Results 1 to 5 of 5
    May 2005
    headlight for oversized handlebar problem?
    I have a stumpy and am having problems mounting head lights on my oversize handlebar. I have tried cygo and performance lights, it would work if you mount it on the size but I wanted it to be on the center. I have checked most lights and the mounting option that they use is more or less for regular sized handlebars. any solution for this ? i kinda want to keep my oversize handlebar ( so no i wont replace my bar for a light =) )
    Reputation: mvtreedodger's Avatar
    I have the same problem with my 05 Stumpy. I was looking at making an adpter. It's on my long list of uncompleted projects...
    Quote Originally Posted by new2mtb
    Reputation: simen's Avatar
    Hi,
    I use NiteRider lights and for OS handlebar I simply remove the rubber on bar mount (supplyed with NR products). Lupine will also provide bar mount for their lights in OS version.
    just like a speeder-bike
    Reputation: Barkdog's Avatar
    Check out the Cateye HL-EL400:
    http://www.cateye.com/en/products/vi...d=7&subCatId=2
    That's what I use on my stumpy. The best part is definitely the little mounting strap thing; if you have another bike with regular bars, it'll work on both! And no need to buy a second mount; essentially there is no mount (nothing to leave on the bike).
    It's a great little light; weighs nothing, batteries have yet to burn out... But it's not bright enough for serious trail riding at night. (I actually have two; even with both mounted, it'd be a bit of a strech on a rough trail). But it's great for road/other night riding.
    May 2005
    Yah, nightrider is a good light but too expensive for me atm. I can't justify 250$ and up lights at the moment. But i did see a couple, and the quality is pretty good.
    Cateye unfortunately doesnt have any high watt' lights at the moment. I don't think the LED's is bring enough for me, or to where I go to at night.
  1. Marzocchi Marathon SL knock sound problem
    By Avé in forum Shocks and Suspension
    Last Post: 02-11-2005, 10:58 AM
  2. WB's fork problem...
    By mdutcher in forum 29er Bikes
    Last Post: 12-11-2004, 11:20 PM
  3. Big big big brake problem....
    By AdamOn6thStreet in forum Brake Time
    Last Post: 10-15-2004, 01:33 PM
  4. Problem, Problem, Problem?
    By Mack in forum Shocks and Suspension
    Last Post: 07-13-2004, 08:41 PM
  5. Syntace F99 handlebar fit question
    By Boj in forum Weight Weenies
    Last Post: 05-01-2004, 09:59 PM
