Results 1 to 9 of 9
    Sep 2012
    How strong is an Enduro frame?
    How strong would you say the frame of an Enduro would be on a scale of 1 (weak) to 10 (strong).
    Mainly talking about the 2008/2009 model frame, but I'm still interested on current model too if you have an opinion.
    I'm trying to gauge how much abuse my bike can take and what to steer clear of.
    Dec 2011
    10. Unless you are attempting 100 ft. drops, you should be fine.
    Reputation: Dirttrackin280h's Avatar
    I don't know but my 11' has taken quite a beating with absolutely no problems besides breaking a couple spokes on the rear rim (but that's given). I would rate it pretty high on the scale. Not sure about earlier years but the 10'-12' are strong bikes from my experience.
    U should worry more on how strong are the wheels first , then strength of the suspension and lastly the frame . Is the flow of impact tat matters.
    Sep 2012
    Quote Originally Posted by Locksley View Post
    I see your point, but the thread is about the strength of the frame, not which piece will buckle first.
    Dec 2011
    Quote Originally Posted by igiantsquid View Post
    His comment shows that the strength of the frame is high enough that you need to worry about other parts first. If you are going to ask a question in this forum, be prepared to get all kinds of answers. Don't get sassy just because it is not a black and white answer.
    Sep 2012
    Quote Originally Posted by aaronpass View Post
    His comment doesn't answer the question and is instead a presumption that an answer he thinks needs giving.
    Keeping the subject on subject is not getting sassy, just a filter.
    Dec 2011
    That was his form of answering the question, it was not off topic at all.
    Frames these days are built to withstand a whole lot. If you are genuinely concerned about riding it hard enough that the frame would break, I would contact the manufacture. As you should be sponsored by them, if you are going big enough to be breaking the frame.
    It is a class 4 out of 5 bike so an 8.
    specialized.site
    /collateral/ownersguide/new/assets/pdf/2012-Bicycle-Owner-s-Manual-Appendix.pdf
