Results 1 to 7 of 7
Thread: Headset
    Headset
    I asked this in the Bike/Frame forum, but was directed here. One of the posters thought Spec. may use a nonstandard size headset.
    I have an 08 FSR XC Expert with a Cane Creek Headset. The desc. on Specialized's website is:
    1 1/8" threadless, black steel cups, loose ball bearings w/ seals
    I'd like to buy a Hope off of Ebay. Here are the specs:
    Steerer Tube: 1-1/8" Threadless
    Headset Type: 1-1/8" Standard Cups
    Color: Red
    Crown Race: 30.0
    Stack Height: 28 mm
    Bearing Type: Cartridge
    Material: Aluminum
    Weight: 90.0 g
    Will I have to do anything other than swap out the two of them? Spec website didn't list anything about "stack height". Is 28mm pretty common/interchangeable?
    Thanks!!!!
    My Stumpie 29er has a King Ti in it with no issues.
    Reputation: tehelmo's Avatar
    28mm = 1.1in
    Measure out both of the headset cups a few times and average it out. You might need to add/take away some spacers depending on your steerer tube length.
    a rouge image I found:
    Thanks for the replies!!
    mmm
    Reputation: timehoc's Avatar
    Talk to your dealer. Spec supposedly has a technical bulletin on non-CC headsets on 08 Stumpys.
    Spec says their forged headtubes are less elastic (than non-forged) so they picked a larger bore for an easier fit with their soft alloy headsets (many Enduro SL an Specialized alloy frames come with something called "Lanusse", prolly just a Cane Creek rebranded headset). Chris King uses a hard alloy that doesn't have as much give
    ↑ ↑ ↓ ↓ ← → ← → B A Select Start
    Thanks for the advice, but this will be for an 08 FSR XC
    Go with the Hope, You'll love it. King makes good stuff, dont get me wrong, but with my latest build up, I run Hope where the King would have been (Hubs, Headsets, Etc) and I honestly like it better. Plus, its different. Anything component wise that Hope puts out I have on my bike. Good sh*t.
    Livin' the dream.
