Results 1 to 2 of 2
    Reputation: Quantdude's Avatar
    New question here. Help! Single chain guide for '07 SX Trail & Saint Cranks???
    I need some help and I did plenty of searching but I couldn't find what I'm looking for...
    I'm building up a '07 Trail SX in bear claw blue
    Unfortunatley I'm having a hard time fitting a chain guide for my single ring up front. I'm running Saint Cranks with a single 32T Salsa ring and a 11-34 COG set in the rear.
    First I tried my e13 SRS 32 Special...no luck...I would have to grind a TON of the lower chain guide to get it to clear the chain stay. I don't mind griding, but I think I may have to grind so much that it will be weak.
    Next I tried a Gamut P20. The boomerang appeared to fit...but then the stupid bash guard wouldn't clear my Saint crank arms I put my e13 bash gaurd on with the P20 boomerang and they didn't like eachother very much.
    So...what is a good single ring chain guide that will work?
    I searched and it sounds like lots of people are running stingers, but how do they compare to a good solid SRS system? I loved my SRS system on my Heckler. I got it dialed in so it was quiet and I never dropped a chain.
    Suggestions?
    1x9's rule
    The Other Dude
    Reputation: jut8's Avatar
    The truvative single ring setups are a good choice. I was running on for awhile, and it fit without any grinding. Then i decided for the type or riding i mostly do, that i would benefit more from a double ring with a bash guard and tensioner. So i went with the Saint double (22-36t), and e13 36t bash guard, a truvative stinger tensioner, and an XT front derailluer. Everything worked out great, and i couldnt be happier with it.
    But back to the poing, the truvative blackspire ones work great with no crazy grinding like most. I hope this helps
    Sponsors: Specialized, Honey Stinger, The Hive, Twenty6, 661, Elka Suspension, www.Chainsmokeracing.net
