Although I like the 120mm, I don't like the fact that this is a 130mm fork with a 10mm travel reducer inside of it. I would much rather have the extra 10mm and lower my stem on the steerer tube.
Does it change your axle to crown length if you take out the spacer? Or is there just an extra cm of exposed stantion that goes unused on the 120's (a la the Cannondales RP23's)?
In other words, if it doesn't affect the geometry, then why not do this?
In my case it did change the geo. added an inch bet. the crown and axle. Headtube angle is less steep. But I figure for the new specialized bikes that come w/ the rock shox u-turn height adjustment on the fly. They encourage you to lengthen or shorten the shock anyways, depending on terrain.
For those that don't know or are confused about what the spacer does:
The Fox Float RL fork on the 06 Stumpy comes from Specialized with a 10mm spacer installed to limit the travel to 120mm. This is a 130mm fork though. The spacer can be removed (see the link below for instructions) to get the full 130mm. I prefer a higher front end and I have already raised the stem to it's maximum height on the steerer tube. http://forums.mtbr.com/showthread.php?t=298618
That makes sense. My frame is an '06 S-works Stumpy 120, but all my running gear came from an '05 Enduro so the fork is a Float 130 and I don't have the washer. Maybe I can get it from Fox.
This bike is great but for hard climbing its a little too wheelie prone. I could get a cheap adjustable travel fork but I like the Float and setting it at 120 would help a little.
OK who has the balls to do this? My front fork creaks when I turn it all the way from one side to the other (after a Downieville trip in which the air pressure had fallen to 10) but doesnt seem to really be a problem. I am thinking, however, to remove the spacer and at the same time hopefully the creakamabob will go away.
Does anyone have clear diagram of this fork? The info on the other link is very sparse. I want to see all the pieces and parts that make it up, and how they're connected, etc.
I had my LBS remove the spacer from my Rock Shox Recon taking it from 100 to 130mm. Cost me $30 and two days of waiting. Well worth it. I had the diagram from SRAM's website, but really did not care to mess with it.
Not that hard to do. I just followed the instructions on the CD manual that came with my 07 comp. I don't remember all the details, but it only took me a half hour or so, and I'm not the fastest wrench. For the 07 models it's a 20 mm spacer, turning the fork into a 140mm.
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
