin XCR dry2 Tubeless (just replaced, only two short rides)
    Pedals - None
    Crank - Cannondale CX-2; 44-29
    Chain - Sram PC99, Hollow pin.
    Rear Cogs - XTR , 11-34
    Bottom Bracket - Shimano XTR
    Front Derailleur - Shimano XT
    Rear Derailleur - SRAM X0
    Shifters - SRAM X9- Trigger
    Handlebars - Answer Riser Carbon
    Stem - Cannondale
    Brakeset - Magura Marta SL
    Brakelevers - Magura Marta SL Carbon
    Saddle - Specialized Phenom
    Seat Post - Alien Carbon
    Color -Ball Burnished Aluminum
    Weight - 23lbs 9oz (without pedals)
