Results 1 to 2 of 2
    hardrock to a enduro ?
    Hi im new to this site and have a question.
    I currently own a Hardrock pro disc, its a great bike! but now I have discovered the enduro!
    i love the frame on that. So, now im wondering if i could buy the enduro frame and fit all my hardrock components on to the frame. Would this be possible? The forks will be upgraded but everything else I still plan to use.
    thanks!
    Enduro 130 or new 150?
    I'm not sure which frame you are after but I may have some answers for you. I have an 05 Enduro 130 (old style) an my buddy has a new S-Works 150.
    The only way you can get a new frame only is an S-Works ($2200us) unless you can find a used frame for sale.
    Obviously you will need a longer travel fork.
    The front derailer and bottom bracket may not work off your old bike but everything else should be fine (although heavy). Might need new cables too.
    I woul recommend going to a 7" or 8" front brake. If you have the Avid mechanicals you can buy the bracket and rotor to save some $$.
    My only complaint is the low BB height so I put a bashguard in place of the big ring and I am going to try a slightly longer rear shock 7.825 (stock length is 7.625).
  1. TALAS fork seal leaking: Enduro or PUSH?
    By PiroChu in forum Shocks and Suspension
    Last Post: 06-16-2005, 07:48 AM
  2. replace 03 Enduro with 05 Stupjumper FSR?
    By slyfink in forum Specialized
    Last Post: 04-18-2005, 08:52 PM
  3. Saber vs. Enduro Geomerty
    By mtnfiend in forum Bike and Frame discussion
    Last Post: 01-22-2005, 07:24 PM
  4. My New 04 Enduro Pro
    By rakkar in forum Specialized
    Last Post: 11-09-2004, 08:52 PM
  5. Replies: 0
    Last Post: 08-03-2004, 11:39 AM
