I recently switched to a 1x drivetrain and since I only have one shifter I wanted to see if I could use a front shifter to operate my Command Post. The 2nd and 3rd Gen Command post uses a regular derailleur cable, so I figured it would be fairly easy to make it happen.
I have an XX1 drivetrain on my bike, so the closest match I could find was an XX 2x front shifter. The XX front shifters only come in 2x, but you can use a 3x from another line. The 3x has more range of movement, but I found the 2x range to be perfect for operating the Command post.
(More info/pix for trigger shifter setup coming soon but here is a peak at the final results)
Results 1 to 10 of 10
Hot DealsContestsLatest Mountain Bike ArticlesVideosMTBR on Facebook |
LinkBack URL
About LinkBacks
