Results 1 to 40 of 40
    I want an Enduro 29er hardtail.
    I love my Enduro 29er so much, I would love to see specialized do a hardtail version. I think it would be such a blast.
    I want a full carbon frame. Same low standover, low bottom bracket, shorten the chainstays even more, but keep the tire clearance. Offer it with a Pike or a rigid fork option.
    I have a fully rigid titanium 29er that I use as a training bike to keep my skills sharp, I have it set up to shred (short stem, wide bar, platforms, big tires).
    I think a hardtail Enduro 29er would be sick, snappy, and fun.
    Specialized are your listening????
    Bro Mountainbiker
    Reputation: Sheepo5669's Avatar
    May 2010
    Quote Originally Posted by morandi View Post
    2015 SJ Ht EVO model may be as close are you are going to get. At 120mm w/ a pike it appears to be a pretty sweet ride. Aluminum frame though...
    Also you would have to pull off that crap OEM dropper and replace it with a Lev.
    Raised in a Chicken-Coop by Chickens
    Not even close to what I have in mind. That thing is way too vanilla.
    Reputation: Biking Brazilian's Avatar
    Fat bike
    I've always thought it was weird that the Stumpy FSR and the Stumpy hardtail were such different beasts. Personally I'd love it if the Stumpy hardtail became an all mountain hardtail, with a similar look to the FSR, and the current Stumpy hardtail be called the Epic hardtail (which would make more sense to me anyways).
    Quote Originally Posted by Biking Brazilian View Post
    Fat bike
    I don't want a fatbike. I want something that rails. That jumps well, accelerates, and is fast as hell. That is not a fat bike. I want an Enduro 29er Hardtail!
    Bro Mountainbiker
    May 2010
    I think it's funny that if you actually jump a stump it voids the warranty.
    Jun 2013
    They actually had an Enduro hard tail in 2001, so this isn't that unrealistic.
    I miss Jim Anchower.
    2014 Trek Remedy 8 29er
    2003 Gary Fisher X-Caliber
    I have the closest thing in a hardtail to complement my enduro 29, a kona honzo. Never thought I would own a kona but it's a super fun little hardtail that has a wicked short rear end.
    Bro Mountainbiker
    May 2010
    I loved my honzo so much!!!! I just sold it though to try out this new "goldielocks" wheelsize...
    I really wanted a 26er, but the thought of resale scared me.
    Oct 2012
    The new stumpy ht evo has a 120mm pike, 142x12 rear axle, wierd dropper, 1x10, 68 hta, and tapered headtube. Its way beefier than the previous stumpy ht evo.
    Specialized Bicycle Components
    I think its a sweet ride, however I like the way steel rides than aluminum. I recall specialized did make an enduro ht but that was awhile ago. I would like to see an steel 650b stumpy evo ht with 140mm fork.
    A Canfield yelli should do the trick....
    Sep 2014
    sorry posted in the wrong forum
    JCL
    JCL is offline
    Hardtails suck.
    What I want is an Epic with no Brain, exact Camber Evo geometry, 30.9mm seat tube and stealth routing, tire clearence for 29x2.5" and 24lbs in a medium with a 100mm Revelation.
    i have the 2015 SJ hardtail and really like the feel of it except my preference would be for the frame to be in carbon
    Rocks belong
    Diamondback Mason 29er
    66.5* HTA
    17" chainstays
    Mine is set up with a
    Fox 34 RLC
    KS Lev dropper
    1x10 with Wolftooth 42T
    55mm stem, 780 carbon bars
    B+ rear end with WTB Trailblazer 2.8 rear
    It's an alloy frame though... but the big tire helps
    I've got a WTB Scraper i45 front wheel built up that I intend to use with a 3.0" 650b tire (when they ever come out).
    Attached Thumbnails Attached Thumbnails I want an Enduro 29er hardtail.-img_3472.jpg
    I like 'em long, low, slack and playful
    evilbanks
    Reputation: b_banks's Avatar
    Niner ROS 9. Steel frame but you should do it anyway.
    Rocks belong
    Quote Originally Posted by b_banks View Post
    Short reach, tall standover (so you can't size up)... The bikes provided for reviews all had 70-90 mm stems with 780 bars. Kinda surprised Niner missed the mark on that one.
    Supposed to be a very smooth riding frame though.
    Reputation: CarManDSL's Avatar
    Quote Originally Posted by 06hokiemtb View Post
    diamondback mason 29er
    66.5* hta
    17" chainstays
    ditto!
    Rode one on Maui in Makawao Forest last year.
    A BLAST!
    18 Instinct C90+ BC Ed -28.6 lb
    17 990 Element BC Ed -25.5 burly
    15 Enduro Expert 29-SW build -27.6
    12 Niner Air9RDO -16.4
    Rocks belong
    Quote Originally Posted by CarManDSL View Post
    ditto!
    A BLAST!
    They are slack, long and angry
    My preference was carbon well. I have a carbon SJ FSR as well, but this new Evo has not disappointed. I was also prepared to switch out to 1x11 and found i dont need it
    Rocks belong
    Up until 2015, the Transition TransAm has a short reach as well.
