Results 1 to 25 of 25
    Henge Saddle Creaking
    Does anyone have a problem with the Henge Expert (saddle on the higher end Enduro & Stumpys) saddle creaking? Itís not at the rails. It seems to be between the plastic and the leather. Itís annoying and loud.
    I donít want to return it if there is a simple fix.
    Aug 2010
    No simple fix. AFAIK the Henge and the Phenom have the same problems...where the rails meet the plastic housing, annoying creak.....Mine actually cracked in half...(Henge SL)!!!!! I returned it and exchanged it for a FORMAT Ti, no more creaking. Don't ask me why
    With the help of gravity, get some very light lube into the area where both the front and back of the metal rails are inserted into the plastic seat base. Worked for me. May also be a very dry assembly of the mechanism that clamps the seatpost to the seat rails.
    Whining is not a strategy.
    Mar 2011
    i dont know what seat i have on my '11 hardrock but its OEM and its doing it too.
    Oct 2010
    my friends enduro has a henge seat the creaks and its super annoying.
    he is too busy to ride it as of lately, so i have it. i have already bent the seat rails on 2 other seats, this one i am afraid i am gonna actually break something.
    i will try the grease idea and see if that helps
    Reputation: zoorlen's Avatar
    Quote Originally Posted by kosmo View Post
    For me too: I used some teflon spray lube and the "click clock" went away.
    Reputation: Stumpjumper61's Avatar
    I have believe it or not, 3 henge comp saddles. One of them is very loose and creeks where the two rails attach in the aft section. The other two are solid. Quality control at its best.
    Besides the noise, how comfortable is the henge saddle?
    Aug 2010
    My Phenom saddle that came on my 2011 Epic has the creaking problem also. I squirt some tri-flow where the rails meat the nose of the saddle and this fixes it for a while. I don't think it means the saddle is failing, it's just an annoyance.
    Jun 2010
    I have a different fix for this, thought it doesnt always work - instead of lubing the end of rails, i put the strongest permanent locktite i could find, some times it solved the prob, sotimes it didnt... good luck.
    Reputation: ChainChain's Avatar
    I lubed it. It worked for a while. Then it came back. I always forget about it until I'm at the trailhead. I like the saddle but everyone is different and just because I like it doesn't mean your are going to find it comfortable.
    Between the saddle and the every creaking bb, I just do my best to think about something else.
    Is not amused
    Reputation: Hutch3637's Avatar
    Quote Originally Posted by walangkatapat View Post
    For me it was straight pain. Switched to the phenom comp gel saddle which was a huge upgrade. The only down side is, like everyone else the noise on both is very annoying.
    Yip yip yip nope nope nope
    Smile
    Thanks.
    Reputation: madsedan's Avatar
    Aug 2010
    I had it on my phenom, almost immediately after I bought it.
    The shop tech said it shouldnt be doing that and immediately e-mailed off to get a warranty replacement, my new one is silent.
    The tech said when they see that its because the rail and plastic joint is not to a tight enough tolerance, the seat actually moves mroe than it should, hence the squeak. Eventually from movement cycles causing the squeak something will faily, likely the plastic, so I'd see if you can get a warranty swap.
    Hardrock 29er, Niner EMD9, Cannondale F29, Camber Expert, 650b Nickel all gone.
    2014 Giant Anthem 27.5 here.
    West Chester, PA
    I have 2 avatar experts with issues. One of them was already replaced under warranty and now the new one has the same problem after about 100 miles, so 3 total with creaking/clicking. My ass really likes the seats and I'm close to the dealer so I'll just keep swapping them out...
    West Chester, PA
    Quote Originally Posted by gozal View Post
    Loctite generally doesn't work for filling gaps, so usually it will just crack and fall out (I tried it too)
    What you really need is a flexible epoxy, but you have to inject it all the way into the rail socket for it to work. Thats not easy.
    Jun 2010
    I had the Henge that came on my 2011 enduro comp. After 3 weeks of riding the bike the rails were popping inside the plastic mold of the seat. I took the seat back to the bike shop I bought the bike from and they exchanged the seat for any seat I wanted as long as it was under $90.00 (cost of the Henge) I exchanged it for a WTB Pure V Pro plus had extra left over for 2 packages of Shot blocks. Score !!!!!! WTB seat is much better.
    Jun 2010
    Quote Originally Posted by 92gli View Post
    accually u'r idea is quiet good, the epoxy will bod the metal and plastic and fill in the big gap, i would go with this if my will start to make noises.
    meanwhile i'm still waiting for my evo so... no creaks yet
    DFMBA.org
    Reputation: MTBeing's Avatar
    My Henge that came stock on my '13 Camber Comp Carbon just started and it's annoying the %$#@! out of me. Doesn't seem to be the frame (fingers crossed) but finding this thread gave me a little peace of mind.
    Update: The main thrust of my issue was a poorly machined surface of an aftermarket seat collar making uneven contact with the top of the carbon seat tube. Once I upgraded the seat collar 80% of the noise went away. I put some 3 in 1 oil down into the areas where the rails make contact with the seat frame and it's pretty much silent now. Lesson: sometimes it's a PITA to find that creak!
    Please donate to IMBA or your local IMBA chapter. It's trail karma.
    DFMBA.org
    Not bad. Coming form a cushy WTB Pure V, I was surprised how good the Henge felt.
    Reputation: Chuch's Avatar
    Jan 2013
    I have a henge and a phenom, and both do it. Glad I found this thread as I really dig both of them, but the noise was driving me mad. Argh! Gonna try a few methods!
    Santa Cruz HTLT
    +1 i'm glad I found this thread. My '14 Camber EVO sounded like firecrackers after about 200 miles. Once I traced it to the seat I swapped out the seat post and mounting gizmo's with my old s-works epic. I really hope its not where the rail goes into the seat. If so, I hope the shop can take care of me.
    Update:
    Shop took my Henge back and allowed me to pay the $30 difference and get a new titanium rail Henge. After ~30 miles the new Henge is creaking and snapping just as bad as the first one. Crappy saddle.
    Keep on Rockin...
    Reputation: Miker J's Avatar
    Nov 2003
    I have 3 of the Henge saddles. Super comfortable for my boney but. My favorite saddle.
    They creak like mad. A squirt of WD every now and then quiets them down.
    Let me know if anyone wants to get rid of their's.
    Reputation: nauc's Avatar
    ive had my Henge Expert for 6 months, its been great
  1. Replies: 2
    Last Post: 05-09-2011, 01:24 AM
  2. Henge Saddle
    By CHSAD in forum Specialized
    Last Post: 02-25-2010, 09:23 PM
  3. Specialized Henge saddle?
    By dblspeed in forum All Mountain
    Last Post: 12-27-2009, 02:00 PM
  4. Creaking Seat Post/Saddle
    By Thomas Anderson in forum Tooltime
    Last Post: 06-16-2008, 09:40 AM
  5. Creaking Saddle - Some less prone than others?
    By dubjay in forum General Discussion
    Last Post: 06-13-2007, 02:24 PM
