Results 1 to 6 of 6
    Reputation: Justinm860's Avatar
    Apr 2013
    I need to replace a pivot bolt
    Where can I get a replacement I bent mine the other day. It's the one that holds the rear shock in place (bottom of shock)
    The bike is a 2004 specialized FSR XC
    Apr 2013
    Re: I need to replace a pivot bolt
    Anyone?
    old fart
    Quote Originally Posted by Justinm860 View Post
    Anyone?
    Your best bet is your LBS who can order the part from Specialized. Failing that, access the Spec website, got to Support, and find your bike (if still listed) and locate the part from the frame schematic. This part number would assist the LBS.
    May 2013
    Why don't you take the bent bolt to an industrial supply store and see if they have one?
    Apr 2013
    Quote Originally Posted by skiwi View Post
    It's no longer supported its an 04
    old fart
    Then remove the bolt, and take it to your LBS and see what they have laying around. Alternatively take it to an engineering supplies store and get them to source/make one for you.
  1. Replace 3/8" shock bolt for 8mm?
    By Olaven in forum Shocks and Suspension
    Last Post: 05-06-2013, 04:28 PM
  2. Replace 3/8" bolt for 8mm?
    By Olaven in forum Santa Cruz
    Last Post: 05-02-2013, 06:51 AM
  3. ASR-5C - Broken Pivot Bolt...
    By kev1n in forum Yeti
    Last Post: 02-17-2012, 03:32 PM
  4. Need to replace crank bolt on 07 stumpy (truvativ stylo)
    By singletrkmind in forum Specialized
    Last Post: 10-11-2011, 08:51 AM
