Results 1 to 8 of 8
    Feb 2014
    Installing XT front derailleur on 2013 Stumpy FSR
    I want to upgrade the SRAM X7 front derailleur to a Shimano XT on my 2013 Stumpy FSR so I purchased a E type 2x10 to replace the front.
    Can someone let me know how I can replace the derailleur? Do I need to pull the drive side crank to replace the derailleur or can I access the screws without the chain rings interfering?
    Oct 2012
    You need to pull the cranks. You need a big ass allan wrench for breaking the bolt loose on the cranks. While you got things apart check your bottom bracket bearings for wear.
    Dusting Trails
    Reputation: matuchi's Avatar
    Quote Originally Posted by Kevjer1 View Post
    I'm thinking about doing the same thing on my 2014 Camber Comp Carbon - did you notice much of a differance?
    Feb 2014
    I like the higher end Shimano stuff just for consistency. I had to pull the crank. I have since gone to a 30t raceface NW chainring and a 40t one up ring with Radr cage.
    I did find the shifting good last season with the XT front.
    Dusting Trails
    My older StumpJumper Comp had everything XT and it worked great for years. My Sram X7 FD keeps hanging up going to my large chainring - even after numerous bike shop adjustments. The XT FD isn't too expensive so I'm really thinking to change it to a XT like my rear derailleur.
    Sram FD not all that impressive as a whole. Shiamno for the win. You should use the same hardware that is with your sram fd if it is a straight swap
    Reputation: t3mplar's Avatar
    Jun 2013
    You will need a 10mm allen wrench and will have to re-use the mounting bracket the current SRAM FD uses.
    I also upgraded to the XT and was much happier.
    Dusting Trails
    Quote Originally Posted by t3mplar View Post
    Thanks - I'm going to do it on Thrusday!
  1. 2013 rip9 alloy, front derailleur issues?
    By snowdrifter in forum Niner Bikes
    Last Post: 08-23-2013, 10:13 AM
  2. Replies: 2
    Last Post: 07-22-2013, 07:51 PM
  3. 20009 Stumpy FSR front derailleur help
    By hasbeen in forum Specialized
    Last Post: 06-06-2013, 07:06 PM
  4. Installing a X9 type 2 derailleur help?
    By Yuri Natenpuhl in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-01-2012, 11:13 AM
  5. 2010 S-Works Stumpy FSR front derailleur?
    By Brewer50 in forum Specialized
    Last Post: 07-21-2011, 08:40 PM
