Results 1 to 5 of 5
    Help me pick my next MTB!
    Alright I have it narrowed down to two options:
    Specialized Bicycle Components
    The reason why I am choosing the Epic is because I currently ride a Stumpjumper FSR Comp and I stick mostly with XC type riding so I am looking for something lighter and more efficient. The SJ FSR is a great bike but it is a bit heavy and is more toward trail/more aggressive riding. I do not need all the travel it has in its suspension.
    Now I need help choosing which Epic to get, even though these bikes both use the same frame they have vastly different components/setups. I have only used 2x10 or 3x9 drive train and have no experience with a 1x11. That makes me nervous because I am worried I would run out of gearing going up a long steep climb. If I knew I could turn the gearing just fine going up hill for sustained amounts of time I would jump at the WC over the marathon. This is my main reason for pause. The shorter chain stays on the WC are another unknown for me. Would they cause my legs to tire faster since it would seem like it would put more torque on them?
    I plan on doing races like the Whiskey 50, and Barn Burner 104 and possibly Leadville. Do you think the WC with the shorter chain stays and the 1x11 drive train would be enough or should I go for a more tamer option with more gear choces, longer chain stays in the Marathon model?
    I ride bikes
    Reputation: moefosho's Avatar
    Apr 2013
    Why not the Expert model? Save a grand and it's the same weight?
    1x11 vs 2x10 is a personal preference thing. Both ways you have a pretty wide range. I would suggest riding a 1x11 before buying it.
    The Expert uses their 9m carbon, the WC and Marathon both use their 10m carbon. The components are different as well, Expert uses XTR while WC and Marathon use X0. I have no idea what the exact weight difference would be but there would be a difference.
    I ride bikes
    Apr 2013
    2013 Epic Marathon 23lbs 15oz
    2013 Epic Expert EVO 23lbs 12oz
    2013 Epic S-Works 23lbs
    I know those are the 2013 weights, but they cant be far off this year.
    Quote Originally Posted by moefosho View Post
    Good info! Thank you for that! Hopefully someone will release weights for 2014 bikes sometime soon.
  1. Pick Six
    By Rumpfy in forum Vintage, Retro, Classic
    Last Post: 06-25-2011, 07:55 PM
  2. Please Pick
    By Twiitch in forum Apparel and Protection
    Last Post: 05-13-2011, 10:52 AM
  3. please help me pick my first mtb
    By package81 in forum Beginner's Corner
    Last Post: 04-26-2011, 05:04 PM
  4. Which of the three to pick?
    By bahamabluez in forum 29er Bikes
    Last Post: 03-05-2011, 09:48 PM
  5. Which to pick?
    By hazdxb in forum Wheels and Tires
    Last Post: 03-05-2011, 02:41 AM
