Results 1 to 5 of 5
    How to determine the frame size on Specialized bikes?
    I have an 07 Stumpjumper FSR and my wife has a 94 Hardrock and we are thinking about getting some “new” bikes off Craigslist. We like the size of our current bikes and we’re wondering how to figure out what size they are. Thanks
    Per the Specialized Website:
    How do I determine the size of a bike I own?
    Published 10/14/2008 01:26 PM | Updated 01/13/2011 01:50 PM
    Q: How do I determine the size of the bike I own?
    A: First, Look over your frame to see if there are any stickers indicating its size (for example: 17, 19, M, L, 56, 58 etc...) If a sticker indicating the size does not exist, then follow these simple steps:
    1. Measure the length of your bicycle's head tube. The head tube is the part of the frame that the front fork inserts into. It is the forward most part or 'tube' of the frame and it is arranged in a slight angle off of vertical. You will need to measure this length in millimeters.
    2. Once you have the length of your bicycle's head tube in millimeters, you can then compare that length to the geometry chart for your corresponding year and model of bicycle. A geometry chart is a chart that lists all of the important measurements of your bicycle's frame in relation to each size the bicycle was made in. The geometry chart for your specific model and year (as well as other valuable information about your specific bicycle model) can be found in the archive section of the specialized.com website. The archive section can be found by hovering your mouse cursor over the red Specialized banner in the upper left hand corner of any page on the website, then clicking on 'Bikes' then clicking on 'Archive.'
    3. Once you have located your specific model and year in the online archive, click on the 'Geometry' tab located under the photo of your bicycle. This will show you the geometry chart for your specific model and year in accordance with all of the sizes the bicycle came in.
    4. Locate the row in the geometry chart labeled 'head-tube length' and scan across the row until you find the measurement that matches the measurement that you took from your bicycle's head tube.
    5. One you have found a match, scan to the top of that column and you will see the corresponding size of your bicycle.
    Note: A serial number does not indicate the size or the model and year of a bicycle. We will not be able to tell you this information with only the serial number. If you do not know the model and year of your bicycle, you will need to find it manually via the photos in the online archive
    Thanks, except the online archive only goes back to 2005. Any idea where I can find this info for a 1994 model?
    Reputation: Lurchlee's Avatar
    Specialized Bicycles archive info
    Published 10/08/2008 02:42 PM | Updated 01/13/2011 09:02 AM
    Q: Where can I find information about an older Specialized bicycle model?
    A: For bicycles that were produced after 2002, you can find detailed parts specifications, geometry information and pictures on our specialized.com site. This information is listed under "Bikes - Archive". Every Specialized Bicycle has graphics and paint unique to that particular year, so if you match graphics and your parts mix (assuming your bike is stock) then Bingo!
    If your bike was produced before 2002 gives us a call at: 877-808-8154 and we will look up the information you need.
    Another good online resource for information on bikes built previous to 2002 is bikepedia.com
    Thank You
  1. Help in trying to determine the size
    By webmstrk9 in forum Surly
    Last Post: 08-16-2011, 03:07 PM
  2. Replies: 16
    Last Post: 08-06-2011, 01:52 PM
  3. How to determine V10 size?
    By coiler_guy in forum Santa Cruz
    Last Post: 04-06-2011, 07:06 AM
  4. How do you determine Fork Size (travel) for new frame?
    By robale43 in forum Bike and Frame discussion
    Last Post: 03-05-2011, 09:26 AM
  5. How to determine proper frame size?
    By bagz007 in forum General Discussion
    Last Post: 04-09-2004, 10:37 PM
