Results 1 to 5 of 5
    Reputation: Mark in Baltimore's Avatar
    How do you remove the S-Works/Specialized under top tube cable guides?
    I'm trying to put clear protective film on my bike (Frameskin) and need to remove the shifter housing cables under the top tube. However, I can't seem to figure out how to remove the cable guides. At first glance, it looks like a small allen wrench would fit, but it doesn't. I hope I don't have to undo the front and rear derailleur cable to get clean access to the underside.
    Any help would be appreciated!
    Attached Thumbnails Attached Thumbnails How do you remove the S-Works/Specialized under top tube cable guides?-img_0088-medium-.jpg
    How do you remove the S-Works/Specialized under top tube cable guides?-img_0089-medium-.jpg
    '12 S-Works Stumpjumper carbon HT
    '13 Specialized Carve Comp
    '94 S-Works M2
    waiting for a piece (.45)
    Reputation: SpecialWarr's Avatar
    I thought those were Torx bolts!!? I'll head up into the showroom and see if I can find one.... bringing my coffee with me...
    Nevermind... those are rivets and can't come off... BUT there are cutouts in the mylar sheet to be able to work around the cable retainers no?
    Thanks for the reply! Nope, neither torx bolts nor allen bolts. There has to be a way to get these things off.
    '94 S-Works M2
    Quote Originally Posted by SpecialWarr View Post
    Thanks for looking. Yes, there are cut-outs, but I still have to unfasten both derailleur cables to pull them out of the guides. It's just one more step that I wanted to avoid. I appreciate your help!
    '94 S-Works M2
  1. Cable guides
    By griffter18 in forum Specialized
    Last Post: 02-03-2013, 09:43 PM
  2. Scalpel Cable Guides?
    By Thatshowiroll in forum Cannondale
    Last Post: 10-11-2012, 07:01 AM
  3. 2nd gen Jekyll Riders: top tube cable guides
    By atonyc68 in forum Cannondale
    Last Post: 10-04-2012, 10:49 PM
  4. Cable guides with TIG bronze
    By febikes in forum Frame Building
    Last Post: 02-09-2012, 08:10 PM
  5. Specialized 3 cable guides for Scalpel 29
    By wallyh3 in forum Cannondale
    Last Post: 01-31-2012, 08:51 PM
