Results 1 to 7 of 7
    Hi lo disc front hub 9mm to 20mm
    Is that possible? I just bought 2011 stumpy comp carbon and it came with 9mm front hub, and i would love to use my fork ith it but its 20mm maxle so no go with this wheel unless i canconvert, which seems like with right caps it would be possible.
    By any chance does anyone know if its possible?
    Reputation: mfronk1's Avatar
    Want the same thing so I design it.
    I wanted to do the same thing but specialized said they don't make a kit for it. They list a right side end cap but that is it. Talking with the local shop that called their customer service, they found out that specialized sees that wheel as xc oriented and doesn't make a 20mm conversion. I designed a kit with right, left end caps and a spacer and am testing the waters to see if there is any interest in purchasing such an item. See the drawing below. The hub currently comes set up with 6704 bearing which has a 20mm ID so the design intent of the hub is there. Let me know what you think of the kit.
    Looks very interesting. Do you have any for sale? What is the cost?
    I'm currently in the process of making a set up to check fitment, ease of installation, etc. I need to determine the time spent in fabrication, and if I had enough interest I would pay a shop to program them into a CNC lathe and spit out a whole bunch reducing the cost. I should have a set finished next week or shortly there after and I can get you more solid details. Just as a preliminary guess I would say, to be competitive with other end cap and axle conversion prices, i.e. hope, chris king, etc, the price would be somewhere between $40 and $60.
    Cool, keep me updated
    I got the parts made and it worked out quite well. I can send you pics of the caps and the center cylinder and give you some instruction on install. Send me your email and I will send the pics. I would upload here but it limits the size of file. You can pm me your email.
    Oct 2016
    Smile Drawings?
    Hi Mfronk1! I cannot see your drawings...
    I have a 2015 Enduro comp with a hi Low specialized hub and I am missing an end cap bushing on the brake side (came off during flight and part is no where to be found in bike box). I would need a design for the end cap on the brake side to get is done on a lathe here locally in New Zealand. Specialized told me to buy a whole new hub or a new wheel as this end cap is not sold separately!
    I am looking for design for the part. However my axle diameter is 18 mm though. (outside diam of the axle , silver part in picture above, before the greased area)
    Cheers
    Vic
    Hi lo disc front hub 9mm to 20mm-img_5943.jpgHi lo disc front hub 9mm to 20mm-img_5944.jpgHi lo disc front hub 9mm to 20mm-img_5946.jpgHi lo disc front hub 9mm to 20mm-img_5949.jpg
  1. Replies: 21
    Last Post: 07-01-2013, 11:16 PM
  2. Replies: 3
    Last Post: 10-05-2012, 01:39 PM
  3. Replies: 16
    Last Post: 03-20-2012, 07:44 PM
  4. Specialized Hi-Lo disc, 20mm thru-axle & Rockshox Tullio help please?
    By Unicornz0 in forum Shocks and Suspension
    Last Post: 02-08-2012, 06:40 PM
  5. Tutorial for Adjusting a 20mm TA Specialized Hi Lo Disc Hub
    By Metamorphic in forum Wheels and Tires
    Last Post: 10-23-2011, 10:56 PM
