Results 1 to 16 of 16
    Mar 2013
    How lite is your Epic Comp Alloy?
    Just wanting to see how lite people have got the Epic comp alloy.
    Reputation: Scottesq's Avatar
    I have mine down to 26 lbs, I replaced the wheelset with Roval SL, the shifters, derailleurs and drivetrain are now x0, the front fork is a Sid RL, the saddle is a phenom pro, the handlebar is a Specialized Carbon mini riser and the Seatpost is a Thomson Masterpiece, but the brakes are stock
    2013 Epic Comp 29er
    2014 Stumpjumper Evo HT
    2011 Roubaix
    Mine is also 26 or slightly under.Arch ex wheels,rocket ron and ralph tires.Tubeles.Xo cranks,xx bottom bracket,xg cassette,xx front and rear derailleurs.Xo brakes.Carbons bars,foam grips,carbon seatpost,phenom pro saddle.Xo shifters.Has a 180 disc on front.Cost a few dollars but its a great bike now.Its a 2013
    Mines a 2013 as well
    2013 Epic Comp 29er
    2011 Roubaix
    I take 14,000 ft drops
    I have a 2010 epic comp medium 29 that weighs in a 25lbs4oz; XX1, ec90 bars/post, Stans arch's, nobby nics set up tubeless. Trying to find out if I can get a newer
    stumpy built up to a similar weight.
    That's impressive
    2013 Epic Comp 29er
    2011 Roubaix
    Nov 2012
    I have a 2013 Epic Comp that weighs 23.8 lbs. XX1, Enve bars, Enve seatpost, stock saddle. GC front and Fasttrack rear. If I swapped out the heavy stock saddle and put renegades front and back it would probably be under 23.
    Quote Originally Posted by enderjs View Post
    Wheels?seems very lite for little done
    2013 epic comp
    2013 supersix evo
    how big a difference (not only weight) will D'Aluisio Smartweld make? is it comming to epic in 2015?
    I think low 24's/ high 23's is about as low as you can go. I've had a carbon comp at 24# with a power meter and all high end stuff while I was in between frames. My new WC S-Works weighs 22# with a power meter.
    Pretty good at everything, but not really good at anything!
    A Smart weld aluminum Epic would be very interesting. I have an Allez and it is on par with some of their best carbon.
    Feb 2005
    My large 2010 is 26.25. Currently has XX drivetrain, X-Max wheels w/ snakeskin Ralphs, Ritchey seatpost, Phenom Ti saddle, Syntace stem, Easton Haven Bars and Juicy 7 brakes.
    After the Ouachita Challenge next weekend it's getting X01 and Mavic SLR's w/ EVO Ralph's. Should be interesting to see how much it drops.
    I have heard that the alloy frame is only .6 lbs heavier than the carbon
    2013 Epic Comp 29er
    2011 Roubaix
    Jan 2011
    Quote Originally Posted by Scottesq View Post
    There is a 200g (0.44 lb) difference just between the Carbon Expert and Marathon due to the carbon seat stays on the Marathon vs all-alloy rear of the Expert.
    So I'd find 0.6 lb difference between carbon (even the 10m) and alloy difficult to believe.
    I get my information from a friend who went from a comp to an S works.
    2013 Epic Comp 29er
    2011 Roubaix
    Feb 2005
    Update on my earlier post.
    I completed the X01 crank swap. Removed the shifter, housing, and front derailleur. Changed my C29ssmax's to new SLR's w/ EVO Ralph's which brought it from 26.26 to 24.84.
    Sent from my DROID RAZR using Tapatalk
  1. Replies: 44
    Last Post: 01-08-2014, 08:13 PM
  2. 2013 spec EPIC COMP (alloy) $1999.00 + tax
    By mxadam579 in forum All Mountain
    Last Post: 09-30-2013, 12:37 PM
  3. 13epic comp alloy with upgrades or epic expert?
    By montana_ben in forum Specialized
    Last Post: 06-14-2013, 11:15 AM
  4. 2013 Epic Comp (Alloy) vs. Giant Anthem X
    By GT5050 in forum Specialized
    Last Post: 01-07-2013, 01:05 AM
  5. Replies: 0
    Last Post: 01-29-2012, 02:47 AM
