• 08-22-2012
    TiGeo
    Got my new 2013 Roval Controls today
    First major upgrade for my '12 Stumpy Evo 29 HT. The new 2013 Roval Control wheels. Only difference is the color schemes this year, mine are black/white. A lot better than that red spoke deal they did last year. Also changed out the Purgatory and Ground Control for a Renegade Control 1.95 (rear) and a S-Works Fast Track 2.0 (front). Trails have been dry and these should help me fly. A little weird looking down and seeing such a skinny front tire! Lost over 1 pound with the upgrade. Bike now weights in ~23.5 lbs on the bathroom scale. Trying out tomorrow night. The wheels are great, very light and seem stiffer than the Traverse/HiLo stock set up. A little bummed that the new wheels don't come with 9mm Skraxle end caps, oh well.
  • 08-22-2012
    tonytourist
    Anything is an upgrade over the stock wheelset. I want a set of the Control SLs, just haven't felt like spending the money... yet. Post some pictures!
  • 08-22-2012
    tobyinsydney
    I thought the other big difference is the zero bead hook... this is quite a big change in my mind. Kinda scary but I guess it works!
  • 08-23-2012
    TiGeo
    The Controls are the aluminum rims, the bead hook change was on the carbon rims. Pics to come today.
  • 08-23-2012
    TiGeo
    3 Attachment(s)
    Here are some pics.
  • 08-23-2012
    tooclosetosee
    Sweet, I will be getting a set of the Black/White with my new build. They look nice.
  • 08-23-2012
    ftajiri
    2013 roval carbon go wider than 2012.. other differences is in hub dimension
  • 08-23-2012
    RCMTB
    Very nice! Let us know how they're working out when you get some rides on them. I'm looking for a new set for the spring. Right now, I'm looking at the Rovals and the new 29er Mavics.
  • 08-23-2012
    tooclosetosee
    Nice looking bike man. I like how the white on the rims go with your shock and everything else is blacked out. If I had my way and money wasn't an issue, I would have gone with the blacked out Sworks Epic frame. I'm a big fan of the murdered out look.
    Did your wheels come with the 18 or 36 point star ratchet? I went from a 15 POE hub to a 30 POE stans hub and really noticed the difference on POE and I don't think I will be able to go back. I'll probably upgrade to the 36 point ratchet after a while if I think it is justified. I really don't know why the 36 point star wouldn't be in the hubs if they are supposed to be the super high end wheels that Specialized is selling.
  • 08-23-2012
    TiGeo
    I have no idea of the hub's POE, I know its higher than the HiLo that came off. I am pumped to ride them this weekend. Lost over a pound with this wheelset/tires.
  • 08-23-2012
    TiGeo
    These are 24mm vs. the 26mm Traverse rims on the stockers. Harder to get the tires to air up b/c the bead of the tires won't cover the valve stem easily, just a little wrestling and they went with a floor pump.
  • 08-27-2012
    tooclosetosee
    Here are mine. They come with the 36 star ratchet.
  • 09-01-2012
    TiGeo
    Ride report. Not a big change beyond the louder free hub. The higher POE is nice. They are stiffer to me than the Traverse stockers they replaced. I burped my rear Renegade on a bad line choice, just lost a little air. With the more narrow tires it's clear that I can't run as low of pressure as I was with the wider stock tires. Finally, the tires work great and rolling resistance is certainly less. No issues with traction or cornering so I think this combo is a winner. Final comment, it's always nice to loose over a pound of weight!
  • 12-09-2012
    GnarBrahWyo
    What did you guys end up paying for the complete wheelset if I may ask?
  • 12-09-2012
    TiGeo
    The shop I bought the bike at gave me a smokin' deal...not cool to post that so I can just say less than the MSRP of $700. Sorry I can't be more specific.
  • 12-09-2012
    jochribs
    TiGeo, anymore feedback on the wheels? I see you've had them for quite some time. I see that you said you burped them with the 1.95 Renegades...what sort of pressure where you running when you burped? I ask because I am really interested in these wheels, but the minimum recommended pressure has me a bit wary of being able to run the pressures I like.
    I recently got the S-Works Renegades in 29x2.3, and actually really like them. I had been running the 1.95's since I built the bike this past summer at around 20-22psi with tubes. I've found that the 2.3's are riding very well for me at 15psi with tubes...(don't balk, I kid you not).
    Just looking for some real feedback about how these wheels performed, and if you have gone below the 25 psi minimum? And also to say, grab a set of 29x2.3 Renegades...they're awesome!
