Results 1 to 16 of 16
    Reputation: KeepTheRubberSideDown's Avatar
    Identify my Specialized Stumpjumper...
    I am looking for some help to identify a Specialized Stumpjumper hardtail. I looked through the Specialized archives and searched this forum but did not find a match. These are the details that I currently have
    Frame- Specialized Stumpjumper Pro (Black w/ red decals)
    Fork-Rock Shox Sid
    Drivetrain- XTR rear derailleur,
    Brakes- Avid v-brakes
    I won't be getting the bike until the spring so I don't have any pictures yet. I believe that it would be a 2002 or older because it has no option for disc brakes. I am not sure whether someone has any pictures of this bike, or if there happens to be any online Specialized catalogues that I could use.
    Thanks for your help...
    Looking to buy Vintage Brodies, Rocky Mountain's and steel Dekerf or Cove hardtails.
    I am fairly sure it is a Pro similar to this one posssibly just a different year...
    I have an older stumpy pro frame hangin' on the wall.(2002, Top tube dented) and it has disc mounts. 2003+ have the ORE downtubes.
    Livin' the dream.
    Quote Originally Posted by oldskoolm4
    So it must be older than 2002 then. Unfortunately the Specialized archives only go as old as 2002.
    NormalNorm
    Reputation: norm's Avatar
    Feb 2005
    I'm putting money on 2000. The sids were on the 2000's.
    Reputation: Stumpy Jules's Avatar
    Apr 2005
    That looks like a 2002 model. Mine is very similar to that...
    2008 Enduro Expert
    2010 Santa Cruz Blur LT
    2013 Yeti SB66 (WIP)
    We want... a shrubbery!
    Reputation: ickyickyptngzutboing's Avatar
    Mar 2005
    1999 or 2000 -- But I'm not certain. I had a '99 FSR XC Stumpjumper Pro with the SID XC on the front that matches your description. Black frame, red (with whitish/gray) decals. It was stolen a few years back, but I'll post a pic of that paint scheme if I can find a pic.
    waaahoooooooooooooooooo
    Calvin : Ahhh, another bowl of Chocolate Frosted Sugar Bombs! The second bowl is always the best! The pleasure of my first bowl is diminished by the anticipation of future bowls and by the end of my third bowl, I usually feel sick.
    Hobbes : Maybe you shouldn't use chocolate milk.
    Calvin : I tried Cola, but the bubbles went up my nose.
    If anyone has pictures of 2000 or older model Specialized Stumpjumper Pro hardtails could they please post them up. Thanks
    RXL
    RXL is offline
    1999
    http://www.bikepedia.com/QuickBike/B...4113&Type=bike
    Quote Originally Posted by bikepedia
    Sugg Retail: $1,599.99
    Weight: Unspecified
    Sizes: 13.5", 15.5", 17", 18", 19", 20.5"
    Colors: Gloss Black
    Frame & Fork
    Frame Construction: TIG-welded
    Frame Tubing Material: Specialized M2 XX Metal Matrix
    Fork Brand & Model: Rock Shox Sid XC, 2.5" travel
    Fork Material: Aluminum/magnesium, triple-clamp crown
    Rear Shock: Not applicable
    Components
    Component Group: Mountain Mix
    Brakeset: Shimano Deore XT V-Brake brakes, Shimano Deore XT levers
    Shift Levers: Shimano Deore XT RapidFire SL
    Front Derailleur: Shimano Deore XT top-swing, bottom-pull/clamp-on 35.0mm
    Rear Derailleur: Shimano XTR SGS
    Crankset: Specialized ForeArm Elite, 22/32/44 teeth
    Pedals: Not included
    Bottom Bracket: Specialized Elite, 107mm spindle
    BB Shell Width: 73mm English
    Rear Cogs: 9-speed, 11 - 32 teeth
    Chain: Shimano CN-HG72, 1/2 x 3/32"
    Seatpost: Ritchey Expert, 30.9mm diameter
    Saddle: Specialized Carbotech
    Handlebar: S-Works 140g
    Handlebar Extensions: Not applicable
    Handlebar Stem: Specialized A-1
    Headset: 1 1/8" threadless Specialized Headfirst Comp
    Wheels
    Hubs: Specialized STOUT
    Rims: Mavic X222, 32-hole
    Tires: Front: 26 x 1.95" Specialized Dirt Control Team, Rear: 26 x 1.95" Specialized Dirt Master Team
    Spoke Brand: DT stainless steel, 1.8mm straight gauge
    Spoke Nipples: Alloy nipples
    2000
    http://www.bikepedia.com/QuickBike/B...5635&Type=bike
    Sugg Retail: $1,779.99
    Weight: Unspecified
    Colors: Pearl Yellow/Red
    Frame & Fork
    Fork Brand & Model: Rock Shox Sid XC, 3.15" travel
    Components
    Brakeset: Avid SD-Mag brakes, Avid SD-Mag levers
    Crankset: Specialized Strong Arm 2 Pro, 22/32/44 teeth
    Pedals: Specialized Comp
    Bottom Bracket: Shimano BB-UN72
    BB Shell Width: Unspecified
    Chain: Shimano, 1/2 x 3/32"
    Saddle: Specialized Revolution
    Handlebar: Specialized alloy
    Handlebar Extensions: Not included
    Handlebar Stem: Specialized alloy
    Headset: 1 1/8" threadless Tange Seiki alloy
    Wheels
    Hubs: Specialized Micro STOUT
    Rims: Mavic X517, 28-hole/32-hole
    Tires: Front: 26 x 1.90" Specialized Dirt Control Team, Rear: 26 x 1.90" Specialized Dirt Master Team
    Spoke Brand: DT stainless steel, 1.8mm double-butted
    I would put my money on it being the 1999. Thanks for the help!
    It is a 2002 Stumpjumper Pro.
    Does it look anything like this one? I too am wondering what year mine is and what it might be worth today.
    May 2013
    I also have this bike, and I am wondering what year the frame is.. Anyone? Mine is for sale.. mine is mostly stock.
    Quote Originally Posted by karenflowers View Post
    That's either a 1997 or 98. Had the exact same bike.
    MCH Co-Captain
    1997. had the same one, just sold it a couple years ago.
    ijd
    ijd is offline