    A ROS 9, size medium, has a reach of 16.2 with a Fox 32 120 fork and 15.7 with a Fox 34 140 fork. Large is 16.8 & 16.3, respectively.
    So a 120 Pike (which is what this type of bike really needs) would yield a reach of 15.8-15.9"... that's not long in my book. Thus the complaints in bike reviews about needing to run a 70-90mm stem with 780 bars.
    A large Niner RIP 9 RDO, for example has a 17.1" reach (120) & 16.7" reach (140)... Now that's more like it.
    A large Jet 9 RDO, for example, has a 17.5" reach (100) and 17.1" reach (120).
    An XL ROS 9 is sized similarly to a L RIP 9 or Jet 9.
    Rocks belong
    Quote Originally Posted by 06HokieMTB View Post
    I guess I'll clarify more here.
    The OP wants an Enduro HT. Which means he'll want something long, slack and angry. I'm guessing he'll want to run 780 bars and a 40-50mm stem. And a burly fork.
    For that reason, I recommended the DB Mason. It's the slackest and comes with a 140 Fox 34. Hard to get much angrier for a 29er HT.
    I'm running my Fox 34 at 130 and like it there. I've ran at 120 and it feels like an angry XC bike. Running at 140 makes it feel like a monster (so much so, that you forget it's a HT until you land...)
    A Kona Honzo and Yelli Screamy would also work great. Just keep in mind a 140 fork on those will relax your STA.
    The new TransAM 29 is spec'd with a 120 Pike and has a 17.4" reach (for size large), and a 67.5* HTA to boot. That would be a fun bike with a 120, 130 or maybe even a 140 Pike.
    This.
    Yeah, there are a handful of frames in various other materials that fit the bill, but where's the CARBON?
    ditto!
    A BLAST!
    Did you rent that from Krank? I rode a Process 134 in Makawao about a year ago on my honeymoon but it has rained and it was like riding on hot peanut butter.
    Quote Originally Posted by hjulier View Post
    Yes. Rented Mason for one day and thought I'd try the Process the next. I enjoyed the Mason so much I rented it the next as well!
    I lucked out and had dry days in Makawao.
    Oct 2014
    kona honzo, fun bike with a good headtube angle (68 degree), very nimble, or the Canfield Nimble9, first choice Honzo 2015 has a much better standover
    Feb 2006
    I think the Canfields might have just created such a beast:
    Canfield Brothers EPO Carbon 29er
    Sep 2014
    Quote Originally Posted by powdertrax View Post
    I've been rocking a 2015 Honzo with a 140mm fork the last 3 months. Climbs sweet and descents even better. I've bombed lots of gnarly stuff and have gotten way better descent times with it than I did with my fs trail frame. The low stand over and long top tube makes it really easy to move it around in the cockpit. I'd vouch for it as a really sweet hardtail enduro or AM bike
    Oct 2014
    Quote Originally Posted by brickwallmusic View Post
    I've been contemplating switching to platform pedals, I currently run Time Z clip/flat pedals and have been running clip-ins for almost 30 years, but thinking of flats. What are you running on your Honzo ?
    Sep 2014
    I use crankbrothers egg beaters, part because I've done a lot of xc, part because when the bike is really bouncing around I never have to worry about falling off the pedals or trying to find them.
    Quote Originally Posted by Thaumaturge View Post
    This was exactly what I was after. Canfield checks all the boxes. Now I just need the dough and the space.
    Reputation: Raleighguy29's Avatar
    Jan 2014
    Chromag did it with the rootdown
    Quote Originally Posted by Raleighguy29 View Post
    Great bike. Not Carbon. The Canfield is the closest to my original wish list.
    Jan 2014
    I'm not a carbon guy but the new Canfield Epo is just bad ass!!
    Pretty good at everything, but not really good at anything!
    Canfield Brothers
    Reputation: flymybike's Avatar
    Good ride last night, loving the EPO! I over shot a jump and flat landed so hard, It blew about 1/3 of the tire off the rim. Gotta love tubeless, was able to limp it home with just low pressure.
    http://www.canfieldbrothers.com/frames
    Building bikes that make you smile!
    www.mtbparks.com
    All Bike Park, All the time.
    can you tell me how you built the bike out with components...I am just looking at that now and trying to price it all up....gulp!
  1. Long Enduro on a xc hardtail
    By Powell in forum 29er Bikes
    Last Post: 07-26-2014, 05:54 PM
  2. Long Enduro on a xc hardtail
    By Powell in forum General Discussion
    Last Post: 07-25-2014, 09:40 AM
  3. Enduro or Hardtail for AZ. riding
    By street glide in forum Arizona
    Last Post: 11-20-2011, 07:10 AM
  4. Replies: 3
    Last Post: 10-20-2011, 05:33 PM
  5. My Enduro Hardtail........Sobre OFF
    By steph89 in forum All Mountain
    Last Post: 03-28-2011, 12:35 PM