    **Edit, I'm just realizing/seeing that your wheels aren't the carbon/hookless bead ones. Sorry for the mistake.
  • 12-09-2012
    ds33gt
    Ti Geo-
    I've had the Purgatory/Ground control combo on my last two bikes( my EVo and my stumpy) and am thinking of going to a ground control front and fast trak rear on my stumpy. Could you see a big difference in rolling resistance going to your current setup?
  • 12-10-2012
    TiGeo
    Originally Posted by ds33gt View Post
    Ti Geo-
    Yes. The Renegade/Fast Trak combo is super fast.
  • 12-10-2012
    TiGeo
    I was around 20 (probably less) and I pushed it hard in a whoop-d-doo when it burped. I am running 22-23 now with no issues. I weight 165. I run the front around 22 with no issues.
    The wheels perform great; did an 18 hour race with them in Sept. Knocked the rear out of true slightly slamming into a root at night with my @ss on the seat so I rim-checked pretty bad. Trued right up with no issues. They are great wheels and I would buy again.
    The 2.3 Renegades may be a good dry condition choice next year and should be large-volume to soften up the ride a bit.
  • 12-10-2012
    jochribs
    I've found that the Renegades (both sizes, but even more with the 2.3's ) do better than expected when it's damp. I wouldnt ride them in goopy conditions, but then again, I don't bother riding when it's like that anyway. They're a little skatey here and there, but predictable.
  • 12-10-2012
    TiGeo
    I agree, the Renegade (I run it as a rear tire) works fine most of the time, however, with the current level of leaves on the trail, the knobs are not tall enough to get a good bite into the soil beneath and I slip quite a bit. I am likely going to drop the Purg/Ground Control combo back on until the leaves are gone.
  • 12-10-2012
    jochribs
    Ha! I hear ya. I found exactly that a few weeks ago when the leaves were a little more heavy. Did a few two wheel drifts when I pushed, but I never felt too bad on em.
    Are you having trouble with the Fasttrak? (that's what you have up front, right?) I've never used them, and wish the casing was just a little larger on the 2.2. It's about the same size as the Renegade 1.95. Just wondering if that's what isn't giving you any bite.
  • 12-10-2012
    TiGeo
    The Fasttrak is the same - washes a bit in the leaves b/c the knobs aren't that tall. I run the 2.0.
  • 12-10-2012
    GnarBrahWyo
    Just out of curiousity, how come I only hear about Rovals and Stan's wheels on this forum? How are DT Swiss wheels? Just by internet browsing, their prices seem to be lower. Is there a reason?
  • 12-10-2012
    tooclosetosee
    I assume that you are talking about rims since you can get Stans wheels built with Dt Swiss hubs from Stans and Roval wheels often come with DT Swiss internals. I haven't heard much of anything about DT Swiss rims being run tubeless and Stans and Roval rims seem to have had a decent amount of success being run tubeless. Going to the DT Swiss site I don't see prices on their rims, but they only have one model under 1700 grams that isn't carbon and they don't list the price for it.
  • 12-10-2012
    GnarBrahWyo
    Yeah, my wheelse knowledge sucks. I just know the wheels that are coming with my new Stumpy are 2100 grams or so. Wondering what the best bang for my buck is around $500. I would like to go tubeless too. I weigh in about 185 during riding season and my style is trail/AM.
  • 12-13-2012
    tootall
    ZTR Arch EX 29er Stock Wheelset
  • 12-13-2012
    GnarBrahWyo
    Originally Posted by Andrew-FSR View Post
    Will those work with the through axle on the 2013 Stumpy FSR Comp's?
  • 12-13-2012
    GnarBrahWyo
    Will those work with the through axle on the 2013 Stumpy FSR 29er Comp's?
  • 12-13-2012
    TiGeo
    You should be able to convert them to whichever axle configuration you need. All the info should be on the notubes website.
  • 12-13-2012
    GnarBrahWyo
    Interesting the Stumpy uses different thru-axle sizes on each wheel...just more crap to buy I suppose. haha
  • 12-13-2012
    ritchief
    Yes, I have the Stan Hopes Flow on my 2013 Stumpy Expert 29er...
  • 12-15-2012
    Kimnic
    At 220 I'm not the lightest (but often the fastest on the track), and I have great success with American Classic (alu rims at 1600g), with Schwalbe Nobby Nic 2.35 in the front and Schwalbe Racing Ralph 2.25 in the rear. I run them tubeless and approx. 24/26 psi. Compared to the Roval rims, they are cheaper and only 10g heavier per rim..
    Attachment 745343
  • 12-15-2012
    GnarBrahWyo
    Attachment 745343
    What do those cos t and where do you find them?
