Results 1 to 6 of 6
    I need help fast! Will this wheel fit my 2012' Stumpy 29er HT?
    WTB Stryker TCS Cross Country Race 29" Rear Wheel - Overweight Code W
    WHEEL SIZE: 700c
    WEIGHT: 750 grams
    SPACING: 135mm
    SPOKES: Sanvic Triple Butted 3mm Bladed 3X
    SPOKE COUNT: 32
    LACING PATTERN: 3 Cross
    RIM WIDTH: 19mm
    RIM BRAKE SURFACE: Aluminum
    DISC COMPATIBLE: Yes
    TUBELESS COMPATIBLE: Yes
    TUBELESS READY: Valve/Rim Tape installed - need sealant
    SKEWERS INCLUDED: Yes
    ACCESSORIES INCLUDED:
    I believe the hub I have now 142+ is there an adapter or are parts removable from the existing wheel to make the 135 work? Having hell finding correct info.
    amd
    amd is offline
    Oct 2011
    Pretty sure the '12 stump hts had 135mm rear hubs. Actually I'm almost positive they did. Specialized archives should show you that info on the specs.
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    Correct, all current Stumpy HTs have standard 10x135 rears....
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
    Reputation: WR304's Avatar
    The WTB Stryker TCS 29 rear wheel you linked will fit in a 2012 Specialized Stumpjumper hardtail 29 frame without any modifications or changes required.
    Assuming your current wheel is the one that came with the bike it won't be 142+. The 2012 Stumpjumper hardtail 29 frame has standard 135mm rear spacing and uses a quick release skewer:
    http://www.specialized.com/gb/gb/bik...bon29xtr#specs
    The new 2014 Stumpjumper hardtail 29 frame has 142x12mm thru axle rear dropouts and comes with a 142+ freehub but the older frames don't.
    http://www.specialized.com/gb/gb/bik...umper-29#specs
    Thanks guys! Got it ordered in time 20% off came to around $400 total with shipping. Hopefully that's a decent deal. (Well with the front wheel too)
    Reputation: Mr. Lynch's Avatar
    Jun 2010
    I had a set of those on my Rockhopper Pro 29er HT and I loved them. They setup tubeless super easy and spin up real nice. My only complaints would be the low engagement and the fact replacement spokes are tough to find, although I never did break any.
    $400 is a great price for a set!
    14 Aurum, 16 Fuse, 17 T130
  1. Stumpy 29er Wheel Upgrades
    By GnarBrahWyo in forum 29er Bikes
    Last Post: 10-30-2012, 01:48 PM
  2. 2012 Stumpy EVO HT 29er + 29er Epic
    By MARKtheSHARK in forum Specialized
    Last Post: 01-28-2012, 05:08 PM
  3. 2011 stumpy 29er or 2012 stumpy 29er
    By torque29er in forum 29er Bikes
    Last Post: 12-15-2011, 09:33 PM
  4. Replies: 11
    Last Post: 12-03-2011, 11:32 PM
  5. My new 2012 Stumpy FSR 29er S-works :)
    By 125mph in forum Specialized
    Last Post: 12-01-2011, 07:43 AM
